Is it possible to fool the system (via software) to perform a USB connect/disconnect as if it was physically connected and disconnected?
Look at the nrf_usbd_pullup_disable and nrf_usbd_pullup_enable functions. If you disable the pull-up, the host will see this as a disconnect.
Thanks for your reply, however, it does not seem to do the trick.
There seems to be an issue with the USBD as follows:
- Create a file
- Modify it (write some date to it)
- Connect the USB
- I am able to see the file on the USB drive
- Disconnect the USB
* at this point everything is file as fatfs_init() works fine and I can log more data to the file
However:
- Connect the USB
- Copy (Drag/Drop) the file from the USB drive
- fatfs_init() fails and I no longer can access the file; unless I physically connect/disconnect the USB again.
My intention is in failed times to mimic a USB connect/disconnect without the user's knowledge.
The pullup enable/disable should disconnect the device from the PC's perspective. Can you verify this happens?
I suppose on the microcontroller, you'll need to manually generate a disconnect event after disabling the pullup.
I ended up using this suggestion and it solved the issue. Thanks.
Hi.
I had the almost the same issue. After any access to the files via the USB, the file system was demolished after internal flash access.
I added additional logs to the SDK in QSPI module and it has shown me, that QSPI uninit function (block_dev_qspi_uninit), called after unplugging the USB, was busy (return with NRF_ERROR_BUSY).
I add this code at the beggining of block_dev_qspi_uninit:
if ((p_work->state != NRF_BLOCK_DEV_QSPI_STATE_IDLE))
wait_for_idle(p_qspi_dev);
It fixed the problem.
Best regards
Artur
