I've been trying to read/write data from/to the internal flash storage after a ble disconnect event occurs on my nRF52 development board.
I am using SDK11 and softdevice s132
I am using the following test snippet for this operation-
sd_ble_gap_adv_stop();
sd_ble_gap_scan_stop();
NRF_UART0->TASKS_STOPTX = 1;
NRF_UART0->TASKS_STOPRX = 1;
NRF_UART0->ENABLE = 0;
uint32_t * addr;
uint8_t patwr;
uint8_t patrd;
uint32_t pg_size;
uint32_t pg_num;
pg_size = NRF_FICR->CODEPAGESIZE;
pg_num = NRF_FICR->CODESIZE - 1; // Use last page in flash
// Start address:
addr = (uint32_t *)(pg_size * pg_num);
// Erase page:
flash_page_erase(addr);
patwr=0x45;
flash_word_write(addr, (uint32_t)patwr);
memcpy(&patrd,addr,1);
//patrd = (uint8_t)*(addr);
uint8_t flag=4;
if(patrd==0x45){
flag=1;
LEDS_ON(BSP_LED_0_MASK);
else{
flag=0;
LEDS_ON(BSP_LED_1_MASK);
err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
//Start scanning for peripherals which advertise.
scan_start();
This results in a kind of runtime error causing all LEDs to light up and freezing the device. I observed using debug mode that this occurs at sd_ble_gap_adv_stop(); when the flash code is present but does not occur when the flash code is absent. This is confusing because the flash part of the code appears after the sd_ble_gap_adv_stop(); and I'm assuming if the code is executed sequentially there shouldn't be any difference at that step.
Either way, I would appreciate any solutions for my problem.
Edit : The "hard fault" appeared when i was experimenting with sd_ble_gap_adv_stop(); by commenting it out, when it is present the debug call stack is just 0x000000 and it exhibits the freeze+LED conditions I mentioned above
Thank you
