Only getting advertisement using nRF51 sniffer (nrf v.2-beta)
I have a usb dongle with nRF51422 (PCA10031) and downloaded nrf sniffer software version 2-beta from https://www.nordicsemi.com/eng/nordic/download_resource/65225/1/90637756/136163
I am running this on a Linux machine and using Wireshark (v2.4.6) to analyse the packages.
I've followed the documentation for v2-beta of the sniffer on how to setup the sniffer + the Wireshark plugin.
I'm trying to sniff a BLE communication between 2 devices (not including my computer) like:
- Start sniffer + Wireshark
- Choose to follow either of the devices
- Initiate a pairing session from either of the device
- Terminate the paring session
Now I expect to be able to analyse the traffic but I only see the advertisement/broadcast packages (ADV_IND/SCAN_REQ, etc,,,).
Is there any known issue with this or am I missing something ?
regards
Einar
  • Hi Einar,
    is this consistent, i.e. you're not able to see data packets when the two devices are in a connection  even if you disconnect and re-connect multiple times, or is occasionally?
    I have  observed that occasionally the connection request packet might not be intercepted properly by the sniffer and you then lose the connection because you do not know which channels to jump to or the conenction interval etc. This is usually solved by disconnecting and then reconnecting the two devices. Have you followed the instructions in the nRF Sniffer v2 User Guide, i.e.
    Sniffing a connection involving a single slave device
    To sniff a connection between a specific Peripheral device and a Central:
    1. Start the Sniffer if not already running.
    2. In the Sniffer, choose the device from the Device drop-down list.
    3. Connect the Central to the Peripheral.
    Best regards
    Bjørn
  • Hi Bjorn and thank you for your response.
    It seems so that this happens occasionally.
    Is that maybe normal, i.e. the sniffer missing out on the connect packet and therefore unable to latch on to the hopping sequenced thereafter ?
    If so I guess I'll just have to be patient with it
    regards
    Einar
  • Yes, you will simply have to perform the capture again if you do not see the connetion request packet.
    Best regards
    Bjørn
