Hellou, I'm developing firware which is modification of light switch example. I have build in communication protocol, and when i receive coomand to remove nodes promisioned to client , I need remove all nodes from client list, and start promisioning from address 0x100.
I use this function:
void need_reset()
extern volatile bool reset_device ;
static volatile uint8_t num_of_dev = 0;
volatile uint8_t z = 0;
if((get_timer_value(RESET_TIMER)==0))
if(reset_device == true)
reset_device = false;
num_of_dev = m_configured_devices;
nrf_mesh_disable();
access_clear();
for(z = 0; z <= num_of_dev;z++)
m_configured_devices = z;
dsm_address_publish_remove(m_server_handles[m_configured_devices]);
dsm_devkey_delete(m_devkey_handles[m_configured_devices]);
provisioner_wait_for_unprov(UNPROV_START_ADDRESS + 0);
SEGGER_RTT_printf(DEBUG_WINDOW, "\nGO TO RESET_DEVICE");
sd_nvic_SystemReset();
After after receive command device go to reset, and program start, promisiong continue from last idexed device not from 0x100.
Can you help me, how i remove nodes list and data which are saved to client by primisiong the nodes.
Thanks
