To implement UART service in an example which can act as both central and peripheral at a time.
 I need to implement UART service in such a way that it should act as both central and peripheral at a time.
I am using nRF52832 board and SDK 15.
I want to know which example is suitable in "central and peripheral" example to implement UART service , or can we implement in either ble_uart peripheral or in ble_uart central?
can anyone help in this?
Thanks in advance,
kishor.
  • this is : nRF5_SDK_15.0.0_a53641a\nRF5_SDK_15.0.0_a53641a\examples\ble_central_and_peripheral\experimental\ble_app_hrs_rscs_relay
    You can replace services on this project to nus service
  • Hi Giang ,
    Now i changed to sdk 12.3 and using nrf52832 .
    I have merged both ble uart central and peripheral example to achieve my task.
    It compiled good and error free but neither it is scanning nor advertising.
     * Copyright (c) 2016 Nordic Semiconductor. All Rights Reserved.
     * The information contained herein is confidential property of Nordic Semiconductor. The use,
     * copying, transfer or disclosure of such information is prohibited except by express written
     * agreement with Nordic Semiconductor.
    #include <stdio.h>
    #include <stdint.h>
    #include <stdbool.h>
    #include "nordic_common.h"
    #include "app_error.h"
    #include "app_uart.h"
    #include "ble_db_discovery.h"
    #include "app_timer.h"
    #include "app_util.h"
    #include "bsp.h"
    #include "bsp_btn_ble.h"
    #include "boards.h"
    #include "ble.h"
    #include "ble_gap.h"
    #include "ble_hci.h"
    #include "softdevice_handler.h"
    #include "ble_advdata.h"
    #include "ble_nus_c.h"
    #include "ble_nus.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "ble_conn_state.h"
    #include "SEGGER_RTT.h"
    #include "fstorage.h"
    #define CENTRAL_LINK_COUNT      1                               /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
    #define PERIPHERAL_LINK_COUNT   1                               /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
    #if (NRF_SD_BLE_API_VERSION == 3)
    #define NRF_BLE_MAX_MTU_SIZE    GATT_MTU_SIZE_DEFAULT           /**< MTU size used in the softdevice enabling and to reply to a BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST event. */
    #define UART_TX_BUF_SIZE        256                             /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE        256                             /**< UART RX buffer size. */
    #define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN      /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_TIMER_PRESCALER     0                               /**< Value of the RTC1 PRESCALER register. */
    #define APP_TIMER_OP_QUEUE_SIZE 2                               /**< Size of timer operation queues. */
    #define SCAN_INTERVAL           0x00A0                          /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW             0x0050                          /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_ACTIVE             1                               /**< If 1, performe active scanning (scan requests). */
    #define SCAN_SELECTIVE          0                               /**< If 1, ignore unknown devices (non whitelisted). */
    #define SCAN_TIMEOUT            0x0000                          /**< Timout when scanning. 0x0000 disables timeout. */
    #define DEVICE_NAME             "Nordic_UART"
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)
    #define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Determines minimum connection interval in millisecond. */
    #define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Determines maximum connection interval in millisecond. */
    #define SLAVE_LATENCY           0                               /**< Determines slave latency in counts of connection events. */
    #define SUPERVISION_TIMEOUT     MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 millisecond. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_TIMEOUT_IN_SECONDS      180
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3
    #define UUID16_SIZE             2                               /**< Size of 16 bit UUID */
    #define UUID32_SIZE             4                               /**< Size of 32 bit UUID */
    #define UUID128_SIZE            16                              /**< Size of 128 bit UUID */
    static ble_nus_c_t              m_ble_nus_c;                    /**< Instance of NUS service. Must be passed to all NUS_C API calls. */
    static ble_db_discovery_t       m_ble_db_discovery;
    static ble_nus_t                m_nus;  /**< Instance of database discovery module. Must be passed to all db_discovert API calls */
    static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};
    static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;
     * @brief Connection parameters requested for connection.
    static const ble_gap_conn_params_t m_connection_param =
        (uint16_t)MIN_CONNECTION_INTERVAL,  // Minimum connection
        (uint16_t)MAX_CONNECTION_INTERVAL,  // Maximum connection
        (uint16_t)SLAVE_LATENCY,            // Slave latency
        (uint16_t)SUPERVISION_TIMEOUT       // Supervision time-out
     * @brief Parameters used when scanning.
    static const ble_gap_scan_params_t m_scan_params =
        .active   = 1,
        .interval = SCAN_INTERVAL,
        .window   = SCAN_WINDOW,
        .timeout  = SCAN_TIMEOUT,
        #if (NRF_SD_BLE_API_VERSION == 2)
            .selective   = 0,
            .p_whitelist = NULL,
            .use_whitelist = 0,
     * @brief NUS uuid
    static const ble_uuid_t m_nus_uuid =
        .uuid = BLE_UUID_NUS_SERVICE,
        .type = NUS_SERVICE_UUID_TYPE
    /**@brief Function for asserts in the SoftDevice.
     * @param[in] line_num     Line number of the failing ASSERT call.
     * @param[in] p_file_name  File name of the failing ASSERT call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function to start scanning.
    static void scan_start(void)
        ret_code_t ret;
    	  (void) sd_ble_gap_scan_stop();
        ret = sd_ble_gap_scan_start(&m_scan_params);
        APP_ERROR_CHECK(ret);
        ret = bsp_indication_set(BSP_INDICATE_SCANNING);
    /**@brief Function for handling database discovery events.
     * @details This function is callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function should forward the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' i.e '\r\n' (hex 0x0D) or if the string has reached a length of
     *          @ref NUS_MAX_DATA_LENGTH.
        static uint8_t index = 0;
    	  SEGGER_RTT_printf(0,"UART_handle");
        switch (p_event->evt_type)
            //@snippet [Handling data from UART]
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
                    while (ble_nus_c_string_send(&m_ble_nus_c, data_array, index) != NRF_SUCCESS)
                        // repeat until sent.
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief Callback handling NUS Client events.
     * @details This function is called to notify the application of NUS client events.
     * @param[in]   p_ble_nus_c   NUS Client Handle. This identifies the NUS client
     * @param[in]   p_ble_nus_evt Pointer to the NUS Client event.
    /**@snippet [Handling events from the ble_nus_c module] */
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, const ble_nus_c_evt_t * p_ble_nus_evt)
        uint32_t err_code;
        switch (p_ble_nus_evt->evt_type)
            case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
                err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
                err_code = ble_nus_c_rx_notif_enable(p_ble_nus_c);
                SEGGER_RTT_printf(0,"The device has the Nordic UART Service\r\n");
            case BLE_NUS_C_EVT_NUS_RX_EVT:
                for (uint32_t i = 0; i < p_ble_nus_evt->data_len; i++)
    							   SEGGER_RTT_printf(0,"message recu central\r\n");
                    while (app_uart_put( p_ble_nus_evt->p_data[i]) != NRF_SUCCESS);
            case BLE_NUS_C_EVT_DISCONNECTED:
                SEGGER_RTT_printf(0,"Disconnected\r\n");
                scan_start();
        // Prepare wakeup buttons.
    /**@brief Reads an advertising report and checks if a uuid is present in the service list.
     * @details The function is able to search for 16-bit, 32-bit and 128-bit service uuids.
     *          To see the format of a advertisement packet, see
     *          https://www.bluetooth.org/Technical/AssignedNumbers/generic_access_profile.htm
     * @param[in]   p_target_uuid The uuid to search fir
     * @param[in]   p_adv_report  Pointer to the advertisement report.
     * @retval      true if the UUID is present in the advertisement report. Otherwise false
    static bool is_uuid_present(const ble_uuid_t *p_target_uuid,
                                const ble_gap_evt_adv_report_t *p_adv_report)
        uint32_t err_code;
        uint32_t index = 0;
        uint8_t *p_data = (uint8_t *)p_adv_report->data;
        ble_uuid_t extracted_uuid;
        while (index < p_adv_report->dlen)
            uint8_t field_length = p_data[index];
            uint8_t field_type   = p_data[index + 1];
            if ( (field_type == BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_MORE_AVAILABLE)
               || (field_type == BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_COMPLETE)
                for (uint32_t u_index = 0; u_index < (field_length / UUID16_SIZE); u_index++)
                    err_code = sd_ble_uuid_decode(  UUID16_SIZE,
                                                    &p_data[u_index * UUID16_SIZE + index + 2],
                                                    &extracted_uuid);
                    if (err_code == NRF_SUCCESS)
                        if ((extracted_uuid.uuid == p_target_uuid->uuid)
                            && (extracted_uuid.type == p_target_uuid->type))
                            return true;
            else if ( (field_type == BLE_GAP_AD_TYPE_32BIT_SERVICE_UUID_MORE_AVAILABLE)
                    || (field_type == BLE_GAP_AD_TYPE_32BIT_SERVICE_UUID_COMPLETE)
                for (uint32_t u_index = 0; u_index < (field_length / UUID32_SIZE); u_index++)
                    err_code = sd_ble_uuid_decode(UUID16_SIZE,
                    &p_data[u_index * UUID32_SIZE + index + 2],
                    &extracted_uuid);
                            return true;
            else if ( (field_type == BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_MORE_AVAILABLE)
                    || (field_type == BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_COMPLETE)
                err_code = sd_ble_uuid_decode(UUID128_SIZE,
                                              &p_data[index + 2],
                                              &extracted_uuid);
                        return true;
            index += field_length + 1;
        return false;
    /**@brief Function for handling the Application's BLE Stack events.
     * @param[in] p_ble_evt  Bluetooth stack event.
    static void on_ble_central_evt(ble_evt_t * p_ble_evt)
    	  SEGGER_RTT_printf(0,"on_ble_evt\n");
        uint32_t err_code;
        const ble_gap_evt_t * p_gap_evt = &p_ble_evt->evt.gap_evt;
            case BLE_GAP_EVT_ADV_REPORT:
                const ble_gap_evt_adv_report_t * p_adv_report = &p_gap_evt->params.adv_report;
                if (is_uuid_present(&m_nus_uuid, p_adv_report))
                    err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
                                                  &m_scan_params,
                                                  &m_connection_param);
                        // scan is automatically stopped by the connect
                           SEGGER_RTT_printf(0,"Connecting to target %02x%02x%02x%02x%02x%02x\r\n",
                                 p_adv_report->peer_addr.addr[0],
                                 p_adv_report->peer_addr.addr[1],
                                 p_adv_report->peer_addr.addr[2],
                                 p_adv_report->peer_addr.addr[3],
                                 p_adv_report->peer_addr.addr[4],
                                 p_adv_report->peer_addr.addr[5]
            }break; // BLE_GAP_EVT_ADV_REPORT
            case BLE_GAP_EVT_CONNECTED:
                //NRF_LOG_DEBUG("Connected to target\r\n");
                // start discovery of services. The NUS Client waits for a discovery result
                err_code = ble_db_discovery_start(&m_ble_db_discovery, p_ble_evt->evt.gap_evt.conn_handle);
                break; // BLE_GAP_EVT_CONNECTED
            case BLE_GAP_EVT_TIMEOUT:
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
                    //NRF_LOG_DEBUG("Scan timed out.\r\n");
                    scan_start();
                else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    printf("Connection Request timed out.\r\n");
                break; // BLE_GAP_EVT_TIMEOUT
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
                break; // BLE_GAP_EVT_SEC_PARAMS_REQUEST
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accepting parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                        &p_gap_evt->params.conn_param_update_request.conn_params);
                break; // BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST
            case BLE_GATTC_EVT_TIMEOUT:
                //NRF_LOG_DEBUG("GATT Client Timeout.\r\n");
                break; // BLE_GATTC_EVT_TIMEOUT
            case BLE_GATTS_EVT_TIMEOUT:
                //NRF_LOG_DEBUG("GATT Server Timeout.\r\n");
                break; // BLE_GATTS_EVT_TIMEOUT
            case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
                err_code = sd_ble_gatts_exchange_mtu_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                           NRF_BLE_MAX_MTU_SIZE);
                break; // BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST
    static void on_ble_peripheral_evt(ble_evt_t * p_ble_evt)
        uint32_t err_code;
    	  SEGGER_RTT_printf(0,"on_ble_peripheral_evt\r\n");
                break; // BLE_GAP_EVT_DISCONNECTED
                break; // BLE_GATTS_EVT_SYS_ATTR_MISSING
            case BLE_EVT_USER_MEM_REQUEST:
                err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
                break; // BLE_EVT_USER_MEM_REQUEST
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                ble_gatts_evt_rw_authorize_request_t  req;
                ble_gatts_rw_authorize_reply_params_t auth_reply;
                req = p_ble_evt->evt.gatts_evt.params.authorize_request;
                if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                    if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                        if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                       // auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                        err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
        &auth_reply);
            } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
                // No implementation needed.
    static void sys_evt_dispatch(uint32_t sys_evt)
        fs_sys_event_handler(sys_evt);
        ble_advertising_on_sys_evt(sys_evt);
    //// for role of th
    //uint8_t ble_conn_state_role(uint16_t conn_handle)
    //    uint8_t role = BLE_GAP_ROLE_INVALID;
    //    if (ble_conn_state_valid(conn_handle))
    //#if !defined (S112)
    //        bool central = nrf_atflags_get(&m_bcs.flags.central_flags, conn_handle);
    //        role = central ? BLE_GAP_ROLE_CENTRAL : BLE_GAP_ROLE_PERIPH;
    //#else
    //        role = BLE_GAP_ROLE_PERIPH;
    //#endif // !defined (S112)
    //    return role;
    /**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
     * @details This function is called from the scheduler in the main loop after a BLE stack event has
     *          been received.
    static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    	  uint16_t conn_handle_nb;
    	  uint16_t role;
    	  ble_conn_state_on_ble_evt(p_ble_evt);
    	  conn_handle_nb = p_ble_evt->evt.gap_evt.conn_handle;
        role        = ble_conn_state_role(conn_handle_nb);
    	  SEGGER_RTT_printf(0,"EVT conn handle num %u!!\r\n", conn_handle_nb);
    	  if(role != BLE_GAP_ROLE_INVALID)
    			    if (role == BLE_GAP_ROLE_PERIPH) //MAX
    							SEGGER_RTT_printf(0,"PERIPH\r\n");
    							on_ble_peripheral_evt(p_ble_evt);
    							ble_advertising_on_ble_evt(p_ble_evt);
    							ble_conn_params_on_ble_evt(p_ble_evt);
    					if (role == BLE_GAP_ROLE_CENTRAL)
    							SEGGER_RTT_printf(0,"CENTRAL\r\n");
    							on_ble_central_evt(p_ble_evt);
    							bsp_btn_ble_on_ble_evt(p_ble_evt);
    							ble_db_discovery_on_ble_evt(&m_ble_db_discovery, p_ble_evt);
    							ble_nus_c_on_ble_evt(&m_ble_nus_c,p_ble_evt);
    					SEGGER_RTT_printf(0,"INVALID\r\n");
        uint32_t err_code;
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        // Initialize the SoftDevice handler module.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                        PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        //Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
        ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
        err_code = softdevice_enable(&ble_enable_params);
        // Register with the SoftDevice handler module for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    		err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
     * @param[in] event  Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
    /**@brief Function for initializing the UART.
    static void uart_init(void)
        uint32_t err_code;
        const app_uart_comm_params_t comm_params =
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .flow_control = APP_UART_FLOW_CONTROL_ENABLED,
            .use_parity   = false,
            .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                            UART_RX_BUF_SIZE,
                            UART_TX_BUF_SIZE,
                            uart_event_handle,
                            APP_IRQ_PRIORITY_LOW,
                            err_code);
        //APP_ERROR_CHECK(err_code);
    /**@brief Function for initializing the NUS Client.
    static void nus_c_init(void)
        uint32_t         err_code;
        ble_nus_c_init_t nus_c_init_t;
        nus_c_init_t.evt_handler = ble_nus_c_evt_handler;
        err_code = ble_nus_c_init(&m_ble_nus_c, &nus_c_init_t);
    static void buttons_leds_init(void)
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LED,
                                     APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                     bsp_event_handler);
    /** @brief Function for initializing the Database Discovery Module.
    static void db_discovery_init(void)
        uint32_t err_code = ble_db_discovery_init(db_disc_handler);
    /** @brief Function for the Power manager.
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
    static void gap_params_init(void) //MAX
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
    static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length) //MAX
    	  SEGGER_RTT_printf(0,"\r\nmessage receive!\r\n", length);
        for (uint32_t i = 0; i < length; i++)
            while (app_uart_put(p_data[i]) != NRF_SUCCESS);
        while (app_uart_put('\r') != NRF_SUCCESS);
        while (app_uart_put('\n') != NRF_SUCCESS);
    static void services_init(void) //MAX
        uint32_t       err_code;
        ble_nus_init_t nus_init;
    	  SEGGER_RTT_printf(0,"\r\nerror %X\r\n", err_code);
    static void on_adv_evt(ble_adv_evt_t ble_adv_evt) //MAX
        uint32_t err_code;
        SEGGER_RTT_printf(0,"on_adv_evt\r\n");
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
    static void advertising_init(void) //MAX
        ble_advdata_t          advdata;
        ble_advdata_t          scanrsp;
        ble_adv_modes_config_t options;
        // Build advertising data struct to pass into @ref ble_advertising_init.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = false;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        memset(&scanrsp, 0, sizeof(scanrsp));
        scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
        memset(&options, 0, sizeof(options));
        options.ble_adv_fast_enabled  = true;
        options.ble_adv_fast_interval = APP_ADV_INTERVAL;
        options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
        err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
        APP_ERROR_HANDLER(nrf_error);
    static void on_conn_params_evt(ble_conn_params_evt_t * p_evt) //MAX
        uint32_t err_code;
    static void conn_params_init(void) //MAX
        uint32_t err_code;
        APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, NULL);
        uart_init();
        buttons_leds_init();
        db_discovery_init();
        ble_stack_init();
    	  gap_params_init();   //MAX
    	  services_init();     //MAX
        advertising_init();  //MAX
        conn_params_init();	 //MAX
        nus_c_init();
        SEGGER_RTT_printf(0,"Uart_c Scan started\r\n");
        scan_start();
    	  SEGGER_RTT_printf(0,"\r\nUART Start!\r\n");
        err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    		//adv_scan_start();
        for (;;)
            power_manage();
    I am using above code, could u please help me where i went wrong?
    Thanks in advance.
