Hi:
In the datasheet, there have a description
Input range = (+- 0.6 V or +-VDD/4)/Gain
for a example, if Gain = 2, reference = 0.6V,
input range = 0.6 / 2 = 0.3V = 300mV
so, this range is +/- 150mV or +/- 300mV?
Hi:
The input range of the ADC core is nominally ± (0.6 V / Gain) if you use the internal reference or ± ((VDD / 4) / Gain) if you use VDD as reference. So, with internal reference and Gain = 2, the input range is from -300 mV to +300 mV.
so, in the single ended input with a same calculate
gain = 1/6
Input range = ± (0.6 V)/(1/6) = 3.6 V
range is -3.6V to 3.6V?
but, I had tried a SAADC with nrf52832, only 0~3.6V
I use those setting
.resistor_p = NRF_SAADC_RESISTOR_DISABLED, \
.resistor_n = NRF_SAADC_RESISTOR_DISABLED, \
.gain = NRF_SAADC_GAIN1_6, \
.reference = NRF_SAADC_REFERENCE_INTERNAL, \
.acq_time = NRF_SAADC_ACQTIME_10US, \
.mode = NRF_SAADC_MODE_SINGLE_ENDED, \
.burst = NRF_SAADC_BURST_DISABLED, \
.pin_p = (nrf_saadc_input_t)(PIN_P), \
.pin_n = NRF_SAADC_INPUT_DISABLED \
// and
nrf_saadc_resolution_set(NRF_SAADC_RESOLUTION_12BIT);
and use this formula to calculate my input
float vf = p_event->data.done.p_buffer[0] * 3.6f / 4096.0f; // 12bit resolution
and I get a correct result, also it is means range only 0~3.6V
