I have a NRF52840 Dev Kit and a few Holyiot-17095 modules. From here - https://devzone.nordicsemi.com/f/nordic-q-a/25100/could-you-recommend-nrf51-nrf52-compatible-j-link/98849#98849 i came to know that the Dev Kit can be used to program the external modules.
Could someone let know the connection diagram and process of flashing a program onto Holyiot-17095 using NRF52840 Dev Kit?
Okay, i found this discussion, which helps me understand the connection diagram. I have planned to go ahead with this and try out. However, following query is still valid. Could some one please look at it and suggest?
I am working on an Ubuntu 64 bit machine, which is able to see the dev Kit. I am also able to flash softdevice and programs using nrfjprog utility on NRF52840 Dev Kit over USB. However, not able to understand how to move ahead if an external module (Holyiot-17095) is to be flashed. What should be the tool setup on a Linux machine to achieve this?
Thank you.
-amit
