I have configured the SPI0 module in master mode with EasyDMA. I use the below code to send data
uint8_t rx_buffer[24]="";
uint8_t tx_buffer[] = "SPIM TEST";
nrfx_spim_xfer_desc_t spim_xfer_desc =
.p_rx_buffer = rx_buffer,
.rx_length = sizeof(rx_buffer),
spim_xfer_desc.p_tx_buffer = ( uint8_t*)tx_buffer;
spim_xfer_desc.tx_length = strlen(tx_buffer);
result = nrfx_spim_xfer(&_t_spi_inst, &spim_xfer_desc, 0);
In the output I get the string "SPIM TEST" and with extra 0xFF bytes. I noticed that the total number of bytes corresponds to the rx_length ?
I reduced the rx_length to 4 bytes and I was able to receive the right amount of bytes on the output !
I did the same thing with the spi example and got the same results. Is this the normal behavior of the module ?
Thank you
