which pin to use for TWI method communication, in board type 10040 nfr52832 model Taiyo Yuden EKSHJN
in file 10040 I have this definition of pins:
what should i change?
Is it correct to connect SWD-CLK for SCL signal and SWD-IO for SDA signal?
#define RX_PIN_NUMBER 8 #define TX_PIN_NUMBER 6 #define CTS_PIN_NUMBER 7 #define RTS_PIN_NUMBER 5 #define HWFC true #define SPIS_MISO_PIN 28 // SPI MISO signal. #define SPIS_CSN_PIN 12 // SPI CSN signal. #define SPIS_MOSI_PIN 25 // SPI MOSI signal. #define SPIS_SCK_PIN 29 // SPI SCK signal. #define SPIM0_SCK_PIN 29 // SPI clock GPIO pin number. #define SPIM0_MOSI_PIN 25 // SPI Master Out Slave In GPIO pin number. #define SPIM0_MISO_PIN 28 // SPI Master In Slave Out GPIO pin number. #define SPIM0_SS_PIN 12 // SPI Slave Select GPIO pin number. #define SPIM1_SCK_PIN 2 // SPI clock GPIO pin number. #define SPIM1_MOSI_PIN 3 // SPI Master Out Slave In GPIO pin number. #define SPIM1_MISO_PIN 4 // SPI Master In Slave Out GPIO pin number. #define SPIM1_SS_PIN 5 // SPI Slave Select GPIO pin number. #define SPIM2_SCK_PIN 12 // SPI clock GPIO pin number. #define SPIM2_MOSI_PIN 13 // SPI Master Out Slave In GPIO pin number. #define SPIM2_MISO_PIN 14 // SPI Master In Slave Out GPIO pin number. #define SPIM2_SS_PIN 15 // SPI Slave Select GPIO pin number. // serialization APPLICATION board - temp. setup for running serialized MEMU tests #define SER_APP_RX_PIN 23 // UART RX pin number. #define SER_APP_TX_PIN 24 // UART TX pin number. #define SER_APP_CTS_PIN 2 // UART Clear To Send pin number. #define SER_APP_RTS_PIN 25 // UART Request To Send pin number. #define SER_APP_SPIM0_SCK_PIN 27 // SPI clock GPIO pin number. #define SER_APP_SPIM0_MOSI_PIN 2 // SPI Master Out Slave In GPIO pin number #define SER_APP_SPIM0_MISO_PIN 26 // SPI Master In Slave Out GPIO pin number #define SER_APP_SPIM0_SS_PIN 23 // SPI Slave Select GPIO pin number #define SER_APP_SPIM0_RDY_PIN 25 // SPI READY GPIO pin number #define SER_APP_SPIM0_REQ_PIN 24 // SPI REQUEST GPIO pin number // serialization CONNECTIVITY board #define SER_CON_RX_PIN 24 // UART RX pin number. #define SER_CON_TX_PIN 23 // UART TX pin number. #define SER_CON_CTS_PIN 25 // UART Clear To Send pin number. Not used if HWFC is set to false. #define SER_CON_RTS_PIN 2 // UART Request To Send pin number. Not used if HWFC is set to false. #define SER_CON_SPIS_SCK_PIN 27 // SPI SCK signal. #define SER_CON_SPIS_MOSI_PIN 2 // SPI MOSI signal. #define SER_CON_SPIS_MISO_PIN 26 // SPI MISO signal. #define SER_CON_SPIS_CSN_PIN 23 // SPI CSN signal. #define SER_CON_SPIS_RDY_PIN 25 // SPI READY GPIO pin number. #define SER_CON_SPIS_REQ_PIN 24 // SPI REQUEST GPIO pin number. #define SER_CONN_CHIP_RESET_PIN 11 // Pin used to reset connectivity chip
