I am trouble with adding DFU function to BLE_UART on nRF52832. I have just followed those step in this link Adding DFU to your App. But when i compile and fash to my device, it does not advertising anymore. Here is my main.c code. Please help me to check it out
/* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
* The information contained herein is property of Nordic Semiconductor ASA.
* Terms and conditions of usage are described in detail in NORDIC
* SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
* Licensees are granted free, non-transferable use of the information. NO
* WARRANTY of ANY KIND is provided. This heading must NOT be removed from
* the file.
/** @file
* @defgroup ble_sdk_uart_over_ble_main main.c
* @ingroup ble_sdk_app_nus_eval
* @brief UART over BLE application main file.
* This file contains the source code for a sample application that uses the Nordic UART service.
* This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "softdevice_handler.h"
#include "app_timer.h"
#include "device_manager.h"
#include "app_button.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#ifdef BLE_DFU_APP_SUPPORT
#include "ble_dfu.h"
#include "dfu_app_handler.h"
#endif // BLE_DFU_APP_SUPPORT
#define IS_SRVC_CHANGED_CHARACT_PRESENT 1 /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
#define CENTRAL_LINK_COUNT 0 /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
#define PERIPHERAL_LINK_COUNT 1 /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
#define DEVICE_NAME "DKM" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS 180 /**< The advertising timeout (in units of seconds). */
#define APP_TIMER_PRESCALER 0 /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_OP_QUEUE_SIZE 4 /**< Size of timer operation queues. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define DFU_REV_MAJOR 0x00 /** DFU Major revision number to be exposed. */
#define DFU_REV_MINOR 0x01 /** DFU Minor revision number to be exposed. */
#define DFU_REVISION ((DFU_REV_MAJOR << 8) | DFU_REV_MINOR) /** DFU Revision number to be exposed. Combined of major and minor versions. */
#define APP_SERVICE_HANDLE_START 0x000C /**< Handle of first application specific service when when service changed characteristic is present. */
#define BLE_HANDLE_MAX 0xFFFF /**< Max handle value in BLE. */
STATIC_ASSERT(IS_SRVC_CHANGED_CHARACT_PRESENT); /** When having DFU Service support in application the Service Changed Characteristic should always be present. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
static ble_nus_t m_nus; /**< Structure to identify the Nordic UART Service. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}}; /**< Universally unique service identifier. */
static dm_application_instance_t m_app_handle; /**< Application identifier allocated by device manager */
static ble_dfu_t m_dfus; /**< Structure used to identify the DFU service. */
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_nus Nordic UART Service structure.
* @param[in] p_data Data to be send to UART module.
* @param[in] length Length of the data.
/**@snippet [Handling the data received over BLE] */
static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
for (uint32_t i = 0; i < length; i++)
while(app_uart_put(p_data[i]) != NRF_SUCCESS);
while(app_uart_put('\n') != NRF_SUCCESS);
/**@brief Function for stopping advertising.
static void advertising_stop(void)
uint32_t err_code;
err_code = sd_ble_gap_adv_stop();
/**@brief Function for loading application-specific context after establishing a secure connection.
* @details This function will load the application context and check if the ATT table is marked as
* changed. If the ATT table is marked as changed, a Service Changed Indication
* is sent to the peer if the Service Changed CCCD is set to indicate.
* @param[in] p_handle The Device Manager handle that identifies the connection for which the context
* should be loaded.
static void app_context_load(dm_handle_t const * p_handle)
uint32_t err_code;
static uint32_t context_data;
dm_application_context_t context;
context.len = sizeof(context_data);
context.p_data = (uint8_t *)&context_data;
err_code = dm_application_context_get(p_handle, &context);
if (err_code == NRF_SUCCESS)
// Send Service Changed Indication if ATT table has changed.
if ((context_data & (DFU_APP_ATT_TABLE_CHANGED << DFU_APP_ATT_TABLE_POS)) != 0)
err_code = sd_ble_gatts_service_changed(m_conn_handle, APP_SERVICE_HANDLE_START, BLE_HANDLE_MAX);
if ((err_code != NRF_SUCCESS) &&
(err_code != BLE_ERROR_INVALID_CONN_HANDLE) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != BLE_ERROR_NO_TX_PACKETS) &&
(err_code != NRF_ERROR_BUSY) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING))
APP_ERROR_HANDLER(err_code);
err_code = dm_application_context_delete(p_handle);
else if (err_code == DM_NO_APP_CONTEXT)
// No context available. Ignore.
/** @snippet [DFU BLE Reset prepare] */
/**@brief Function for preparing for system reset.
* @details This function implements @ref dfu_app_reset_prepare_t. It will be called by
* @ref dfu_app_handler.c before entering the bootloader/DFU.
* This allows the current running application to shut down gracefully.
static void reset_prepare(void)
uint32_t err_code;
if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
// Disconnect from peer.
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
// If not connected, the device will be advertising. Hence stop the advertising.
advertising_stop();
err_code = ble_conn_params_stop();
nrf_delay_ms(500);
uint32_t err_code;
ble_nus_init_t nus_init;
/** @snippet [DFU BLE Service initialization] */
ble_dfu_init_t dfus_init;
// Initialize the Device Firmware Update Service.
memset(&dfus_init, 0, sizeof(dfus_init));
dfus_init.evt_handler = dfu_app_on_dfu_evt;
dfus_init.error_handler = NULL;
dfus_init.revision = DFU_REVISION;
err_code = ble_dfu_init(&m_dfus, &dfus_init);
dfu_app_reset_prepare_set(reset_prepare);
dfu_app_dm_appl_instance_set(m_app_handle);
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
/**@brief Function for handling errors from the Connection Parameters module.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
/**@brief Function for the application's SoftDevice event handler.
* @param[in] p_ble_evt SoftDevice event.
static void on_ble_evt(ble_evt_t * p_ble_evt)
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
// Pairing not supported
// No implementation needed.
/**@brief Function for dispatching a SoftDevice event to all modules with a SoftDevice
* event handler.
* @details This function is called from the SoftDevice event interrupt handler after a
* SoftDevice event has been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
ble_conn_params_on_ble_evt(p_ble_evt);
ble_nus_on_ble_evt(&m_nus, p_ble_evt);
/** @snippet [Propagating BLE Stack events to DFU Service] */
ble_dfu_on_ble_evt(&m_dfus, p_ble_evt);
ble_advertising_on_ble_evt(p_ble_evt);
bsp_btn_ble_on_ble_evt(p_ble_evt);
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
uint32_t err_code;
nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
// Initialize SoftDevice.
SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
ble_enable_params_t ble_enable_params;
err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
PERIPHERAL_LINK_COUNT,
&ble_enable_params);
ble_enable_params.gatts_enable_params.service_changed = 1;
//Check the ram settings against the used number of links
CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
// Enable BLE stack.
err_code = softdevice_enable(&ble_enable_params);
// Subscribe for BLE events.
err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
case BSP_EVENT_WHITELIST_OFF:
err_code = ble_advertising_restart_without_whitelist();
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' i.e '\n' (hex 0x0D) or if the string has reached a length of
* @ref NUS_MAX_DATA_LENGTH.
/**@snippet [Handling the data received over UART] */
static uint8_t index = 0;
uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
err_code = ble_nus_string_send(&m_nus, data_array, index);
index = 0;
case APP_UART_FIFO_ERROR:
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
uint32_t err_code;
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
APP_UART_FLOW_CONTROL_ENABLED,
false,
UART_BAUDRATE_BAUDRATE_Baud115200
APP_UART_FIFO_INIT( &comm_params,
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOW,
err_code);
/**@brief Function for handling the Device Manager events.
* @param[in] p_evt Data associated to the device manager event.
static uint32_t device_manager_evt_handler(dm_handle_t const * p_handle,
dm_event_t const * p_event,
ret_code_t event_result)
APP_ERROR_CHECK(event_result);
if (p_event->event_id == DM_EVT_LINK_SECURED)
app_context_load(p_handle);
return NRF_SUCCESS;
/**@brief Function for the Device Manager initialization.
* @param[in] erase_bonds Indicates whether bonding information should be cleared from
* persistent storage during initialization of the Device Manager.
static void device_manager_init(bool erase_bonds)
uint32_t err_code;
dm_init_param_t init_param = {.clear_persistent_data = erase_bonds};
dm_application_param_t register_param;
// Initialize persistent storage module.
err_code = pstorage_init();
err_code = dm_init(&init_param);
memset(®ister_param.sec_param, 0, sizeof(ble_gap_sec_params_t));
register_param.sec_param.bond = SEC_PARAM_BOND;
register_param.sec_param.mitm = SEC_PARAM_MITM;
register_param.sec_param.lesc = SEC_PARAM_LESC;
register_param.sec_param.keypress = SEC_PARAM_KEYPRESS;
register_param.sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
register_param.sec_param.oob = SEC_PARAM_OOB;
register_param.sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
register_param.sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
register_param.evt_handler = device_manager_evt_handler;
register_param.service_type = DM_PROTOCOL_CNTXT_GATT_SRVR_ID;
err_code = dm_register(&m_app_handle, ®ister_param);
uint32_t err_code;
ble_advdata_t advdata;
ble_advdata_t scanrsp;
// Build advertising data struct to pass into @ref ble_advertising_init.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_FULL_NAME;
advdata.include_appearance = false;
advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
memset(&scanrsp, 0, sizeof(scanrsp));
scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
scanrsp.uuids_complete.p_uuids = m_adv_uuids;
ble_adv_modes_config_t options = {0};
options.ble_adv_fast_enabled = BLE_ADV_FAST_ENABLED;
options.ble_adv_fast_interval = APP_ADV_INTERVAL;
options.ble_adv_fast_timeout = APP_ADV_TIMEOUT_IN_SECONDS;
err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
bsp_event_handler);
/**@brief Function for placing the application in low power state while waiting for events.
static void power_manage(void)
uint32_t err_code = sd_app_evt_wait();
/**@brief Application main function.
uint32_t err_code;
bool erase_bonds;
// Initialize.
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
uart_init();
ble_stack_init();
device_manager_init(erase_bonds);
gap_params_init();
advertising_init();
services_init();
conn_params_init();
printf("\r\nUART Start!\r\n");
err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
// Enter main loop.
for (;;)
power_manage();
