Hi
I've just modified our platform that uses a connectivity based environment to the latest S132 6.1.0/SDK15 combination. Since the migration I seem to miss a lot of scan responses event if they are configured on start scan.
My assumtion is that the new added pause in scanning after a advertisement report has been received is causing this problem. The pause between the advertisement reception and the continue call with start scan function is naturally longer than if no connectivity is used. This longer pause may cause that no scan response is received.
Is this a known behavior? What can I do to get the scan working witch scan responses over connectivity?
Regards Adrian
