NRF52832 SAADC result is not in the right order
Here is my code.
I plan to use 3 ADC (2 single ended, 1 differential) on NRF52832.
#define SAMPLES_IN_BUFFER (3)
#define TEMP_pin     (NRF_SAADC_INPUT_AIN7)
#define BAT_ADC_pin  (NRF_SAADC_INPUT_AIN6)
#define DIFF_P_pin   (NRF_SAADC_INPUT_AIN5)
#define DIFF_N_pin   (NRF_SAADC_INPUT_AIN4)
const nrf_drv_timer_t MY_TIMER_0 = NRF_DRV_TIMER_INSTANCE(0);
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t     m_ppi_channel;
#define NRF_DRV_SAADC_SINGLE_ENDED(PIN_P, GAIN)        \
        .resistor_p = NRF_SAADC_RESISTOR_DISABLED,     \
        .resistor_n = NRF_SAADC_RESISTOR_DISABLED,     \
        .gain       = GAIN,                            \
        .reference  = NRF_SAADC_REFERENCE_INTERNAL,    \
        .acq_time   = NRF_SAADC_ACQTIME_10US,          \
        .mode       = NRF_SAADC_MODE_SINGLE_ENDED,     \
        .burst      = NRF_SAADC_BURST_DISABLED,        \
        .pin_p      = (nrf_saadc_input_t)(PIN_P),      \
        .pin_n      = NRF_SAADC_INPUT_DISABLED         \
#define NRF_DRV_SAADC_DIFFERENTIAL(PIN_P, PIN_N, GAIN) \
        .gain       = GAIN,                            \
        .mode       = NRF_SAADC_MODE_DIFFERENTIAL,     \
        .pin_n      = (nrf_saadc_input_t)(PIN_N)       \
void saadc_sampling_event_init(void) {
    ret_code_t err_code;
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                          timer_compare_event_addr,
                                          saadc_sample_task_addr);
void saadc_sampling_event_enable(void) {
void saadc_callback(nrf_drv_saadc_evt_t const * p_event) {
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        printf("%5d, %5d, %5d\n", p_event->data.done.p_buffer[0], p_event->data.done.p_buffer[1], p_event->data.done.p_buffer[2]);
void saadc_init(void) {
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    nrf_saadc_resolution_set(NRF_SAADC_RESOLUTION_12BIT);
    // channel 0
    // ADC range = 0.6V / GAIN = 0.6 / (1/6) = 3.6V
    nrf_saadc_channel_config_t channel_0_config = NRF_DRV_SAADC_SINGLE_ENDED(BAT_ADC_pin, NRF_SAADC_GAIN1_6);
    err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
    // channel 1
    // ADC range = 0.6V / GAIN = 0.6 / (1/2) = 1.2V
    nrf_saadc_channel_config_t channel_1_config = NRF_DRV_SAADC_SINGLE_ENDED(TEMP_pin, NRF_SAADC_GAIN1_6);
    err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
    // channel 2
    // ADC range = 0.6V / GAIN = 0.6 / 1 = +-0.6 V
    // ADC range = 0.6V / GAIN = 0.6 / 2 = +-0.3 V
    // ADC range = 0.6V / GAIN = 0.6 / 4 = +-0.15V
    nrf_saadc_channel_config_t channel_2_config = NRF_DRV_SAADC_DIFFERENTIAL(DIFF_P_pin, DIFF_N_pin, NRF_SAADC_GAIN1);
    err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
int main(void) {
    nrf_drv_timer_init(&MY_TIMER_0, &timer_cfg, &my_timer_handler);
    nrf_drv_timer_extended_compare(&MY_TIMER_0,
                                    NRF_TIMER_CC_CHANNEL0,
                                    nrf_drv_timer_ms_to_ticks(&MY_TIMER_0, 50),
                                    NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                    true);
    nrf_drv_timer_enable(&MY_TIMER_0);
    saadc_init();
    saadc_sampling_event_init();
Only the first time convert, I can get correct order output  ADC_ch0, ADC_ch1 and ADC_ch2,
otherwise,  I discover the output order is ADC_ch2, ADC_ch0 and ADC_ch1.
How to solve this problem?
