Device Name set question
After programming, the device name cannot be changed. Is there any solution that can achieve? I know that I can change the paramter from the function in attached file. But I need the method can make me change the device name after programming. and the p_dev_name is need const parameter
  • On second thought, you can do it using pstorage for updating device name and const to read its value. Knowing exact address in flash in wich pstorage will keep your device name you can declare your const as described in the link in #1 with start address that you can calculate from pstorage and 32 bytes length.
