Device Name set question
After programming, the device name cannot be changed. Is there any solution that can achieve? I know that I can change the paramter from the function in attached file. But I need the method can make me change the device name after programming. and the p_dev_name is need const parameter
  • Maybe like this?
    1. Create array in flash that will contain your device name like this.
    2. On power on set device name using sd_ble_gap_device_name_set() with this array.
    3. On receiving device name change command over your custom service characteristic store received string in your array in flash.
    4. Set device name using sd_ble_gap_device_name_set() with this array.
    UPD:
    Though best is just using pstorage to store your data and update it with array in RAM as you aren't restricted to use only const parameter, for example, this will work as well:
    #define DEVICE_NAME                        "My_device"
    uint8_t arr[sizeof(DEVICE_NAME)];
    strcpy((char *)arr, (const char *)DEVICE_NAME);
                                          (const uint8_t *)arr,
                                          strlen((char *)arr));
  • On second thought, you can do it using pstorage for updating device name and const to read its value. Knowing exact address in flash in wich pstorage will keep your device name you can declare your const as described in the link in #1 with start address that you can calculate from pstorage and 32 bytes length.
