IRQ not triggered even though the emission status seems ok.
I've been using the nRF24l01+ for some time now and am quite satisfied. I'm having a new issue that I'm unable to explain and for which I would greatly appreciate some help.
I have two units comunicating together using the following scheme:
1: T = t0 - Module 1 sends message 1
2: T = t0 - Module 2 receives message 1
3: T = t0 + 30 ms - Module 2 sends msg 2
4: T = t0 + 30 ms - Module 1 receives msg 2
5: T = t0 + 40 ms - Module 1 sends msg 3
6: T = t0 + 50 ms - Module 1 sends msg 4
7: T = t0 + 100 ms - The process starts again.
My problem is that when I send msg2 using the module 2, the tx status goes to 1, which means that the emission went well, but there is no IRQ triggered on the module 1 side. Is there a configuration where the emitting unit sees everything as normal whereas the receiving unit doesn't call an interruption ?
The problem gets even more strange, because when I remove step 5 or step 6, so I just send one message after receiveing msg 2, then everything starts to work normally again...
Any clue to what the problem might be ?
Thank you all for any help you may provide,
