Hi.
I'm busy to add the nrf8001 BLE module to my PIC32MM product for negative pressure monitoring in a small area. Is there is list of minimum settings that is available to get the nrf8001 going? (Pseudo code) or something?
Kind regards BDD
Hi.
Kind regards BDD
I would recommend that you start with the ble-sdk-arduino. Follow the porting guide. At a minimum you need to use nRFgo studio to create a setup file (or use one from the example projects). This needs to be sent to the nRF8001 on boot to configure the device. After that you can send / receive data according to your configuration.
porting guide:: https://github.com/NordicSemiconductor/ble-sdk-arduino/blob/master/documentation/libraries/BLE/nRF8001-Porting-ACI-Library.md
Im new to the nRFgo Stdio.
So I need to do a setup on the Studio , will that export a settings file that I can use and stream over via SPI? from my PIC32MM
Yes, you need to do that. I guess you should also look at the library arcithecture document to get a better understanding of this.
