Proper place and exact change to increase the tx power in ble_app_att_mtu_throughput example(nRF5_SDK_15.0.0)
Hardware used: 2 nRF52480 DK boards
I am running nRF5_SDK_15.0.0_a53641a\examples\ble_central_and_peripheral\experimental\ble_app_att_mtu_throughput example, I want to increase the tx power of the both sender and receiver boards.
I am adding the below change to increase the tx power of the nRF52840 boards to run the att_mtu example. But tx power value is not changing.
I checked the tx power value by keeping the debug breakpoint in the adv_data.c file(ble_advdata_encode()). Please help me regarding the changes need to be added, so that i can increase tx power and test the att_mtu example by keeping the 2 boards in long range.
ble_advdata_encode(): // Here everytime it is showing tx power level to zero.
// Encode TX power level.
if (p_advdata->p_tx_power_level != NULL)
err_code = tx_power_level_encode(*p_advdata->p_tx_power_level,
p_encoded_data,
p_len,
max_size);
VERIFY_SUCCESS(err_code);
// Initialize.
log_init();
cli_init();
leds_init();
timer_init();
counter_init();
buttons_init();
power_management_init();
ble_stack_init();
gap_params_init();
+ sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN,m_conn_handle,8);
+ sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV,m_conn_handle,8);
gatt_init();
advertising_data_set();
  • Hi Nordic team,
    Please reply ASAP on the query mentioned in my previous comment.
  • Hi Prasanna,
    if you look at advertising_data_set() in main.c you'll see that the ble_advdata_t adv_data struct only populates the .name_type, .flags and .include_apperance fields, i.e.
      ble_advdata_t const adv_data =
            .name_type          = BLE_ADVDATA_FULL_NAME,
            .flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE,
            .include_appearance = false,
    hence (p_advdata->p_tx_power_level != NULL) evaluates to false in ble_advdata_encode. If you want to include the tx power in the advertisment packet you need to populate this in the adv_data struct yourself.
    You're also calling sd_ble_gap_tx_power_set without checking the return codes, please implement this. You're also passing the connection handle(m_conn_handle) when you're trying to set the advertisment role TX power, which is incorrect, you need to pass the advertisement handle(m_adv_handle) as stated in the documentation.
    Best regards
    Bjørn
  • Hi Bjorn,
    1. Followed the steps mentioned by you and changed the code accordingly for setting the tx power to 8dBM. Did i properly set in source code, Please help to check my source code file.
    2. To perform long range throughput testing with tx power 8dBM, I am trying to set the PHY channel to CODED in the ble_app_att_mtu_throughput  example source code.When i changed the PHY channel to CODED and flashed through IAR embedded workbench and pressed switch 3 on board 1(tester role board is ready to perform run command).But on board2, after pressing switch 4, It is throwing fatal error.
     * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /**@cond To Make Doxygen skip documentation generation for this file.
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include <stdio.h>
    #include "amt.h"
    #include "counter.h"
    #include "sdk_config.h"
    #include "nrf.h"
    #include "ble.h"
    #include "ble_gatt.h"
    #include "ble_hci.h"
    #include "nordic_common.h"
    #include "nrf_gpio.h"
    #include "bsp_btn_ble.h"
    #include "ble_advdata.h"
    #include "ble_srv_common.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "app_error.h"
    #include "nrf_cli.h"
    #include "nrf_cli_rtt.h"
    #include "nrf_cli_uart.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DATA_LENGTH_DEFAULT             27                                              /**< The stack default data length. */
    #define DATA_LENGTH_MAX                 251                                             /**< The stack maximum data length. */
    #define CONN_INTERVAL_DEFAULT           (uint16_t)(MSEC_TO_UNITS(7.5, UNIT_1_25_MS))    /**< Default connection interval used at connection establishment by central side. */
    #define CONN_INTERVAL_MIN               (uint16_t)(MSEC_TO_UNITS(7.5, UNIT_1_25_MS))    /**< Minimum acceptable connection interval, in 1.25 ms units. */
    #define CONN_INTERVAL_MAX               (uint16_t)(MSEC_TO_UNITS(500, UNIT_1_25_MS))    /**< Maximum acceptable connection interval, in 1.25 ms units. */
    #define CONN_SUP_TIMEOUT                (uint16_t)(MSEC_TO_UNITS(4000,  UNIT_10_MS))    /**< Connection supervisory timeout (4 seconds). */
    #define SLAVE_LATENCY                   0                                               /**< Slave latency. */
    #define SCAN_ADV_LED                    BSP_BOARD_LED_0
    #define READY_LED                       BSP_BOARD_LED_1
    #define PROGRESS_LED                    BSP_BOARD_LED_2
    #define DONE_LED                        BSP_BOARD_LED_3
    #define BOARD_TESTER_BUTTON             BSP_BUTTON_2                                    /**< Button to press at beginning of the test to indicate that this board is connected to the PC and takes input from it via the UART. */
    #define BOARD_DUMMY_BUTTON              BSP_BUTTON_3                                    /**< Button to press at beginning of the test to indicate that this board is standalone (automatic behavior). */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                             /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define APP_BLE_CONN_CFG_TAG            1                                               /**< A tag that refers to the BLE stack configuration. */
    #define APP_BLE_OBSERVER_PRIO           3                                               /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                           /**< Advertising handle used to identify an advertising set. */
    static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                            /**< Buffer for storing an encoded advertising set. */
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = NULL,
            .len    = 0
    static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
    /**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
    static ble_data_t m_scan_buffer =
        m_scan_buffer_data,
    typedef enum
        NOT_SELECTED = 0x00,
        BOARD_TESTER,
        BOARD_DUMMY,
    } board_role_t;
    typedef struct
        uint16_t        att_mtu;                    /**< GATT ATT MTU, in bytes. */
        uint16_t        conn_interval;              /**< Connection interval expressed in units of 1.25 ms. */
        ble_gap_phys_t  phys;                       /**< Preferred PHYs. */
        uint8_t         data_len;                   /**< Data length. */
        bool            conn_evt_len_ext_enabled;   /**< Connection event length extension status. */
    } test_params_t;
    NRF_BLE_GATT_DEF(m_gatt);                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                         /**< Context for the Queued Write module.*/
    BLE_DB_DISCOVERY_DEF(m_ble_db_discovery);       /**< DB discovery module instance. */
    static nrf_ble_amtc_t     m_amtc;
    static nrf_ble_amts_t     m_amts;
    NRF_SDH_BLE_OBSERVER(m_amtc_ble_obs, BLE_AMTC_BLE_OBSERVER_PRIO, nrf_ble_amtc_on_ble_evt, &m_amtc);
    NRF_SDH_BLE_OBSERVER(m_amts_ble_obs, BLE_AMTS_BLE_OBSERVER_PRIO, nrf_ble_amts_on_ble_evt, &m_amts);
    NRF_CLI_UART_DEF(cli_uart, 0, 64, 16);
    NRF_CLI_RTT_DEF(cli_rtt);
    NRF_CLI_DEF(m_cli_uart, "throughput example:~$ ", &cli_uart.transport, '\r', 4);
    NRF_CLI_DEF(m_cli_rtt,  "throughput example:~$ ", &cli_rtt.transport,  '\n', 4);
    static board_role_t volatile m_board_role  = NOT_SELECTED;
    static bool volatile m_run_test;
    static bool volatile m_notif_enabled;
    static bool volatile m_mtu_exchanged;
    static bool volatile m_data_length_updated;
    static bool volatile m_phy_updated;
    static bool volatile m_conn_interval_configured;
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current BLE connection .*/
    static uint8_t m_gap_role     = BLE_GAP_ROLE_INVALID;       /**< BLE role for this connection, see @ref BLE_GAP_ROLES */
    // Name to use for advertising and connection.
    static char const m_target_periph_name[] = DEVICE_NAME;
    // Test parameters.
    // Settings like ATT MTU size are set only once on the dummy board.
    // Make sure that defaults are sensible.
    static test_params_t m_test_params =
        .att_mtu                  = NRF_SDH_BLE_GATT_MAX_MTU_SIZE,
        .data_len                 = NRF_SDH_BLE_GAP_DATA_LENGTH,
        .conn_interval            = CONN_INTERVAL_DEFAULT,
        .conn_evt_len_ext_enabled = true,
        // Only symmetric PHYs are supported.
    #if defined(S140)
        .phys.tx_phys             = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED,
        .phys.rx_phys             = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED,
    #else
        .phys.tx_phys             = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS,
        .phys.rx_phys             = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS,
    // Scan parameters requested for scanning and connection.
    static ble_gap_scan_params_t const m_scan_param =
        .active        = 0x00,
        .interval      = SCAN_INTERVAL,
        .window        = SCAN_WINDOW,
        .timeout       = 0x0000, // No timeout.
        //.scan_phys     = BLE_GAP_PHY_1MBPS,
        .scan_phys     = BLE_GAP_PHY_CODED,
        .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
    // Connection parameters requested for connection.
    static ble_gap_conn_params_t m_conn_param =
        .min_conn_interval = CONN_INTERVAL_MIN,   // Minimum connection interval.
        .max_conn_interval = CONN_INTERVAL_MAX,   // Maximum connection interval.
        .slave_latency     = SLAVE_LATENCY,       // Slave latency.
        .conn_sup_timeout  = CONN_SUP_TIMEOUT     // Supervisory timeout.
    static void test_terminate(void);
    void data_len_set(uint8_t value);
    char const * phy_str(ble_gap_phys_t phys)
        static char const * str[] =
            "1 Mbps",
            "2 Mbps",
            "Coded",
            "Unknown"
        switch (phys.tx_phys)
            case BLE_GAP_PHY_1MBPS:
                return str[0];
            case BLE_GAP_PHY_2MBPS:
            case BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS:
            case BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED:
                return str[1];
            case BLE_GAP_PHY_CODED:
                return str[2];
                return str[3];
    static void instructions_print(void)
        NRF_LOG_INFO("Type 'config' to change the configuration parameters.");
        NRF_LOG_INFO("You can use the TAB key to autocomplete your input.");
        NRF_LOG_INFO("Type 'run' when you are ready to run the test.");
    /**@brief Function for handling BLE_GAP_ADV_REPORT events.
     * Search for a peer with matching device name.
     * If found, stop advertising and send a connection request to the peer.
    static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
        ret_code_t err_code;
        if (!ble_advdata_name_find(p_adv_report->data.p_data,
                                   p_adv_report->data.len,
                                   m_target_periph_name))
            err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
            return;
        NRF_LOG_INFO("Device \"%s\" found, sending a connection request.",
                     (uint32_t) m_target_periph_name);
        // Stop advertising.
        (void) sd_ble_gap_adv_stop(m_adv_handle);
        // Initiate connection.
        m_conn_param.min_conn_interval = CONN_INTERVAL_DEFAULT;
        m_conn_param.max_conn_interval = CONN_INTERVAL_DEFAULT;
        err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
                                      &m_scan_param,
                                      &m_conn_param,
                                      APP_BLE_CONN_CFG_TAG);
        if (err_code != NRF_SUCCESS)
            NRF_LOG_ERROR("sd_ble_gap_connect() failed: 0x%x.", err_code);
    /**@brief Function for handling BLE_GAP_EVT_CONNECTED events.
     * Save the connection handle and GAP role, then discover the peer DB.
    static void on_ble_gap_evt_connected(ble_gap_evt_t const * p_gap_evt)
        m_conn_handle = p_gap_evt->conn_handle;
        m_gap_role    = p_gap_evt->params.connected.role;
        if (m_gap_role == BLE_GAP_ROLE_PERIPH)
            NRF_LOG_INFO("Connected as a peripheral.");
        else if (m_gap_role == BLE_GAP_ROLE_CENTRAL)
            NRF_LOG_INFO("Connected as a central.");
        // Stop scanning and advertising.
        (void) sd_ble_gap_scan_stop();
        bsp_board_leds_off();
        // Assign connection handle to the Queued Write module.
        NRF_LOG_INFO("Discovering GATT database...");
        err_code  = ble_db_discovery_start(&m_ble_db_discovery, p_gap_evt->conn_handle);
            NRF_LOG_INFO("Sending PHY Update, %s.", phy_str(m_test_params.phys));
            err_code = sd_ble_gap_phy_update(p_gap_evt->conn_handle, &m_test_params.phys);
    /**@brief Function for handling BLE_GAP_EVT_DISCONNECTED events.
     * Unset the connection handle and terminate the test.
    static void on_ble_gap_evt_disconnected(ble_gap_evt_t const * p_gap_evt)
        NRF_LOG_DEBUG("Disconnected: reason 0x%x.", p_gap_evt->params.disconnected.reason);
        if (m_run_test)
            NRF_LOG_WARNING("GAP disconnection event received while test was running.")
        test_terminate();
    /**@brief Function for handling BLE Stack events.
     * @param[in] p_ble_evt  Bluetooth stack event.
        uint32_t              err_code;
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            case BLE_GAP_EVT_ADV_REPORT:
                on_adv_report(&p_gap_evt->params.adv_report);
            case BLE_GAP_EVT_CONNECTED:
                on_ble_gap_evt_connected(p_gap_evt);
                on_ble_gap_evt_disconnected(p_gap_evt);
            case BLE_GAP_EVT_CONN_PARAM_UPDATE:
                m_conn_interval_configured = true;
                NRF_LOG_INFO("Connection interval updated: 0x%x, 0x%x.",
                    p_gap_evt->params.conn_param_update.conn_params.min_conn_interval,
                    p_gap_evt->params.conn_param_update.conn_params.max_conn_interval);
            } break;
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accept parameters requested by the peer.
                ble_gap_conn_params_t params;
                params = p_gap_evt->params.conn_param_update_request.conn_params;
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle, &params);
                NRF_LOG_INFO("Connection interval updated (upon request): 0x%x, 0x%x.",
                    p_gap_evt->params.conn_param_update_request.conn_params.min_conn_interval,
                    p_gap_evt->params.conn_param_update_request.conn_params.max_conn_interval);
            } break;
                err_code = sd_ble_gatts_sys_attr_set(p_gap_evt->conn_handle, NULL, 0, 0);
            } break;
            case BLE_GATTC_EVT_TIMEOUT: // Fallthrough.
            case BLE_GATTS_EVT_TIMEOUT:
                NRF_LOG_DEBUG("GATT timeout, disconnecting.");
                err_code = sd_ble_gap_disconnect(m_conn_handle,
            } break;
            case BLE_GAP_EVT_PHY_UPDATE:
                ble_gap_evt_phy_update_t const * p_phy_evt = &p_ble_evt->evt.gap_evt.params.phy_update;
                if (p_phy_evt->status == BLE_HCI_STATUS_CODE_LMP_ERROR_TRANSACTION_COLLISION)
                    // Ignore LL collisions.
                    NRF_LOG_DEBUG("LL transaction collision during PHY update.");
                m_phy_updated = true;
                ble_gap_phys_t phys = {0};
                phys.tx_phys = p_phy_evt->tx_phy;
                phys.rx_phys = p_phy_evt->rx_phy;
                NRF_LOG_INFO("PHY update %s. PHY set to %s.",
                             (p_phy_evt->status == BLE_HCI_STATUS_CODE_SUCCESS) ?
                             "accepted" : "rejected",
                             phy_str(phys));
            } break;
            } break;
                // No implementation needed.
    /**@brief AMT server event handler. */
    static void amts_evt_handler(nrf_ble_amts_evt_t evt)
        switch (evt.evt_type)
            case NRF_BLE_AMTS_EVT_NOTIF_ENABLED:
                NRF_LOG_INFO("Notifications enabled.");
                bsp_board_led_on(READY_LED);
                m_notif_enabled = true;
                if (m_board_role != BOARD_TESTER)
                    return;
                if (m_test_params.conn_interval != CONN_INTERVAL_DEFAULT)
                    NRF_LOG_DEBUG("Updating connection parameters..");
                    m_conn_param.min_conn_interval = m_test_params.conn_interval;
                    m_conn_param.max_conn_interval = m_test_params.conn_interval;
                    err_code = sd_ble_gap_conn_param_update(m_conn_handle, &m_conn_param);
                        NRF_LOG_ERROR("sd_ble_gap_conn_param_update() failed: 0x%x.", err_code);
            } break;
            case NRF_BLE_AMTS_EVT_NOTIF_DISABLED:
                NRF_LOG_INFO("Notifications disabled.");
                bsp_board_led_off(READY_LED);
            } break;
            case NRF_BLE_AMTS_EVT_TRANSFER_1KB:
                NRF_LOG_INFO("Sent %u KBytes", (evt.bytes_transfered_cnt / 1024));
                bsp_board_led_invert(PROGRESS_LED);
            } break;
            case NRF_BLE_AMTS_EVT_TRANSFER_FINISHED:
                counter_stop();
                bsp_board_led_off(PROGRESS_LED);
                bsp_board_led_on(DONE_LED);
                uint32_t time_ms      = counter_get();
                uint32_t bit_count    = (evt.bytes_transfered_cnt * 8);
                float throughput_kbps = ((bit_count / (time_ms / 1000.f)) / 1000.f);
                NRF_LOG_INFO("Done.");
                NRF_LOG_INFO("=============================");
                NRF_LOG_INFO("Time: %u.%.2u seconds elapsed.", (time_ms / 1000), (time_ms % 1000));
                NRF_LOG_INFO("Throughput: " NRF_LOG_FLOAT_MARKER " Kbps.",
                             NRF_LOG_FLOAT(throughput_kbps));
                NRF_LOG_INFO("Sent %u bytes of ATT payload.", evt.bytes_transfered_cnt);
                NRF_LOG_INFO("Retrieving amount of bytes received from peer...");
                err_code = nrf_ble_amtc_rcb_read(&m_amtc);
                    NRF_LOG_ERROR("nrf_ble_amtc_rcb_read() failed: 0x%x.", err_code);
                    test_terminate();
            } break;
    /**@brief AMT Client event handler.  */
    static void amtc_evt_handler(nrf_ble_amtc_t * p_amt_c, nrf_ble_amtc_evt_t * p_evt)
        switch (p_evt->evt_type)
            case NRF_BLE_AMT_C_EVT_DISCOVERY_COMPLETE:
                NRF_LOG_INFO("AMT service discovered at peer.");
                err_code = nrf_ble_amtc_handles_assign(p_amt_c,
                                                       p_evt->conn_handle,
                                                       &p_evt->params.peer_db);
                // Enable notifications.
                err_code = nrf_ble_amtc_notif_enable(p_amt_c);
            } break;
            case NRF_BLE_AMT_C_EVT_NOTIFICATION:
                static uint32_t bytes_cnt  = 0;
                static uint32_t kbytes_cnt = 0;
                if (p_evt->params.hvx.bytes_sent == 0)
                    bytes_cnt  = 0;
                    kbytes_cnt = 0;
                bytes_cnt += p_evt->params.hvx.notif_len;
                if (bytes_cnt > 1024)
                    bytes_cnt -= 1024;
                    kbytes_cnt++;
                    NRF_LOG_INFO("Received %u kbytes", kbytes_cnt);
                    nrf_ble_amts_rbc_set(&m_amts, p_evt->params.hvx.bytes_rcvd);
                if (p_evt->params.hvx.bytes_rcvd >= AMT_BYTE_TRANSFER_CNT)
                    bytes_cnt  = 0;
                    kbytes_cnt = 0;
                    NRF_LOG_INFO("Transfer complete, received %u bytes of ATT payload.",
            } break;
            case NRF_BLE_AMT_C_EVT_RBC_READ_RSP:
                NRF_LOG_INFO("Peer received %u bytes of ATT payload.", (p_evt->params.rcv_bytes_cnt));
                test_terminate();
            } break;
    /**@brief Function for handling Database Discovery events.
     * @details This function is a callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function should forward the events
     *          to their respective service instances.
     * @param[in] p_evt  Pointer to the database discovery event.
    static void db_disc_evt_handler(ble_db_discovery_evt_t * p_evt)
        nrf_ble_amtc_on_db_disc_evt(&m_amtc, p_evt);
    /**@brief Function for handling events from the GATT library. */
    static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        switch (p_evt->evt_id)
            case NRF_BLE_GATT_EVT_ATT_MTU_UPDATED:
                m_mtu_exchanged = true;
                NRF_LOG_INFO("ATT MTU exchange completed. MTU set to %u bytes.",
                             p_evt->params.att_mtu_effective);
            } break;
            case NRF_BLE_GATT_EVT_DATA_LENGTH_UPDATED:
                m_data_length_updated = true;
                NRF_LOG_INFO("Data length updated to %u bytes.", p_evt->params.data_length);
            } break;
        nrf_ble_amts_on_gatt_evt(&m_amts, p_evt);
    /**@brief Function for setting up advertising data. */
    static void advertising_data_set(void)
        ret_code_t ret;
        static int8_t tx_power = 8;
        ble_gap_adv_params_t const adv_params =
            .properties    =
              //.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED,
              .type = BLE_GAP_ADV_TYPE_EXTENDED_CONNECTABLE_NONSCANNABLE_UNDIRECTED,
            .p_peer_addr   = NULL,
            .filter_policy = BLE_GAP_ADV_FP_ANY,
            .interval      = ADV_INTERVAL,
            .duration      = 0,
            .primary_phy   = BLE_GAP_PHY_CODED, // Must be changed to connect in long range. (BLE_GAP_PHY_CODED)
            .secondary_phy = BLE_GAP_PHY_CODED,
            .p_tx_power_level   = &tx_power,
        ret = ble_advdata_encode(&adv_data, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        APP_ERROR_CHECK(ret);
        ret = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
        //ret = sd_ble_gap_adv_set_configure(&m_adv_handle, NULL, &adv_params);
        ret = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV,m_adv_handle,tx_power);
    /**@brief Function for starting advertising. */
        NRF_LOG_INFO("Starting advertising.");
        bsp_board_led_on(SCAN_ADV_LED);
        ret_code_t err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    /**@brief Function to start scanning. */
    static void scan_start(void)
        NRF_LOG_INFO("Starting scan.");
        ret_code_t err_code = sd_ble_gap_scan_start(&m_scan_param, &m_scan_buffer);
    static void log_init(void)
        ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timer_init(void)
    /**@brief Function for enabling button input.
    static void buttons_enable(void)
        ret_code_t err_code = app_button_enable();
    /**@brief Function for disabling button input. */
    static void buttons_disable(void)
        ret_code_t err_code = app_button_disable();
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_evt_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case BOARD_TESTER_BUTTON:
                NRF_LOG_INFO("This board will act as tester.");
                instructions_print();
                m_board_role = BOARD_TESTER;
            } break;
            case BOARD_DUMMY_BUTTON:
                NRF_LOG_INFO("This board will act as responder.");
                m_board_role = BOARD_DUMMY;
                // Set the data length to the maximum if necessary, so that this board will
                // accept whatever value requested by the tester.
                uint8_t dl = 0;
                (void) nrf_ble_gatt_data_length_get(&m_gatt, BLE_CONN_HANDLE_INVALID, &dl);
                if (dl != DATA_LENGTH_MAX)
                    data_len_set(DATA_LENGTH_MAX);
                advertising_start();
                scan_start();
            } break;
        buttons_disable();
    /**@brief Function for initializing the button library.
    static void buttons_init(void)
       // The array must be static because a pointer to it will be saved in the button library.
        static app_button_cfg_t buttons[] =
            {BOARD_TESTER_BUTTON, false, BUTTON_PULL, button_evt_handler},
            {BOARD_DUMMY_BUTTON,  false, BUTTON_PULL, button_evt_handler}
        ret_code_t err_code = app_button_init(buttons, ARRAY_SIZE(buttons), BUTTON_DETECTION_DELAY);
    static void client_init(void)
        ret_code_t err_code = ble_db_discovery_init(db_disc_evt_handler);
        err_code = nrf_ble_amtc_init(&m_amtc, amtc_evt_handler);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for initializing the Queued Write module.
    static void qwr_init(void)
        nrf_ble_qwr_init_t qwr_init_obj = {0};
        qwr_init_obj.error_handler = nrf_qwr_error_handler;
        err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
    static void server_init(void)
        qwr_init();
        nrf_ble_amts_init(&m_amts, amts_evt_handler);
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for initializing GAP parameters.
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name and the preferred connection parameters.
                                              (uint8_t const *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        err_code = sd_ble_gap_ppcp_set(&m_conn_param);
    /**@brief Function for initializing the GATT library. */
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        ret_code_t ret;
        ret = nrf_pwr_mgmt_init();
    void preferred_phy_set(ble_gap_phys_t * p_phy)
        memcpy(&m_test_params.phys, p_phy, sizeof(ble_gap_phys_t));
    void gatt_mtu_set(uint16_t att_mtu)
        m_test_params.att_mtu = att_mtu;
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, att_mtu);
        err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, att_mtu);
    void connection_interval_set(uint16_t value)
        m_test_params.conn_interval = value;
    void conn_evt_len_ext_set(bool status)
        ble_opt_t  opt;
        memset(&opt, 0x00, sizeof(opt));
        opt.common_opt.conn_evt_ext.enable = status ? 1 : 0;
        err_code = sd_ble_opt_set(BLE_COMMON_OPT_CONN_EVT_EXT, &opt);
        m_test_params.conn_evt_len_ext_enabled = status;
        err_code = nrf_ble_gatt_data_length_set(&m_gatt, BLE_CONN_HANDLE_INVALID, value);
        m_test_params.data_len = value;
    bool is_tester_board(void)
        return (m_board_role == BOARD_TESTER);
    void current_config_print(nrf_cli_t const * p_cli)
        char const * role = (m_board_role == BOARD_TESTER) ? "tester" :
                            (m_board_role == BOARD_DUMMY)  ? "dummy" : "not selected";
        nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "==== Current test configuration ====\r\n");
                        "Board role:\t\t%s\r\n"
                        "ATT MTU size:\t\t%d\r\n"
                        "Data length:\t\t%d\r\n"
                        "Connection interval:\t%d units\r\n"
                        "Connection length ext:\t%s\r\n"
                        "Preferred PHY:\t\t%s\r\n",
                        role,
                        m_test_params.att_mtu,
                        m_test_params.data_len,
                        m_test_params.conn_interval,
                        m_test_params.conn_evt_len_ext_enabled ? "on" : "off",
        nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "GAP event length:\t%d\r\n",
                        NRF_SDH_BLE_GAP_EVENT_LENGTH);
    void test_begin(void)
        NRF_LOG_INFO("Preparing the test.");
        NRF_LOG_FLUSH();
    #if defined(S132)
        // PHY does not need to be updated for s132
        switch (m_gap_role)
                // If no connection was established, the role won't be either.
                // In this case, start both advertising and scanning.
                scan_start();
            case BLE_GAP_ROLE_PERIPH:
                m_test_params.phys.tx_phys = BLE_GAP_PHY_2MBPS;
            case BLE_GAP_ROLE_CENTRAL:
                scan_start();
    static void test_run(void)
        counter_start();
        nrf_ble_amts_notif_spam(&m_amts);
    static bool is_test_ready()
        return (   (m_board_role == BOARD_TESTER)
                && m_conn_interval_configured
                && m_notif_enabled
                && m_mtu_exchanged
                && (m_data_length_updated || m_test_params.data_len == DATA_LENGTH_DEFAULT)
                && m_phy_updated
                && !m_run_test);
    void cli_process(void)
        nrf_cli_process(&m_cli_uart);
     * @details Handle any pending operation(s), then sleep until the next event occurs.
        cli_process();
        if (is_test_ready())
            NRF_LOG_INFO("Test started");
            m_run_test = true;
            test_run();
            nrf_pwr_mgmt_run();
        m_run_test                 = false;
        m_notif_enabled            = false;
        m_mtu_exchanged            = false;
        m_data_length_updated      = false;
        m_phy_updated              = false;
        m_conn_interval_configured = false;
        if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
            NRF_LOG_INFO("Disconnecting...");
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
                NRF_LOG_ERROR("sd_ble_gap_disconnect() failed: 0x%0x.", err_code);
            if (m_board_role == BOARD_DUMMY)
                    scan_start();
    void cli_init(void)
        if (CoreDebug->DHCSR & CoreDebug_DHCSR_C_DEBUGEN_Msk)
            ret_code_t err_code = nrf_cli_init(&m_cli_rtt, NULL, true, true, NRF_LOG_SEVERITY_INFO);
        nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
        uart_config.pseltxd = TX_PIN_NUMBER;
        uart_config.pselrxd = RX_PIN_NUMBER;
        uart_config.hwfc    = NRF_UART_HWFC_DISABLED;
        ret_code_t err_code = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
    void cli_start(void)
        ret_code_t err_code =  nrf_cli_start(&m_cli_uart);
        // Initialize.
        log_init();
        cli_init();
        leds_init();
        timer_init();
        counter_init();
        buttons_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        server_init();
        client_init();
        gatt_mtu_set(m_test_params.att_mtu);
        conn_evt_len_ext_set(m_test_params.conn_evt_len_ext_enabled);
        // Start execution.
        cli_start();
        buttons_enable();
        NRF_LOG_INFO("ATT MTU example started.");
        NRF_LOG_INFO("Press button 3 on the board connected to the PC.");
        NRF_LOG_INFO("Press button 4 on other board.");
        // Enter main loop.
        for (;;)
            idle_state_handle();
    Not sure,What is going wrong in the code ? Attached the main file source code(nRF5_SDK_15.0.0_a53641a/ble_app_att_mtu_throughput  example). Please help to check the source code.
    3. Please let me know exactly what changes need to perform for testing the long range by using ble_app_att_mtu_throughput example.
  • Hi Prasanna,
    Q1: The sd_ble_gap_tx_power_set() calls looks good now.
    Q2: I recommend that you use the modified ble_app_att_mtu_throughput example from our Testing Long Range (Coded PHY) with Nordic solution (It Simply Works) blog post. It provides you with a step by step guide on how to set up the attached project files for testing. The code is available at the end of the blog post, but I will include the link below as well.
    long range test.zip
    Q3: See the modified ble_app_att_mtu_throughput example from our Testing Long Range (Coded PHY) with Nordic solution (It Simply Works) blog post.
    Best regards
    Bjørn
