Good day
I can't see my beacon on my phone after downloading the app. The beacon is on but still can't be recognised on the phone.
what might be the problem?
Tshepo
HI
I have read chapter 4.3 and also followed the instruction before i started to load the nRF Beacon app and even deleted the app and reinstalled twice but still nothing is seen when i scan it.
i tried to load it manually but the app keeps on stating that the beacon is not found.
what will be the next step?
I assume you beacon kit is flashing a purple light every 5th second?
Have you enabled "Location services" on the iOS device, especially for the nRFbeacon app. Please go to Privacy settings - location services to enable this.
Do you get the nRFBeacon up on main part of the beacon app? Are you able to read the UUID for beacon?
Hi
Finally i got the answer and its as follows:
I believe the steps that solved it for me were:
in iPhone app select "Update" tab. Press SW2 on beacon device -- LED turns 'yellow' major, minor & calibrated RSSI fields became auto-filled (for me this was major: 1, minor: 38, rssi: -69) press SW2 AGAIN (LED goes back to original purple blink mode). in iPhone app select "Beacons" tab -- nRF Beacon is now listed. I believe it's 2nd depressing of SW2 that seemed to be necessary.
hope its useful for someone else.
thanks for the effort
