Command Line Programming nRF52840 Dongle
I've been trying to find a way to program a hex file onto the dongle via the command line on linux.
I would very much prefer not having to touch the mouse in order to program the dongle, so the Programmer App is out of the question. Also, it doesn't work. Instead it just throws a warning about the start of the program being located at address 0x0.
I've tried creating a package using nrfutil, but that didn't work either. After having managed to put together a package like so:
    nrfutil pkg generate --debug-mode --application ot-ncp-ftd.hex --hw-version 52 --sd-req 0xA7,0x67,0x80,0x81,0x87,0x88,0x8C,0x91,0x95,0x98,0x99,0x9E,0x9F,0x9D,0xA5,0xA8,0xA9 ftd.zip
and trying to program like so
    dfu usb_serial --package ftd.zip -p /dev/ttyACM0
it just threw me this error: pc_ble_driver_py.exceptions.NordicSemiException: Response Code InvalidObject
It would be great to have support for the dongle in nrfjprog
Cheers,
Andri
  • I found out that the nRF Connect programmer will work if I edit the GCC linker script. Replace:
    MEMORY
      FLASH (rx) : ORIGIN = 0x0, LENGTH = 0x100000
      RAM (rwx) :  ORIGIN = 0x20000000, LENGTH = 0x40000
    with
    MEMORY
      FLASH (rx) : ORIGIN = 0x1000, LENGTH = 0xff000
      RAM (rwx) :  ORIGIN = 0x20000008, LENGTH = 0x3fff8
    It does not help with nrfutil, so I'm still missing a way to do it on the command line.
  • HI Andrii,
    I sincerely apologize for the late reply.
    You should be able to generate an application firmware image that uses the S140 v6.0.0 using the following command
    nrfutil pkg generate --application ble_app_blinky_pca10059_s140.hex --application-version 5 --hw-version 52 --sd-req 0xA9 ble_app_blinky.zip
    Note: You need to set the FLASH length so that ORIGIN+ LENGTH < 0xE0000 (start address of the bootloader)
  • Hi Bjørn,
    It's understandable given the fellesferie.
    You wouldn't happen to know how I can configure the FLASH start address in Zephyr? They have quite a complicated build system. Editing the linker script does not seem to be a straight-forward task.
  • just to make sure, if you plan to use Zephyr then you should not have the Softdevice programmed, seems the suggestion from Bjørn used this.
    The Dongle will always have the MBR from the Softdevice in the first block (unless you use an external SWD programmer for programming) so your Zephyr application needs to work despite this, that means work with the MBR interrupt forwarding scheme. You may use VTOR to change the location of the interrupt table as an option.
  • Hi Andri,
    it would be great if you could confirm if your trying to update the dongle with an application built with Zephyr or if its an application built with the nRF5 SDK. If it is a Zephyr application then you  will have to make sure it is compatible with the interrupt forwarding scheme of the MBR, as stated by .
    Bjørn
