I want to implement UART service which can act as central and peripheral at at time.
I am using nrf52832 board and sdk 15.
I tried to implement it by changing the services in "ble_app_hrs_rscs_relay" ,i.e by replacing the "hrs" with "nus" and "hrs_c" with nus_c".
After compiling i am getting the following errors.
.\_build\nrf52832_xxaa.axf: Error: L6200E: Symbol m_nrf_log_ble_nus_logs_data_const multiply defined (by ble_nus_c.o and ble_nus.o).
.\_build\nrf52832_xxaa.axf: Error: L6200E: Symbol m_nrf_log_ble_nus_logs_data_dynamic multiply defined (by ble_nus_c.o and ble_nus.o).
.\_build\nrf52832_xxaa.axf: Error: L6200E: Symbol UARTE0_UART0_IRQHandler multiply defined (by nrfx_uart.o and nrfx_prs.o).
/** * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA * * All rights reserved. * * Redistribution and use in source and binary forms, with or without modification, * are permitted provided that the following conditions are met: * * 1. Redistributions of source code must retain the above copyright notice, this * list of conditions and the following disclaimer. * * 2. Redistributions in binary form, except as embedded into a Nordic * Semiconductor ASA integrated circuit in a product or a software update for * such product, must reproduce the above copyright notice, this list of * conditions and the following disclaimer in the documentation and/or other * materials provided with the distribution. * * 3. Neither the name of Nordic Semiconductor ASA nor the names of its * contributors may be used to endorse or promote products derived from this * software without specific prior written permission. * * 4. This software, with or without modification, must only be used with a * Nordic Semiconductor ASA integrated circuit. * * 5. Any software provided in binary form under this license must not be reverse * engineered, decompiled, modified and/or disassembled. * * THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES * OF MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE * DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE * GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ /** * @brief BLE Heart Rate and Running speed Relay application main file. * * @detail This application demonstrates a simple "Relay". * Meaning we pass on the values that we receive. By combining a collector part on * one end and a sensor part on the other, we show that the s130 can function * simultaneously as a central and a peripheral device. * * In the figure below, the sensor ble_app_hrs connects and interacts with the relay * in the same manner it would connect to a heart rate collector. In this case, the Relay * application acts as a central. * * On the other side, a collector (such as Master Control panel or ble_app_hrs_c) connects * and interacts with the relay the same manner it would connect to a heart rate sensor peripheral. * * Led layout: * LED 1: Central side is scanning LED 2: Central side is connected to a peripheral * LED 3: Peripheral side is advertising LED 4: Peripheral side is connected to a central * * @note While testing, be careful that the Sensor and Collector are actually connecting to the Relay, * and not directly to each other! * * Peripheral Relay Central * +--------+ +-----------|----------+ +-----------+ * | Heart | | Heart | Heart | | | * | Rate | -----> | Rate -|-> Rate | -----> | Collector | * | Sensor | | Collector | Sensor | | | * +--------+ +-----------| and | +-----------+ * | Running | Running| * +--------+ | Speed -|-> Speed | * | Running|------> | Collector | Sensor | * | Speed | +-----------|----------+ * | Sensor | * +--------+ */ #include <stdint.h> #include <stdio.h> #include <string.h> #include "nordic_common.h" #include "app_error.h"//add #include "nrf.h"//add #include "nrf_sdh.h"//add #include "app_uart.h"//add #include "nrf_sdh.h" #include "nrf_sdh_soc.h" #include "nrf_sdh_ble.h" #include "boards.h"//add #include "peer_manager.h" #include "app_timer.h" #include "bsp_btn_ble.h" #include "ble.h" #include "ble_advdata.h" #include "ble_advertising.h" #include "ble_conn_params.h" #include "ble_db_discovery.h" #include "app_util.h"//add #include "ble_nus.h"//add #include "ble_hci.h"//add #include "ble_nus_c.h"//add #include "app_util_platform.h" #include "ble_conn_params.h"//add #include "ble_conn_state.h"//add #include "nrf_fstorage.h" #include "fds.h" #include "nrf_ble_gatt.h" #include "nrf_ble_qwr.h" #include "nrf_pwr_mgmt.h" #if defined (UART_PRESENT) #include "nrf_uart.h" #endif #if defined (UARTE_PRESENT) #include "nrf_uarte.h" #endif #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" #define PERIPHERAL_ADVERTISING_LED BSP_BOARD_LED_2 #define PERIPHERAL_CONNECTED_LED BSP_BOARD_LED_3 #define CENTRAL_SCANNING_LED BSP_BOARD_LED_0 #define CENTRAL_CONNECTED_LED BSP_BOARD_LED_1 #define DEVICE_NAME "Nordic_UART" /**< Name of device. Will be included in the advertising data. */ #define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */ #define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */ #define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms). This value corresponds to 187.5 ms. */ #define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */ #define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */ #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */ #define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */ #define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */ #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */ #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */ #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */ #define SEC_PARAM_BOND 1 /**< Perform bonding. */ #define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */ #define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */ #define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */ #define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */ #define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */ #define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size in octets. */ #define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size in octets. */ #define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */ #define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 millisecond. */ #define SCAN_DURATION 0x0000 /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning will continue until it is explicitly disabled. */ #define MIN_CONNECTION_INTERVAL (uint16_t) MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines minimum connection interval in milliseconds. */ #define MAX_CONNECTION_INTERVAL (uint16_t) MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Determines maximum connection interval in milliseconds. */ #define SLAVE_LATENCY 0 /**< Determines slave latency in terms of connection events. */ #define SUPERVISION_TIMEOUT (uint16_t) MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 milliseconds. */ /**@brief Priority of the application BLE event handler. * @note You shouldn't need to modify this value. */ #define APP_BLE_OBSERVER_PRIO 3 static ble_nus_t m_nus; /**< Heart rate service instance. */ //static ble_rscs_t m_rscs; /**< Running speed and cadence service instance. */ static ble_nus_c_t m_ble_nus_c; /**< Heart rate service client instance. */ //static ble_rscs_c_t m_rscs_c; /**< Running speed and cadence service client instance. */ //for peripheral BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */ NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/ BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */ static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */ static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */ static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */ { {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE} }; //for central BLE_NUS_C_DEF(m_ble_nus_c); BLE_DB_DISCOVERY_DEF(m_db_disc); static uint16_t m_conn_handle_nus_c = BLE_CONN_HANDLE_INVALID; /**< Connection handle for the nus central application */ /**@brief names which the central applications will scan for, and which will be advertised by the peripherals. * if these are set to empty strings, the UUIDs defined below will be used */ static char const m_target_periph_name[] = ""; /**@brief Connection parameters requested for connection. */ static ble_gap_conn_params_t const m_connection_param = { (uint16_t)MIN_CONNECTION_INTERVAL, // Minimum connection (uint16_t)MAX_CONNECTION_INTERVAL, // Maximum connection (uint16_t)SLAVE_LATENCY, // Slave latency (uint16_t)SUPERVISION_TIMEOUT // Supervision time-out }; /**@brief Parameters used when scanning. */ static ble_gap_scan_params_t const m_scan_params = { .extended = 1, .active = 1, .interval = SCAN_INTERVAL, .window = SCAN_WINDOW, .timeout = SCAN_DURATION, .scan_phys = BLE_GAP_PHY_1MBPS, .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL, }; static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_EXTENDED_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */ /**@brief NUS uuid. */ static ble_uuid_t const m_nus_uuid = { .uuid = BLE_UUID_NUS_SERVICE, .type = NUS_SERVICE_UUID_TYPE }; /**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */ static ble_data_t m_scan_buffer = { m_scan_buffer_data, BLE_GAP_SCAN_BUFFER_EXTENDED_MIN }; /**@brief Function to handle asserts in the SoftDevice. * * @details This function will be called in case of an assert in the SoftDevice. * * @warning This handler is an example only and does not fit a final product. You need to analyze * how your product is supposed to react in case of Assert. * @warning On assert from the SoftDevice, the system can only recover on reset. * * @param[in] line_num Line number of the failing ASSERT call. * @param[in] p_file_name File name of the failing ASSERT call. */ void assert_nrf_callback(uint16_t line_num, const uint8_t * p_file_name) { app_error_handler(0xDEADBEEF, line_num, p_file_name); } /**@brief Function for initiating scanning. */ static void scan_start(void) { ret_code_t ret; ret = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer); APP_ERROR_CHECK(ret); ret = bsp_indication_set(BSP_INDICATE_SCANNING); APP_ERROR_CHECK(ret); } /**@brief Function for initiating advertising and scanning. */ static void adv_scan_start(void) { ret_code_t err_code; //check if there are no flash operations in progress if (!nrf_fstorage_is_busy(NULL)) { // Start scanning for peripherals and initiate connection to devices which // advertise Heart Rate or Running speed and cadence UUIDs. scan_start(); // Turn on the LED to signal scanning. bsp_board_led_on(CENTRAL_SCANNING_LED); // Start advertising. err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST); APP_ERROR_CHECK(err_code); } } /**@brief Function for handling database discovery events. * * @details This function is callback function to handle events from the database discovery module. * Depending on the UUIDs that are discovered, this function should forward the events * to their respective services. * * @param[in] p_event Pointer to the database discovery event. */ static void db_disc_handler(ble_db_discovery_evt_t * p_evt) { ble_nus_on_db_disc_evt(&m_ble_nus_c, p_evt); } /**@brief Function for handling app_uart events. * * @details This function will receive a single character from the app_uart module and append it to * a string. The string will be be sent over BLE when the last character received was a * 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length. */ /**@snippet [Handling the data received over UART] */ void uart_event_handle(app_uart_evt_t * p_event) { static uint8_t data_array[BLE_NUS_MAX_DATA_LEN]; static uint8_t index = 0; uint32_t err_code; switch (p_event->evt_type) { case APP_UART_DATA_READY: UNUSED_VARIABLE(app_uart_get(&data_array[index])); index++; if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len))) { NRF_LOG_DEBUG("Ready to send data over BLE NUS"); NRF_LOG_HEXDUMP_DEBUG(data_array, index); do { uint16_t length = (uint16_t)index; err_code = ble_nus_data_send(&m_nus, data_array, &length, m_conn_handle); if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) && (err_code != NRF_ERROR_NOT_FOUND) ) { APP_ERROR_CHECK(err_code); } } while (err_code == NRF_ERROR_BUSY); index = 0; } break; case APP_UART_COMMUNICATION_ERROR: APP_ERROR_HANDLER(p_event->data.error_communication); break; case APP_UART_FIFO_ERROR: APP_ERROR_HANDLER(p_event->data.error_code); break; default: break; } } /**@snippet [Handling the data received over UART] */ /**@brief Function for handling characters received by the Nordic UART Service. * * @details This function takes a list of characters of length data_len and prints the characters out on UART. * If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender. */ static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len) { ret_code_t ret_val; NRF_LOG_DEBUG("Receiving data."); NRF_LOG_HEXDUMP_DEBUG(p_data, data_len); for (uint32_t i = 0; i < data_len; i++) { do { ret_val = app_uart_put(p_data[i]); if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY)) { NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i); APP_ERROR_CHECK(ret_val); } } while (ret_val == NRF_ERROR_BUSY); } if (p_data[data_len-1] == '\r') { while (app_uart_put('\n') == NRF_ERROR_BUSY); } // if (ECHOBACK_BLE_UART_DATA) // { // // Send data back to peripheral. // do // { // ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len); // if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY)) // { // NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val); // APP_ERROR_CHECK(ret_val); // } // } while (ret_val == NRF_ERROR_BUSY); // } } /**@brief Callback handling NUS Client events. * * @details This function is called to notify the application of NUS client events. * * @param[in] p_ble_nus_c NUS Client Handle. This identifies the NUS client * @param[in] p_ble_nus_evt Pointer to the NUS Client event. */ /**@snippet [Handling events from the ble_nus_c module] */ static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt) { ret_code_t err_code; switch (p_ble_nus_evt->evt_type) { case BLE_NUS_C_EVT_DISCOVERY_COMPLETE: NRF_LOG_INFO("Discovery complete."); err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles); APP_ERROR_CHECK(err_code); err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c); APP_ERROR_CHECK(err_code); NRF_LOG_INFO("Connected to device with Nordic UART Service."); break; case BLE_NUS_C_EVT_NUS_TX_EVT: ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len); break; case BLE_NUS_C_EVT_DISCONNECTED: NRF_LOG_INFO("Disconnected."); scan_start(); break; } } /**@snippet [Handling events from the ble_nus_c module] */ /**@brief Function for putting the chip into sleep mode. * * @note This function will not return. */ static void sleep_mode_enter(void) { uint32_t err_code = bsp_indication_set(BSP_INDICATE_IDLE); APP_ERROR_CHECK(err_code); // Prepare wakeup buttons. err_code = bsp_btn_ble_sleep_mode_prepare(); APP_ERROR_CHECK(err_code); // Go to system-off mode (this function will not return; wakeup will cause a reset). err_code = sd_power_system_off(); APP_ERROR_CHECK(err_code); } /**@brief Function for handling the advertising report BLE event. * * @param[in] p_adv_report Advertising report from the SoftDevice. */ static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report) { ret_code_t err_code; if (ble_advdata_uuid_find(p_adv_report->data.p_data, p_adv_report->data.len, &m_nus_uuid)) { err_code = sd_ble_gap_connect(&p_adv_report->peer_addr, &m_scan_params, &m_connection_param, APP_BLE_CONN_CFG_TAG); if (err_code == NRF_SUCCESS) { // scan is automatically stopped by the connect err_code = bsp_indication_set(BSP_INDICATE_IDLE); APP_ERROR_CHECK(err_code); NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x", p_adv_report->peer_addr.addr[0], p_adv_report->peer_addr.addr[1], p_adv_report->peer_addr.addr[2], p_adv_report->peer_addr.addr[3], p_adv_report->peer_addr.addr[4], p_adv_report->peer_addr.addr[5] ); } } else { err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer); APP_ERROR_CHECK(err_code); } } /**@brief Function for assigning new connection handle to available instance of QWR module. * * @param[in] conn_handle New connection handle. */ static void multi_qwr_conn_handle_assign(uint16_t conn_handle) { for (uint32_t i = 0; i < NRF_SDH_BLE_TOTAL_LINK_COUNT; i++) { if (m_qwr.conn_handle == BLE_CONN_HANDLE_INVALID) { ret_code_t err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, conn_handle); APP_ERROR_CHECK(err_code); break; } } } /**@brief Function for handling BLE events from central applications. * * @details This function parses scanning reports and initiates a connection to peripherals when a * target UUID is found. It updates the status of LEDs used to report central applications * activity. * * @param[in] p_ble_evt Bluetooth stack event. */ static void on_ble_central_evt(ble_evt_t const * p_ble_evt) { ret_code_t err_code; ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt; switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_ADV_REPORT: on_adv_report(&p_gap_evt->params.adv_report); break; // BLE_GAP_EVT_ADV_REPORT case BLE_GAP_EVT_CONNECTED: NRF_LOG_INFO("Connected to target"); err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL); APP_ERROR_CHECK(err_code); err_code = bsp_indication_set(BSP_INDICATE_CONNECTED); APP_ERROR_CHECK(err_code); // start discovery of services. The NUS Client waits for a discovery result err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle); APP_ERROR_CHECK(err_code); break; case BLE_GAP_EVT_TIMEOUT: if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN) { NRF_LOG_INFO("Scan timed out."); scan_start(); } else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN) { NRF_LOG_INFO("Connection Request timed out."); } break; case BLE_GAP_EVT_SEC_PARAMS_REQUEST: // Pairing not supported err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL); APP_ERROR_CHECK(err_code); break; case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST: // Accepting parameters requested by peer. err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle, &p_gap_evt->params.conn_param_update_request.conn_params); APP_ERROR_CHECK(err_code); break; case BLE_GAP_EVT_PHY_UPDATE_REQUEST: { NRF_LOG_DEBUG("PHY update request."); ble_gap_phys_t const phys = { .rx_phys = BLE_GAP_PHY_AUTO, .tx_phys = BLE_GAP_PHY_AUTO, }; err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys); APP_ERROR_CHECK(err_code); } break; case BLE_GATTC_EVT_TIMEOUT: // Disconnect on GATT Client timeout event. NRF_LOG_DEBUG("GATT Client Timeout."); err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; case BLE_GATTS_EVT_TIMEOUT: // Disconnect on GATT Server timeout event. NRF_LOG_DEBUG("GATT Server Timeout."); err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; default: break; } } /**@brief Function for handling BLE events from peripheral applications. * @details Updates the status LEDs used to report the activity of the peripheral applications. * * @param[in] p_ble_evt Bluetooth stack event. */ static void on_ble_peripheral_evt(ble_evt_t const * p_ble_evt) { ret_code_t err_code; // ret_code_t err_code; // ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt; switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_CONNECTED: NRF_LOG_INFO("Connected"); err_code = bsp_indication_set(BSP_INDICATE_CONNECTED); APP_ERROR_CHECK(err_code); m_conn_handle = p_ble_evt->evt.gap_evt.conn_handle; err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, m_conn_handle); APP_ERROR_CHECK(err_code); break; case BLE_GAP_EVT_DISCONNECTED: NRF_LOG_INFO("Disconnected"); // LED indication will be changed when advertising starts. m_conn_handle = BLE_CONN_HANDLE_INVALID; break; case BLE_GAP_EVT_PHY_UPDATE_REQUEST: { NRF_LOG_DEBUG("PHY update request."); ble_gap_phys_t const phys = { .rx_phys = BLE_GAP_PHY_AUTO, .tx_phys = BLE_GAP_PHY_AUTO, }; err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys); APP_ERROR_CHECK(err_code); } break; case BLE_GAP_EVT_SEC_PARAMS_REQUEST: // Pairing not supported err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL); APP_ERROR_CHECK(err_code); break; case BLE_GATTS_EVT_SYS_ATTR_MISSING: // No system attributes have been stored. err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0, 0); APP_ERROR_CHECK(err_code); break; case BLE_GATTC_EVT_TIMEOUT: // Disconnect on GATT Client timeout event. err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; case BLE_GATTS_EVT_TIMEOUT: // Disconnect on GATT Server timeout event. err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; default: // No implementation needed. break; } } /**@brief Function for checking if a bluetooth stack event is an advertising timeout. * * @param[in] p_ble_evt Bluetooth stack event. */ static bool ble_evt_is_advertising_timeout(ble_evt_t const * p_ble_evt) { return (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_SET_TERMINATED); } /**@brief Function for handling BLE events. * * @param[in] p_ble_evt Bluetooth stack event. * @param[in] p_context Unused. */ static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context) { uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle; uint16_t role = ble_conn_state_role(conn_handle); // Based on the role this device plays in the connection, dispatch to the right handler. if (role == BLE_GAP_ROLE_PERIPH || ble_evt_is_advertising_timeout(p_ble_evt)) { ble_nus_on_ble_evt(p_ble_evt, &m_nus); //ble_rscs_on_ble_evt(p_ble_evt, &m_rscs); on_ble_peripheral_evt(p_ble_evt); } else if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT)) { ble_nus_c_on_ble_evt(p_ble_evt, &m_ble_nus_c); //ble_rscs_c_on_ble_evt(p_ble_evt, &m_rscs_c); on_ble_central_evt(p_ble_evt); } } /**@brief Function for initializing the BLE stack. * * @details Initializes the SoftDevice and the BLE event interrupts. */ static void ble_stack_init(void) { ret_code_t err_code; err_code = nrf_sdh_enable_request(); APP_ERROR_CHECK(err_code); // Configure the BLE stack using the default settings. // Fetch the start address of the application RAM. uint32_t ram_start = 0; err_code = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start); APP_ERROR_CHECK(err_code); // Enable BLE stack. err_code = nrf_sdh_ble_enable(&ram_start); APP_ERROR_CHECK(err_code); // Register a handler for BLE events. NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_handler, NULL); } /**@brief Function for handling events from the BSP module. * * @param[in] event Event generated by button press. */ void bsp_event_handler(bsp_event_t event) { ret_code_t err_code; switch (event) { case BSP_EVENT_SLEEP: nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF); break; case BSP_EVENT_DISCONNECT: err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); if (err_code != NRF_ERROR_INVALID_STATE) { APP_ERROR_CHECK(err_code); } break; default: break; } } /**@brief Function for initializing the UART module. */ /**@snippet [UART Initialization] */ static void uart_init(void) { uint32_t err_code; app_uart_comm_params_t const comm_params = { .rx_pin_no = RX_PIN_NUMBER, .tx_pin_no = TX_PIN_NUMBER, .rts_pin_no = RTS_PIN_NUMBER, .cts_pin_no = CTS_PIN_NUMBER, .flow_control = APP_UART_FLOW_CONTROL_DISABLED, .use_parity = false, #if defined (UART_PRESENT) .baud_rate = NRF_UART_BAUDRATE_115200 #else .baud_rate = NRF_UARTE_BAUDRATE_115200 #endif }; APP_UART_FIFO_INIT(&comm_params, UART_RX_BUF_SIZE, UART_TX_BUF_SIZE, uart_event_handle, APP_IRQ_PRIORITY_LOWEST, err_code); APP_ERROR_CHECK(err_code); } /**@snippet [UART Initialization] */ /**@brief Heart rate collector initialization. */ static void nus_c_init(void) { ret_code_t err_code; ble_nus_c_init_t nus_c_init_obj; nus_c_init_obj.evt_handler = ble_nus_c_evt_handler; err_code = ble_nus_c_init(&m_ble_nus_c, &nus_c_init_obj); APP_ERROR_CHECK(err_code); } /**@brief Function for initializing buttons and leds. * * @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to * wake the application up. */ static void buttons_leds_init(void) { ret_code_t err_code; bsp_event_t startup_event; err_code = bsp_init(BSP_INIT_LEDS,bsp_event_handler); APP_ERROR_CHECK(err_code); err_code = bsp_btn_ble_init(NULL, &startup_event); APP_ERROR_CHECK(err_code); //*p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA); } /** * @brief Database discovery initialization. */ static void db_discovery_init(void) { ret_code_t err_code = ble_db_discovery_init(db_disc_handler); APP_ERROR_CHECK(err_code); } /**@brief Function for the GAP initialization. * * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the * device including the device name, appearance, and the preferred connection parameters. */ static void gap_params_init(void) { ret_code_t err_code; ble_gap_conn_params_t gap_conn_params; ble_gap_conn_sec_mode_t sec_mode; BLE_GAP_CONN_SEC_MODE_SET_OPEN(&sec_mode); err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME)); APP_ERROR_CHECK(err_code); memset(&gap_conn_params, 0, sizeof(gap_conn_params)); gap_conn_params.min_conn_interval = MIN_CONNECTION_INTERVAL; gap_conn_params.max_conn_interval = MAX_CONNECTION_INTERVAL; gap_conn_params.slave_latency = SLAVE_LATENCY; gap_conn_params.conn_sup_timeout = SUPERVISION_TIMEOUT; err_code = sd_ble_gap_ppcp_set(&gap_conn_params); APP_ERROR_CHECK(err_code); } /**@brief Function for handling the data from the Nordic UART Service. * * @details This function will process the data received from the Nordic UART BLE Service and send * it to the UART module. * * @param[in] p_evt Nordic UART Service event. */ /**@snippet [Handling the data received over BLE] */ static void nus_data_handler(ble_nus_evt_t * p_evt) { if (p_evt->type == BLE_NUS_EVT_RX_DATA) { uint32_t err_code; NRF_LOG_DEBUG("Received data from BLE NUS. Writing data on UART."); NRF_LOG_HEXDUMP_DEBUG(p_evt->params.rx_data.p_data, p_evt->params.rx_data.length); for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++) { do { err_code = app_uart_put(p_evt->params.rx_data.p_data[i]); if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY)) { NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code); APP_ERROR_CHECK(err_code); } } while (err_code == NRF_ERROR_BUSY); } if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r') { while (app_uart_put('\n') == NRF_ERROR_BUSY); } } } /**@snippet [Handling the data received over BLE] */ /**@brief Function for handling Queued Write Module errors. * * @details A pointer to this function will be passed to each service which may need to inform the * application about an error. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void nrf_qwr_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /**@brief Function for initializing services that will be used by the application. * * @details Initialize the Heart Rate, Battery and Device Information services. */ static void services_init(void) { uint32_t err_code; ble_nus_init_t nus_init; nrf_ble_qwr_init_t qwr_init = {0}; // Initialize Queued Write Module. qwr_init.error_handler = nrf_qwr_error_handler; err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init); APP_ERROR_CHECK(err_code); // Initialize NUS. memset(&nus_init, 0, sizeof(nus_init)); nus_init.data_handler = nus_data_handler; err_code = ble_nus_init(&m_nus, &nus_init); APP_ERROR_CHECK(err_code); } /**@brief Function for handling advertising events. * * @param[in] ble_adv_evt Advertising event. */ static void on_adv_evt(ble_adv_evt_t ble_adv_evt) { uint32_t err_code; switch (ble_adv_evt) { case BLE_ADV_EVT_FAST: err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING); APP_ERROR_CHECK(err_code); break; case BLE_ADV_EVT_IDLE: sleep_mode_enter(); break; default: break; } } /**@brief Function for initializing the Advertising functionality. */ static void advertising_init(void) { ret_code_t err_code; ble_advertising_init_t init; memset(&init, 0, sizeof(init)); init.advdata.name_type = BLE_ADVDATA_FULL_NAME; init.advdata.include_appearance = true; init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]); init.advdata.uuids_complete.p_uuids = m_adv_uuids; init.config.ble_adv_fast_enabled = true; init.config.ble_adv_fast_interval = APP_ADV_INTERVAL; init.config.ble_adv_fast_timeout = APP_ADV_DURATION; init.evt_handler = on_adv_evt; err_code = ble_advertising_init(&m_advertising, &init); APP_ERROR_CHECK(err_code); ble_advertising_conn_cfg_tag_set(&m_advertising, APP_BLE_CONN_CFG_TAG); } /**@brief Function for handling errors from the Connection Parameters module. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void conn_params_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /**@brief Function for handling an event from the Connection Parameters Module. * * @details This function will be called for all events in the Connection Parameters Module * which are passed to the application. * * @note All this function does is to disconnect. This could have been done by simply setting * the disconnect_on_fail config parameter, but instead we use the event handler * mechanism to demonstrate its use. * * @param[in] p_evt Event received from the Connection Parameters Module. */ static void on_conn_params_evt(ble_conn_params_evt_t * p_evt) { uint32_t err_code; if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) { err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE); APP_ERROR_CHECK(err_code); } } /**@brief Function for initializing the Connection Parameters module. */ static void conn_params_init(void) { ret_code_t err_code; ble_conn_params_init_t cp_init; memset(&cp_init, 0, sizeof(cp_init)); cp_init.p_conn_params = NULL; cp_init.first_conn_params_update_delay = FIRST_CONN_PARAMS_UPDATE_DELAY; cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY; cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT; cp_init.start_on_notify_cccd_handle = BLE_CONN_HANDLE_INVALID; // Start upon connection. cp_init.disconnect_on_fail = true; cp_init.evt_handler = NULL; // Ignore events. cp_init.error_handler = conn_params_error_handler; err_code = ble_conn_params_init(&cp_init); APP_ERROR_CHECK(err_code); } /**@brief Function for handling events from the GATT library. */ void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt) { if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED) { NRF_LOG_INFO("ATT MTU exchange completed."); m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH; NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len); } } /**@brief Function for initializing the GATT module. */ static void gatt_init(void) { ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler); APP_ERROR_CHECK(err_code); err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE); APP_ERROR_CHECK(err_code); } /**@brief Function for initializing logging. */ static void log_init(void) { ret_code_t err_code = NRF_LOG_INIT(NULL); APP_ERROR_CHECK(err_code); NRF_LOG_DEFAULT_BACKENDS_INIT(); } /**@brief Function for initializing power management. */ static void power_management_init(void) { ret_code_t err_code; err_code = nrf_pwr_mgmt_init(); APP_ERROR_CHECK(err_code); } /**@brief Function for handling the idle state (main loop). If there is no pending log operation, then sleep until next the next event occurs. */ static void idle_state_handle(void) { if (NRF_LOG_PROCESS() == false) { nrf_pwr_mgmt_run(); } } /**@brief Function for initializing the timer. */ static void timer_init(void) { ret_code_t err_code = app_timer_init(); APP_ERROR_CHECK(err_code); } /**@brief Function for application main entry. */ int main(void) { uint32_t err_code; // Initialize. log_init(); timer_init(); uart_init();//added buttons_leds_init(); power_management_init(); ble_stack_init(); gap_params_init(); gatt_init(); conn_params_init(); db_discovery_init(); peer_manager_init(); nus_c_init();//added services_init(); advertising_init(); conn_params_init();//added // Start execution. ("uart_c scan is started."); scan_start(); NRF_LOG_INFO("\r\nUART Start!\r\n"); err_code = ble_advertising_start(&m_advertising,BLE_ADV_MODE_FAST); APP_ERROR_CHECK(err_code); //adv_scan_start(); // Enter main loop. for (;;) { idle_state_handle(); } }
The above is my code,could somebody help in this ?
Thanks in advance.
