To implement UART service as a concurrent central and peripheral example!!!!!
 I want to implement UART service which can act as central and peripheral at at time.
 I am using nrf52832 board and sdk 15.
 I tried to implement it by changing the services in  "ble_app_hrs_rscs_relay" ,i.e by replacing the "hrs" with "nus" and  "hrs_c" with nus_c".
 After compiling i am getting the following errors.
   .\_build\nrf52832_xxaa.axf: Error: L6200E: Symbol m_nrf_log_ble_nus_logs_data_const multiply defined (by ble_nus_c.o and ble_nus.o).
  .\_build\nrf52832_xxaa.axf: Error: L6200E: Symbol m_nrf_log_ble_nus_logs_data_dynamic multiply defined (by ble_nus_c.o and ble_nus.o).
  .\_build\nrf52832_xxaa.axf: Error: L6200E: Symbol UARTE0_UART0_IRQHandler multiply defined (by nrfx_uart.o and nrfx_prs.o).
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
 * @brief BLE Heart Rate and Running speed Relay application main file.
 * @detail This application demonstrates a simple "Relay".
 * Meaning we pass on the values that we receive. By combining a collector part on
 * one end and a sensor part on the other, we show that the s130 can function
 * simultaneously as a central and a peripheral device.
 * In the figure below, the sensor ble_app_hrs connects and interacts with the relay
 * in the same manner it would connect to a heart rate collector. In this case, the Relay
 * application acts as a central.
 * On the other side, a collector (such as Master Control panel or ble_app_hrs_c) connects
 * and interacts with the relay the same manner it would connect to a heart rate sensor peripheral.
 * Led layout:
 * LED 1: Central side is scanning       LED 2: Central side is connected to a peripheral
 * LED 3: Peripheral side is advertising LED 4: Peripheral side is connected to a central
 * @note While testing, be careful that the Sensor and Collector are actually connecting to the Relay,
 *       and not directly to each other!
 *    Peripheral                  Relay                    Central
 *    | Heart  |        | Heart     |   Heart  |        |           |
 *    | Rate   | -----> | Rate     -|-> Rate   | -----> | Collector |
 *    | Sensor |        | Collector |   Sensor |        |           |
 *    +--------+        +-----------|   and    |        +-----------+
 *                      | Running   |   Running|
 *    +--------+        | Speed    -|-> Speed  |
 *    | Running|------> | Collector |   Sensor |
 *    | Speed  |        +-----------|----------+
 *    | Sensor |
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "app_error.h"//add
#include "nrf.h"//add
#include "nrf_sdh.h"//add
#include "app_uart.h"//add
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "boards.h"//add
#include "peer_manager.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
#include "app_util.h"//add
#include "ble_nus.h"//add
#include "ble_hci.h"//add
#include "ble_nus_c.h"//add
#include "ble_conn_params.h"//add
#include "ble_conn_state.h"//add
#include "nrf_fstorage.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define PERIPHERAL_ADVERTISING_LED      BSP_BOARD_LED_2
#define PERIPHERAL_CONNECTED_LED        BSP_BOARD_LED_3
#define CENTRAL_SCANNING_LED            BSP_BOARD_LED_0
#define CENTRAL_CONNECTED_LED           BSP_BOARD_LED_1
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms). This value corresponds to 187.5 ms. */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_CONN_CFG_TAG            1    /**< A tag identifying the SoftDevice BLE configuration. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size in octets. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size in octets. */
#define SCAN_INTERVAL                   0x00A0                                      /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW                     0x0050                                      /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION                   0x0000                                      /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning will continue until it is explicitly disabled. */
#define MIN_CONNECTION_INTERVAL         (uint16_t) MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines minimum connection interval in milliseconds. */
#define MAX_CONNECTION_INTERVAL         (uint16_t) MSEC_TO_UNITS(30, UNIT_1_25_MS)  /**< Determines maximum connection interval in milliseconds. */
#define SLAVE_LATENCY                   0                                           /**< Determines slave latency in terms of connection events. */
#define SUPERVISION_TIMEOUT             (uint16_t) MSEC_TO_UNITS(4000, UNIT_10_MS)  /**< Determines supervision time-out in units of 10 milliseconds. */
/**@brief   Priority of the application BLE event handler.
 * @note    You shouldn't need to modify this value.
#define APP_BLE_OBSERVER_PRIO           3
static ble_nus_t m_nus;                                             /**< Heart rate service instance. */
//static ble_rscs_t m_rscs;                                           /**< Running speed and cadence service instance. */
static ble_nus_c_t m_ble_nus_c;                                         /**< Heart rate service client instance. */
//static ble_rscs_c_t m_rscs_c;                                       /**< Running speed and cadence service client instance. */
//for peripheral
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);
NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
//for central
BLE_NUS_C_DEF(m_ble_nus_c);
BLE_DB_DISCOVERY_DEF(m_db_disc);
static uint16_t m_conn_handle_nus_c  = BLE_CONN_HANDLE_INVALID;     /**< Connection handle for the nus central application */
/**@brief names which the central applications will scan for, and which will be advertised by the peripherals.
 *  if these are set to empty strings, the UUIDs defined below will be used
static char const m_target_periph_name[] = "";
/**@brief Connection parameters requested for connection. */
static ble_gap_conn_params_t const m_connection_param =
     (uint16_t)MIN_CONNECTION_INTERVAL,  // Minimum connection
    (uint16_t)MAX_CONNECTION_INTERVAL,  // Maximum connection
    (uint16_t)SLAVE_LATENCY,            // Slave latency
    (uint16_t)SUPERVISION_TIMEOUT       // Supervision time-out
/**@brief Parameters used when scanning. */
static ble_gap_scan_params_t const m_scan_params =
    .extended      = 1,
    .active        = 1,
    .interval      = SCAN_INTERVAL,
    .window        = SCAN_WINDOW,
    .timeout       = SCAN_DURATION,
    .scan_phys     = BLE_GAP_PHY_1MBPS,
    .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_EXTENDED_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
/**@brief NUS uuid. */
static ble_uuid_t const m_nus_uuid =
    .uuid = BLE_UUID_NUS_SERVICE,
    .type = NUS_SERVICE_UUID_TYPE
/**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
static ble_data_t m_scan_buffer =
    m_scan_buffer_data,
/**@brief Function to handle asserts in the SoftDevice.
 * @param[in] line_num     Line number of the failing ASSERT call.
 * @param[in] p_file_name  File name of the failing ASSERT call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for initiating scanning.
static void scan_start(void)
        ret_code_t ret;
    ret = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
   APP_ERROR_CHECK(ret);
    ret = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for initiating advertising and scanning.
static void adv_scan_start(void)
    ret_code_t err_code;
    //check if there are no flash operations in progress
    if (!nrf_fstorage_is_busy(NULL))
        // Start scanning for peripherals and initiate connection to devices which
        // advertise Heart Rate or Running speed and cadence UUIDs.
        scan_start();
        // Turn on the LED to signal scanning.
        bsp_board_led_on(CENTRAL_SCANNING_LED);
        // Start advertising.
        err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling database discovery events.
 * @details This function is callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function should forward the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_nus_on_db_disc_evt(&m_ble_nus_c, p_evt);
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                do
                    if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) &&
                         (err_code != NRF_ERROR_NOT_FOUND) )
                } while (err_code == NRF_ERROR_BUSY);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief Function for handling characters received by the Nordic UART Service.
 * @details This function takes a list of characters of length data_len and prints the characters out on UART.
 *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
        do
            ret_val = app_uart_put(p_data[i]);
            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                APP_ERROR_CHECK(ret_val);
        } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
        while (app_uart_put('\n') == NRF_ERROR_BUSY);
//    if (ECHOBACK_BLE_UART_DATA)
//        // Send data back to peripheral.
//        do
//            ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
//            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
//                NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
//                APP_ERROR_CHECK(ret_val);
//        } while (ret_val == NRF_ERROR_BUSY);
/**@brief Callback handling NUS Client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS Client Handle. This identifies the NUS client
 * @param[in]   p_ble_nus_evt Pointer to the NUS Client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        case BLE_NUS_C_EVT_NUS_TX_EVT:
            ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
        case BLE_NUS_C_EVT_DISCONNECTED:
            NRF_LOG_INFO("Disconnected.");
            scan_start();
    // Prepare wakeup buttons.
/**@brief Function for handling the advertising report BLE event.
 * @param[in] p_adv_report  Advertising report from the SoftDevice.
static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
    if (ble_advdata_uuid_find(p_adv_report->data.p_data, p_adv_report->data.len, &m_nus_uuid))
        err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
                                      &m_scan_params,
                                      &m_connection_param,
                                      APP_BLE_CONN_CFG_TAG);
        if (err_code == NRF_SUCCESS)
            // scan is automatically stopped by the connect
            NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                     p_adv_report->peer_addr.addr[0],
                     p_adv_report->peer_addr.addr[1],
                     p_adv_report->peer_addr.addr[2],
                     p_adv_report->peer_addr.addr[3],
                     p_adv_report->peer_addr.addr[4],
                     p_adv_report->peer_addr.addr[5]
        err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
/**@brief Function for assigning new connection handle to available instance of QWR module.
 * @param[in] conn_handle New connection handle.
static void multi_qwr_conn_handle_assign(uint16_t conn_handle)
    for (uint32_t i = 0; i < NRF_SDH_BLE_TOTAL_LINK_COUNT; i++)
        if (m_qwr.conn_handle == BLE_CONN_HANDLE_INVALID)
            ret_code_t err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, conn_handle);
/**@brief   Function for handling BLE events from central applications.
 * @details This function parses scanning reports and initiates a connection to peripherals when a
 *          target UUID is found. It updates the status of LEDs used to report central applications
 *          activity.
static void on_ble_central_evt(ble_evt_t const * p_ble_evt)
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_ADV_REPORT:
            on_adv_report(&p_gap_evt->params.adv_report);
            break; // BLE_GAP_EVT_ADV_REPORT
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected to target");
            err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
            // start discovery of services. The NUS Client waits for a discovery result
            err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
                NRF_LOG_INFO("Scan timed out.");
                scan_start();
            else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_INFO("Connection Request timed out.");
            // Pairing not supported
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
/**@brief   Function for handling BLE events from peripheral applications.
 * @details Updates the status LEDs used to report the activity of the peripheral applications.
static void on_ble_peripheral_evt(ble_evt_t const * p_ble_evt)
// ret_code_t            err_code;
//    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
        } break;
            // No implementation needed.
/**@brief Function for checking if a bluetooth stack event is an advertising timeout.
 * @param[in] p_ble_evt Bluetooth stack event.
static bool ble_evt_is_advertising_timeout(ble_evt_t const * p_ble_evt)
    return (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_SET_TERMINATED);
    uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    uint16_t role        = ble_conn_state_role(conn_handle);
    // Based on the role this device plays in the connection, dispatch to the right handler.
    if (role == BLE_GAP_ROLE_PERIPH || ble_evt_is_advertising_timeout(p_ble_evt))
        ble_nus_on_ble_evt(p_ble_evt, &m_nus);
        //ble_rscs_on_ble_evt(p_ble_evt, &m_rscs);
        on_ble_peripheral_evt(p_ble_evt);
    else if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT))
        ble_nus_c_on_ble_evt(p_ble_evt, &m_ble_nus_c);
        //ble_rscs_c_on_ble_evt(p_ble_evt, &m_rscs_c);
        on_ble_central_evt(p_ble_evt);
 * @details Initializes the SoftDevice and the BLE event interrupts.
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @param[in] event  Event generated by button press.
    switch (event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
/**@brief Heart rate collector initialization.
static void nus_c_init(void)
    ble_nus_c_init_t nus_c_init_obj;
    nus_c_init_obj.evt_handler = ble_nus_c_evt_handler;
    err_code = ble_nus_c_init(&m_ble_nus_c, &nus_c_init_obj);
 * @param[out] p_erase_bonds  Will be true if the clear bonding button was pressed to
 *                            wake the application up.
static void buttons_leds_init(void)
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS,bsp_event_handler);
    //*p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA);
 * @brief Database discovery initialization.
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    gap_conn_params.min_conn_interval = MIN_CONNECTION_INTERVAL;
    gap_conn_params.max_conn_interval = MAX_CONNECTION_INTERVAL;
    gap_conn_params.conn_sup_timeout  = SUPERVISION_TIMEOUT;
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
    APP_ERROR_HANDLER(nrf_error);
 * @details Initialize the Heart Rate, Battery and Device Information services.
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
        uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
/**@brief Function for handling errors from the Connection Parameters module.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
    cp_init.start_on_notify_cccd_handle    = BLE_CONN_HANDLE_INVALID; // Start upon connection.
    cp_init.disconnect_on_fail             = true;
    cp_init.evt_handler                    = NULL;  // Ignore events.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("ATT MTU exchange completed.");
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
	err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
/**@brief Function for initializing logging.
static void log_init(void)
/**@brief Function for handling the idle state (main loop). If there is no pending log operation,
          then sleep until next the next event occurs.
        nrf_pwr_mgmt_run();
/**@brief Function for initializing the timer.
static void timer_init(void)
/**@brief Function for application main entry.
    uint32_t err_code;
    // Initialize.
    log_init();
    timer_init();
	  uart_init();//added
    buttons_leds_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    conn_params_init();
    db_discovery_init();
    peer_manager_init();
    nus_c_init();//added
    services_init();
    advertising_init();
	 conn_params_init();//added
    // Start execution.
    ("uart_c scan is started.");
     		 scan_start();
     NRF_LOG_INFO("\r\nUART Start!\r\n");
      err_code = ble_advertising_start(&m_advertising,BLE_ADV_MODE_FAST);
			 //adv_scan_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
The above is my code,could somebody help in this ?
Thanks in advance.
