dazzled and confused
Hi, Okay I got my nRF52840 Dongle, plugged it in to my window 10, verified it shows up as USB device on window's Device Manger.
Checked and Red pulsating LED (LD2) was pulsing, meaning  nRF52840 Dongle has entered the bootloader mode.  Fired up the "nRF Connect".
Launch the <Programmer (experimental)> app.  Selected the device, It displayed a Map showing BootLoader and some Application.  Browse and
added my test hex file. Press <Write all to devkit> button, some programming happened, LD2 stop pulsating and following messages appeared
on the Log below nRF connect
23:08:33.6730
Application data folder: C:\Users\xxxxx\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
23:09:06.5490
Using USB SDFU protocol to communicate with target
23:09:06.5690
Protocol Version: 1 found
23:09:06.5710
Hardware: 52840 found
23:09:06.5760
Firmware: Bootloader found
23:09:06.5760
Firmware: Application found
23:10:32.8940
Parsing .hex file: C:\Users\XXX\Desktop\myNordic_Develop_all\ble_app_lightbulbP2-X5\Output\Debug\Exe\ble_app_lightbulbP.hex
23:10:32.8990
File was last modified at 7/17/2018, 1:03:10 PM
23:10:33.0810
Data block: 0x00026000-0x0003D7A4 (0x000177A4 bytes long)
23:12:01.9130
Hash is generated by SHA256
23:12:01.9370
Performing DFU. This may take a few seconds
23:12:06.1300
DFU completed successfully!
OKAY - It looks all good - looks like DFU got installed but where is my application (ble_app_lightbulbP.hex) which was what I wanted and selected.
Also noting is running, no advertising are happening.  Am I missing something? Does this means that only DFU can be installed
on the dongle and my real application need to go through a smart-Phone (zipped package, nRFUtil). OR can I program my dongle just the way
I program my nRF52840 DK using the SES.  I check around and read DFU info. most of them utilize Keil, which most of your example program
don't compile as they are greater then 32K. so please any suggestion how to proceed - please point to SES.
Another question,  can I use your JTAG header pins on the Dongle and program my Hex file. I understand DFU is great tool to field upgrade an existing
device but right now all I am interested is to use my dongle as my nRF52840 DK and later install the BLE sniffer app.
Thanks
  • Hi jsayed
    With regards to the second part of your question "Another question,  can I use your JTAG header pins on the Dongle and program my Hex file. I understand DFU is great tool to field upgrade an existing
    device but right now all I am interested is to use my dongle as my nRF52840 DK and later install the BLE sniffer app."
    I think this is described in the Debug output section of the DK users guide (pls see the link)
    http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.nrf52%2Fdita%2Fnrf52%2Fdevelopment%2Fnrf52840_pdk%2Fif_mcu.html
    Cheers
    Michael
    first and foremost, the dongle is not a replacement for the DK, it is a supplement primarily targeted to be the HW frontend for nRF Connect for Desktop. That said, what you plan to do will be possible to do but will require the use of a DK in addition to the dongel.
    Based on your description it is a bit unclear what you want to do. There is already a USB DFU on the device and this can't be replaced by the user through the USB interface. If you want to replace it then you will need to use the SWD interface. If so then you will need to read out the memory through SWD prior to erasing if you want to revert to the default FW later, there is another post on how to do this in DevZone.
    As of today, the nRF Connect for Desktop programming app does not support programming applications using the SoftDevice, this will be coming with the next update. In the meantime you can program such applications through nrfutil (though not the DFU section).
