I am willing to migrate sdk 14.2 code to sdk 15.0 code. Do you mind me to ask a crypto micro-ecc question, please? Thanks.
In sdk 14.2, the micro-ecc part definition is like this:
// <i> The micro-ecc library provides a software implementation of ECC cryptography for nRF5 Series devices.
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC
#define NRF_CRYPTO_BACKEND_MICRO_ECC 1
// <q> NRF_CRYPTO_BACKEND_MICRO_ECC_SHA256 - Enable SHA256
// <i> Enable SHA256 cryptographic hash functionality.
// <i> Enable this setting if you need SHA256 support, for example to verify signatures.
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_SHA256
#define NRF_CRYPTO_BACKEND_MICRO_ECC_SHA256 1
// <q> NRF_CRYPTO_BACKEND_MICRO_ECC_RNG - Enable random number generator
// <i> Enable random number generation.
// <i> Enable this setting if you need to generate cryptographic keys.
// <i> This setting requires the RNG peripheral driver to be present.
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_RNG
#define NRF_CRYPTO_BACKEND_MICRO_ECC_RNG 1
// </e>
However, in sdk 15, it looks like this:
// <e> NRF_CRYPTO_BACKEND_MICRO_ECC_ENABLED - Enable the micro-ecc backend.
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_ENABLED
#define NRF_CRYPTO_BACKEND_MICRO_ECC_ENABLED 0
// <q> NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP192R1_ENABLED - Enable secp192r1 (NIST 192-bit) curve
// <i> Enable this setting if you need secp192r1 (NIST 192-bit) support using micro-ecc
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP192R1_ENABLED
#define NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP192R1_ENABLED 1
// <q> NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP224R1_ENABLED - Enable secp224r1 (NIST 224-bit) curve
// <i> Enable this setting if you need secp224r1 (NIST 224-bit) support using micro-ecc
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP224R1_ENABLED
#define NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP224R1_ENABLED 1
// <q> NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP256R1_ENABLED - Enable secp256r1 (NIST 256-bit) curve
// <i> Enable this setting if you need secp256r1 (NIST 256-bit) support using micro-ecc
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP256R1_ENABLED
#define NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP256R1_ENABLED 1
// <q> NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP256K1_ENABLED - Enable secp256k1 (Koblitz 256-bit) curve
// <i> Enable this setting if you need secp256k1 (Koblitz 256-bit) support using micro-ecc
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP256K1_ENABLED
#define NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP256K1_ENABLED 1
// <q> NRF_CRYPTO_BACKEND_MICRO_ECC_PUBLIC_KEY_TRUSTED_ENABLED - Always trust raw public key (it will cause a security issue if the public key comes from an untrusted source)
// <i> Enable this setting if you want to reduce flash usage. Only for use in nRF SDK DFU! Never enable it if the raw public key comes from an untrusted source.
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_PUBLIC_KEY_TRUSTED_ENABLED
#define NRF_CRYPTO_BACKEND_MICRO_ECC_PUBLIC_KEY_TRUSTED_ENABLED 0
// <q> NRF_CRYPTO_BACKEND_MICRO_ECC_LITTLE_ENDIAN_ENABLED - Enable non-standard little endian byte order.
// <i> This affects parameters for all ECC API (raw keys, signature, digest, shared secret). Only for use in nRF SDK DFU!
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_LITTLE_ENDIAN_ENABLED
#define NRF_CRYPTO_BACKEND_MICRO_ECC_LITTLE_ENDIAN_ENABLED 0
// </e>
I do not know how to map these 2 definitions into so many definitions... would you please guide? Thanks.
