TWI Low power mode
Dear Nordic Team,
Thanks for support
Currently i am work with VL53L0X in ble_uart_app example. it working fine , but its take 5ma current. How can i use TWI in low power mode. Please suggest anyone.
SDK =12.3.0 , SD=s132.
My Code :
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_config = {
       .scl                = DEVICE_SCL_PIN,
       .sda                = DEVICE_SDA_PIN,
       .frequency          = NRF_TWI_FREQ_400K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);  //twi_handler
    nrf_drv_twi_enable(&m_twi);
    uint32_t err_code;
    bool erase_bonds;
     uint8_t LI8u_Buffer[50]={0};
		static uint8_t data_array[20]={"Distance===>0000MM\n"};
    // Initialize.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    //uart_init();
//			twi_init();
//			if(VL53L0X_init(1)){VL53L0X_Init_flag=1;}
//			else VL53L0X_Init_flag = 0;
//			VL53L0X_setSignalRateLimit(0.1);
//			VL53L0X_setVcselPulsePeriod(VcselPeriodPreRange,18);
//			VL53L0X_setVcselPulsePeriod(VcselPeriodFinalRange,14);
//			VL53L0X_setMeasurementTimingBudget(220000);
    ble_stack_init();
    gap_params_init();
    services_init();
    advertising_init();
    conn_params_init();
   // printf("\r\nUART Start!\r\n");
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    // Enter main loop.
    for (;;)
			 // nrf_delay_ms(5000);
        power_manage();
			  if(m_conn_handle != BLE_CONN_HANDLE_INVALID)
					Read_Sensor();
						data_array[12]='0'+(Distance/1000);
						data_array[13]='0'+(Distance/100)%10;
						data_array[14]='0'+(Distance/10)%10;
						data_array[15]='0'+(Distance%10);
					if(VL53L0X_Init_flag){
					err_code=ble_nus_string_send(&m_nus,(uint8_t *)"INIT OK",7);
					  err_code=ble_nus_string_send(&m_nus,data_array,sizeof(data_array));
									nrf_delay_ms(500);
void Read_Sensor(void){
				twi_init();nrf_delay_ms(5);
			else VL53L0X_Init_flag = 0;	nrf_delay_ms(5);
//VL53L0X_Init_flag=1;
	nrf_delay_ms(500);
						 Distance = VL53L0X_readRangeSingleMillimeters();
						 if( Distance<=2000 && Distance>0 )
							 Dist_Values=Distance;
						//	 printf("Distance=%d\r\n",Dist_Values);
						 }else{
							 if(Distance!=0&&Distance!=65535){
								    if(Distance>=2000 &&Distance <=8000){
											Dist_Values=1999;
										else if(Distance>=8000 && Distance <=9000){
											Dist_Values=1999;
					//		printf("Distance Error=%d\r\n",Distance);
						 						 	nrf_drv_twi_disable(&m_twi);	nrf_delay_ms(5);
							nrf_drv_twi_uninit(&m_twi);nrf_delay_ms(5);
	*(volatile uint32_t *)0x40003FFC = 0;
	*(volatile uint32_t *)0x40003FFC;
	*(volatile uint32_t *)0x40003FFC = 1;
