sd_flash_page_erase will not trigger system event?
I'm using pstorage, but found some problem. sd_flash_page_erase will not trigger system event after the operation is complete.
In my code, I registered the system event handler, according to the instruction in pstorage.
err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
And I also fix the bug reported in pstorage.
static void sys_evt_dispatch(uint32_t sys_evt)
	if ((sys_evt == NRF_EVT_FLASH_OPERATION_SUCCESS) ||
            (sys_evt == NRF_EVT_FLASH_OPERATION_ERROR)) {
		pstorage_sys_event_handler(sys_evt);
The pstorage callback reset the flash operation in progress flag.
static void pstorage_callback(pstorage_handle_t *  p_handle,
                                  uint8_t              op_code,
                                  uint32_t             result,
                                  uint8_t *            p_data,
                                  uint32_t             data_len)
	/** @note sys_evt_dispatch --> pstorage_sys_event_handler --> pstorage_callback */
	if (result == NRF_EVT_FLASH_OPERATION_SUCCESS)
		m_flash_opblock = false;
	} else
		APP_ERROR_CHECK(result);
In the very beginning, my code ran into pstorage_init(). It contains an operation of erasing all swap area by using sd_flash_page_erase(). This function returned successfully. However, it will never trigger the system event handler, and thus my flag cannot be reset.
Any idea about this?
