I am trying to interface an atmega32 with an nRF24L01. I am trying to communicate between two nRF's. But before proceeding to that, I set out to test the SPI connection between the atmega and nRF.
This is the nRF24L01.h header file:
This is a picture of my connection. I've used the upper atmega32 and an nRF24L01 and USBASP V2.0 from LC Technology. I'm using atmel studio 7 to write the code and extreme burner AVR to burn the code. I'm using a PAKKO 6F22 9V Heavy duty battery as the power source. I have used two potentiometers to divide the voltage. Atmega32 is given around ~4.8V and nRF around ~3.2 V. But with this current configuration, power fluctuates a lot. I'm using LED on PORTA to test my code. But sometimes the LED lights up and sometimes it doesn't. (PORTA = 0x04 don't get executed) I've checked the connection thoroughly, but can't figure out why it is behaving like this. And if it does light up, it is not giving the correct output, i.e the value I've written to the registers is not reflected on the LED. (If condition in while loop is not executed) Can you guys give me some suggestions to work out the power issue and to get the intended output on LEDs?
Note : Code is taken mainly from Gizmosnack's tutorial.
Link: http://gizmosnack.blogspot.com/2013/04/tutorial-nrf24l01-and-avr.html
I'm using
