Interactive mesh provisioning and configuration : Provisioning Several Clients Problem
Hey, I use the Interactive mesh provisioning and configuration  tutorial to setup one server and several clients which can communicate with this server.
Can you say me, how can I include several servers and several clients with the pyACI script.
If I use just one Server and One Client everything works fine but if i add additional Client like this
p.scan_start()
p.scan_stop()
p.provision(name="Light switch2")
cc.publish_set(10, 2)
cc.appkey_add(0)
cc.model_app_bind(db.nodes[2].unicast_address + 1, 0, mt.ModelId(1, 0x59))
cc.model_publication_set(db.nodes[2].unicast_address + 1, mt.ModelId(1, 0x59), mt.Publish(db.nodes[0].unicast_address, index=0, ttl=1))
the provisioning process works fine but if I  Press the Button and try to communicate to the server from the two  clients (not at the same time, one after another) something goes
bad and i get: No reply from OnOff server 0
the same happens if I try to use the "Serial Client" in parallel to Clinet1
sc = SimpleOnOffClient()
device.model_add(sc)
sc.publish_set(0, 0)
sc.set(True)
