How to run proxy and Nus at the same time
Hi all,
when I insert ble_nus into mesh_gatt . I realized there are two pulse functions with the same function:
void ble_nus_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
    if ((p_context == NULL) || (p_ble_evt == NULL))
        return;
    ble_nus_t * p_nus = (ble_nus_t *)p_context;
        case BLE_GAP_EVT_CONNECTED:
            on_connect(p_nus, p_ble_evt);
        case BLE_GATTS_EVT_WRITE:
            on_write(p_nus, p_ble_evt);
        case BLE_GATTS_EVT_HVN_TX_COMPLETE:
            on_hvx_tx_complete(p_nus, p_ble_evt);
            // No implementation needed.
and
void mesh_gatt_on_ble_evt(const ble_evt_t * p_ble_evt, void * p_context)
            connect_evt_handle(p_ble_evt);
            disconnect_evt_handle(p_ble_evt);
            write_evt_handle(p_ble_evt);
            tx_complete_handle(p_ble_evt->evt.gatts_evt.conn_handle);
        /* TODO: The following events should be handled by an SDK module/the application. */
            uint32_t err_code = sd_ble_gatts_service_changed(p_ble_evt->evt.gatts_evt.conn_handle,
                                                             m_gatt.handles.service,
                                                             m_gatt.handles.service);
            /* Those errors can be expected when sending trying to send Service Changed indication
             * if the CCCD is not set to indicate. Thus set the returning error code to success. */
            NRF_MESH_ASSERT((err_code == NRF_SUCCESS) ||
                            (err_code == BLE_ERROR_INVALID_CONN_HANDLE) ||
                            (err_code == NRF_ERROR_INVALID_STATE) ||
                            (err_code == NRF_ERROR_BUSY));
            NRF_MESH_ERROR_CHECK(sd_ble_gatts_sys_attr_set(p_ble_evt->evt.gatts_evt.conn_handle, NULL, 0, 0));
        case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST:
            ble_gap_data_length_params_t dl_params;
            memset(&dl_params, BLE_GAP_DATA_LENGTH_AUTO, sizeof(dl_params));
            NRF_MESH_ERROR_CHECK(sd_ble_gap_data_length_update(p_ble_evt->evt.gap_evt.conn_handle,
                                                               &dl_params,
                                                               NULL));
            NRF_MESH_ERROR_CHECK(sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle,
                                                             BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                             NULL,
                                                             NULL));
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
            NRF_MESH_ERROR_CHECK(sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys));
        case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
            exchange_mtu_req_handle(p_ble_evt);
        case BLE_GATTS_EVT_SC_CONFIRM:
if they let them coexist , when I use nrf_connect connect and use mesh_app connect , It jump to 2 function , and I only want , if I connect to nus , it jump to ble_nus_on_ble_evt , If I connect to proxy , It jump to mesh_gatt_on_ble_evt . Is this feasible? Can you give me advice ? Thank !!!
  • Thank for help !!!
    This my code modified :
            return;
        ble_nus_on_ble_evt(p_ble_evt, &p_nus);
    //            connect_evt_handle(p_ble_evt);
    //            on_connect(p_nus, p_ble_evt);
    //            uint32_t err_code = sd_ble_gatts_service_changed(p_ble_evt->evt.gatts_evt.conn_handle,
    //                                                             m_gatt.handles.service,
    //                                                             m_gatt.handles.service);
    //            /* Those errors can be expected when sending trying to send Service Changed indication
    //             * if the CCCD is not set to indicate. Thus set the returning error code to success. */
    //            NRF_MESH_ASSERT((err_code == NRF_SUCCESS) ||
    //                            (err_code == BLE_ERROR_INVALID_CONN_HANDLE) ||
    //                            (err_code == NRF_ERROR_INVALID_STATE) ||
    //                            (err_code == NRF_ERROR_BUSY));
    But it still error . If I run NUS service , it jump mesh handle and error ?
    NUS part will run correct if I only use :
    // write_evt_handle(p_ble_evt);
    // tx_complete_handle(p_ble_evt->evt.gatts_evt.conn_handle);
    and error if use :
    can you help me , I really need this ! Thank very much !!!
  • DId you initialise the nus? Call nus_init(); after initialize(); in the main(); function?
  • static void initialize(void)
        __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS, LOG_LEVEL_DBG3, LOG_CALLBACK_DEFAULT);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Proxy Server Demo -----\n");
        hal_leds_init();
        uart_init();
        log_info_init();
        timers_init();
    #if BUTTON_BOARD
        ERROR_CHECK(hal_buttons_init(button_event_handler));
        uint32_t err_code = nrf_sdh_enable_request();
        uint32_t ram_start = 0;
        /* Set the default configuration (as defined through sdk_config.h). */
        err_code = nrf_sdh_ble_default_cfg_set(MESH_SOFTDEVICE_CONN_CFG_TAG, &ram_start);
        gap_params_init();
    //    gatt_init();
        services_init();
        conn_params_init();
        mesh_init();
    static void start(void)
    //    rtt_input_enable(app_rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
        ERROR_CHECK(mesh_stack_start());
        if (!m_device_provisioned)
            static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
            mesh_provisionee_start_params_t prov_start_params =
                .p_static_data    = static_auth_data,
                .prov_complete_cb = provisioning_complete_cb
            ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
        const uint8_t *p_uuid = nrf_mesh_configure_device_uuid_get();
        __LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, "Device UUID ", p_uuid, NRF_MESH_UUID_SIZE);
        initialize();
        execution_start(start);
        for (;;)
            (void)sd_app_evt_wait();
    This is an part of my main . I call nus init() in service_init() function
  • See file "app_config.h", as it overrides some settings in "sdk_config.h". In "app_config.h", NRF_SDH_BLE_PERIPHERAL_LINK_COUNT is set to 1, this value should be increased to allow for the NUS connection.
  • yes , I set it = 1 . Can you send me an simple example run proxy and nus at the same time or I will send my project for you ? Thank very much
