How to change the GPIO output frequency of nRF52832 over 1MHz ?
Dear Sir,
I had a project is lighting the LED matrix, we choose the LED IC is TLC5958 and MCU is using nRF52832.
Now, we have a question is how to change the GPIO output frequency ?
After calculation, the LED IC clock needs 1.524MHz, but we try to pass the C language or modify the assembly language, GPIO can only output 1MHz.
Have any friends can help us ?
Thank you.
Wesley
2018.07.23
  • You can generate 1.6 MHz using a PWM peripherial. You might need to put the GPIO pin in high drive mode in order to achieve a good signal.
  • Hi Wesley,
    Here is a bare-metal code example to get the PWM peripheral to output 1.6MHz on pin 4:
     * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdbool.h>
    #include <stdint.h>
    #include "nrf.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #define PWM_PIN 4
    int16_t buf[] = {(1 << 15) | 5}; // Inverse polarity (bit 15)
        // Start accurate HFCLK (XOSC)
        while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0) ;
        // Configure PWM_PIN as output, and set it to 0
        NRF_GPIO->DIRSET = (1 << PWM_PIN);
        NRF_GPIO->OUTCLR = (1 << PWM_PIN);
        NRF_PWM0->PRESCALER   = PWM_PRESCALER_PRESCALER_DIV_1; //
        NRF_PWM0->PSEL.OUT[0] = PWM_PIN;
        NRF_PWM0->MODE        = (PWM_MODE_UPDOWN_Up << PWM_MODE_UPDOWN_Pos);
        NRF_PWM0->DECODER     = (PWM_DECODER_LOAD_Common       << PWM_DECODER_LOAD_Pos) |
                                (PWM_DECODER_MODE_RefreshCount << PWM_DECODER_MODE_Pos);
        NRF_PWM0->LOOP        = (PWM_LOOP_CNT_Disabled << PWM_LOOP_CNT_Pos);
        NRF_PWM0->COUNTERTOP = 10;
        NRF_PWM0->SEQ[0].CNT = ((sizeof(buf) / sizeof(uint16_t)) << PWM_SEQ_CNT_CNT_Pos);
        NRF_PWM0->SEQ[0].ENDDELAY = 0;
        NRF_PWM0->SEQ[0].PTR = (uint32_t)&buf[0];
        NRF_PWM0->SEQ[0].REFRESH = 0;
        NRF_PWM0->SHORTS = 0;
        NRF_PWM0->ENABLE = 1;
        NRF_PWM0->TASKS_SEQSTART[0] = 1;
        while (true)
        __WFE();
