How Can I Create Own timers_init
Hi folks,
I try change blinky code for nRF52810 SoC. I must create own timer. I dont know app_timer example help for me?! I want to do when power on leds on 2 seconds. I dont want to use nrf_delay_ms(). My codes are under the topic.
thanks...
standart blinky code block
void lfclk_request()
    uint32_t err_code = nrf_drv_clock_init();
void timer_a_handler(void * p_context)
    nrf_drv_gpiote_out_set(Kontrol_1);
void create_timers()
    uint32_t err_code;
    // Create timers
    err_code = app_timer_create(&m_led_a_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                timer_a_handler);
void start_timer()
    uint32_t err_code;
    // Start timer
    err_code = app_timer_start(m_led_a_timer_id,
                                APP_TIMER_TICKS(1000),
                                NULL);
/**@brief Function for application main entry.
    // Initialize.
    log_init();
    leds_init();
    timers_init();
    buttons_init();
    power_management_init();
    lfclk_request();  --->
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    create_timers();  --->
    start_timer();    --->
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    sistem_baslangici();
    // Start execution.
    NRF_LOG_INFO("Blinky example started.");
    advertising_start();
    // Enter main loop.
    for (;;)
         sutun();
       // idle_state_handle();
sistem_baslangici()
some #define and header files
void sistem_baslangici(void)
    nrf_gpio_pin_clear(Kontrol_1);
    nrf_gpio_pin_set(Kontrol_2);
    nrf_gpio_pin_clear(Motor_GERI);
    nrf_delay_ms(2000);
    nrf_gpio_pin_set(Kontrol_1);
    nrf_gpio_pin_clear(Kontrol_2);
    nrf_delay_ms(2000);
  • I think you want to turn an LED off for 2 seconds, then off for 2 seconds.
    You can use a repeated timer of 4 seconds to turn the LED on. Then start a oneshot timer to turn it off after 2 seconds.
    You can also use a repeated timer of 2 seconds and toggle the LED. I think this option is better due to using less resources.
    Option 1:
    #define LED_ON_INTERVAL 2000
    #define LED_OFF_INTERVAL    2000
    #define MY_LED   BSP_BOARD_LED_1
    static uint32_t led_idx = MY_LED;
    static void timers_init(void)
        ret_code_t err_code = app_timer_init();           //Initializes the library
        err_code = app_timer_create(&led_on_timer_id,
                                    led_on_timeout_handler);
        err_code = app_timer_create(&led_off_timer_id,
                                    APP_TIMER_MODE_SINGLE_SHOT,
                                    led_off_timeout_handler);
    void led_on_timeout_handler(void *led_idx)
        uint32_t *p_led_idx = led_idx;
        bsp_board_led_on(*p_led_idx);         //Or however you want to turn it on
        ret_code_t err_code = app_timer_start(led_off_timer_id, LED_OFF_INTERVAL, led_idx);    //oneshot timer to turn off LED
    void led_off_timeout_handler(void *ptr_led)
      uint32_t *p_led_idx = ptr_led;
      bsp_board_led_off(*p_led_idx);
    int main (void)
      ret_code_t err_code;
      err_code = app_timer_start(led_on_timer_id, LED_ON_INTERVAL, led_idx);
    Option 2:
    #define LED_TOGGLE_INTERVAL 2000
        err_code = app_timer_create(&led_toggle_timer_id,
                                    led_toggle_timeout_handler);
    void led_toggle_timeout_handler(void *led_idx)
        uint8_t *p_led_idx = led_idx;
        bsp_board_led_invert(*p_led_idx);         //Or however you want to turn it on/off
    int main (void)
      err_code = app_timer_start(led_toggle_timer_id, LED_TOGGLE_INTERVAL, &led_idx);
    Notice that I have used another method to turn LEDs on/off, but you can use your method too. These examples are based on my own code for nRF52840 with SDK15.0.0
    Also note that I have not compiled these examples.
  • I solved problem like this.
        uint32_t err_code;
        // Create timers
                                    timer_a_handler);
    void start_timer()
        uint32_t err_code;
        // Start timer
                                    APP_TIMER_TICKS(2),
                                    NULL);
        // Initialize.
        log_init();
        leds_init();
        timers_init();
        buttons_init();
        lfclk_request();
        create_timers();
        start_timer();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        // Enter main loop.
        for (;;)
        //    basla();
             sutun();
