Hi ;
I am using the sdk12.3 spi example to read external flash W25Q16, but it fails . Here is my code. Do you have any suggestion ?
/** * Copyright (c) 2015 - 2017, Nordic Semiconductor ASA * * All rights reserved. * * Redistribution and use in source and binary forms, with or without modification, * are permitted provided that the following conditions are met: * * 1. Redistributions of source code must retain the above copyright notice, this * list of conditions and the following disclaimer. * * 2. Redistributions in binary form, except as embedded into a Nordic * Semiconductor ASA integrated circuit in a product or a software update for * such product, must reproduce the above copyright notice, this list of * conditions and the following disclaimer in the documentation and/or other * materials provided with the distribution. * * 3. Neither the name of Nordic Semiconductor ASA nor the names of its * contributors may be used to endorse or promote products derived from this * software without specific prior written permission. * * 4. This software, with or without modification, must only be used with a * Nordic Semiconductor ASA integrated circuit. * * 5. Any software provided in binary form under this license must not be reverse * engineered, decompiled, modified and/or disassembled. * * THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES * OF MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE * DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE * GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ #include "sdk_common.h" #include "nrf_drv_spi.h" #include "nrf_drv_common.h" #include "nrf_gpio.h" #include "nrf_assert.h" #include "app_util_platform.h" #include "nrf_log.h" #include "nrf_log_ctrl.h" #if 0 #define NRF_LOG_MODULE_NAME "SPI" #if SPI_CONFIG_LOG_ENABLED #define NRF_LOG_LEVEL SPI_CONFIG_LOG_LEVEL #define NRF_LOG_INFO_COLOR SPI_CONFIG_INFO_COLOR #define NRF_LOG_DEBUG_COLOR SPI_CONFIG_DEBUG_COLOR #else //SPI_CONFIG_LOG_ENABLED #define NRF_LOG_LEVEL 0 #endif //SPI_CONFIG_LOG_ENABLED #include "nrf_log.h" #endif #define IRQ_HANDLER(n) void SPI##n##_IRQ_HANDLER(void) /* Defines -------------------------------------------------------------------*/ /* Flash ID */ #define GD25Q32_FLASH_ID 0xC8 /* Status Register Bits */ #define STATUS_BUSY 0x01 #define STATUS_WEL 0x02 #define STATUS_BP0 0x04 #define STATUS_BP1 0x08 #define STATUS_TB 0x20 #define STATUS_SRP 0x80 /* Flash operation command */ #define WRITE_STATUS_REG 0x01 #define PAGE_PROGRAM 0x02 #define READ_DATA_BYTE 0x03 #define READ_STATUS_REG 0x05 #define CHIP_EARSE 0x60 #define READ_ID 0x9f /** @addtogroup Exported_types * @{ */ // Control block - driver instance local data. typedef struct { nrf_drv_spi_handler_t handler; nrf_drv_spi_evt_t evt; // Keep the struct that is ready for event handler. Less memcpy. nrf_drv_state_t state; volatile bool transfer_in_progress; // [no need for 'volatile' attribute for the following members, as they // are not concurrently used in IRQ handlers and main line code] uint8_t ss_pin; uint8_t orc; uint8_t bytes_transferred; bool tx_done : 1; bool rx_done : 1; } spi_control_block_t; static spi_control_block_t m_cb[1]; /*******************************************************************************************/ //static volatile bool spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */ extern bool spi_xfer_done; /** * @brief SPI user event handler. * @param event */ void spi_event_handler(nrf_drv_spi_evt_t const * p_event) { spi_xfer_done = true; NRF_LOG_INFO("Transfer completed.\r\n"); // if (m_rx_buf[0] != 0) { NRF_LOG_INFO(" Received: \r\n"); // NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf)); } } ret_code_t nrf_drv_spi_init(nrf_drv_spi_t const * const p_instance, nrf_drv_spi_config_t const * p_config, nrf_drv_spi_handler_t handler) { ASSERT(p_config); spi_control_block_t * p_cb = &m_cb[p_instance->drv_inst_idx]; ret_code_t err_code; p_cb->handler = handler; uint32_t mosi_pin; uint32_t miso_pin; // Configure pins used by the peripheral: // - SCK - output with initial value corresponding with the SPI mode used: // 0 - for modes 0 and 1 (CPOL = 0), 1 - for modes 2 and 3 (CPOL = 1); // according to the reference manual guidelines this pin and its input // buffer must always be connected for the SPI to work. if (p_config->mode <= NRF_DRV_SPI_MODE_1) { nrf_gpio_pin_clear(p_config->sck_pin); } else { nrf_gpio_pin_set(p_config->sck_pin); } NRF_GPIO->PIN_CNF[p_config->sck_pin] = (GPIO_PIN_CNF_DIR_Output << GPIO_PIN_CNF_DIR_Pos) | (GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos) | (GPIO_PIN_CNF_PULL_Disabled << GPIO_PIN_CNF_PULL_Pos) | (GPIO_PIN_CNF_DRIVE_S0S1 << GPIO_PIN_CNF_DRIVE_Pos) | (GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos); // - MOSI (optional) - output with initial value 0, mosi_pin = p_config->mosi_pin; nrf_gpio_pin_clear(mosi_pin); nrf_gpio_cfg_output(mosi_pin); // - MISO (optional) - input, miso_pin = p_config->miso_pin; nrf_gpio_cfg_input(miso_pin, NRF_GPIO_PIN_NOPULL); // - Slave Select (optional) - output with initial value 1 (inactive). nrf_gpio_pin_set(p_config->ss_pin); nrf_gpio_cfg_output(p_config->ss_pin); m_cb[p_instance->drv_inst_idx].ss_pin = p_config->ss_pin; NRF_SPI_Type * p_spi = p_instance->p_registers; nrf_spi_pins_set(p_spi, p_config->sck_pin, mosi_pin, miso_pin); nrf_spi_frequency_set(p_spi, (nrf_spi_frequency_t)p_config->frequency); nrf_spi_configure(p_spi, (nrf_spi_mode_t)p_config->mode, (nrf_spi_bit_order_t)p_config->bit_order); m_cb[p_instance->drv_inst_idx].orc = p_config->orc; if (p_cb->handler) { nrf_spi_int_enable(p_spi, NRF_SPI_INT_READY_MASK); } nrf_spi_enable(p_spi); if (p_cb->handler) { nrf_drv_common_irq_enable(p_instance->irq, p_config->irq_priority); } p_cb->transfer_in_progress = false; p_cb->state = NRF_DRV_STATE_INITIALIZED; NRF_LOG_INFO("Init\r\n"); err_code = NRF_SUCCESS; NRF_LOG_INFO("Function: %s, error code: %s.\r\n", (uint32_t)__func__, (uint32_t)ERR_TO_STR(err_code)); return err_code; } void nrf_drv_spi_uninit(nrf_drv_spi_t const * const p_instance) { spi_control_block_t * p_cb = &m_cb[p_instance->drv_inst_idx]; ASSERT(p_cb->state != NRF_DRV_STATE_UNINITIALIZED); if (p_cb->handler) { nrf_drv_common_irq_disable(p_instance->irq); } #define DISABLE_ALL 0xFFFFFFFF NRF_SPI_Type * p_spi = p_instance->p_registers; if (p_cb->handler) { nrf_spi_int_disable(p_spi, DISABLE_ALL); } nrf_spi_disable(p_spi); #undef DISABLE_ALL p_cb->state = NRF_DRV_STATE_UNINITIALIZED; } ret_code_t nrf_drv_spi_transfer(nrf_drv_spi_t const * const p_instance, uint8_t * p_tx_buffer, uint8_t tx_buffer_length, uint8_t * p_rx_buffer, uint8_t rx_buffer_length) { nrf_drv_spi_xfer_desc_t xfer_desc; NRF_SPI_Type * p_spi = p_instance->p_registers; nrf_spi_event_clear(p_spi, NRF_SPI_EVENT_READY); xfer_desc.p_tx_buffer = p_tx_buffer; xfer_desc.tx_length = tx_buffer_length; xfer_desc.p_rx_buffer = p_rx_buffer; xfer_desc.rx_length = rx_buffer_length; NRF_LOG_DEBUG("Tx data:\r\n"); NRF_LOG_DEBUG("%x\r\n",p_tx_buffer[0] ); NRF_LOG_INFO("Transfer tx_len:%d, rx_len:%d.\r\n", tx_buffer_length, rx_buffer_length); NRF_LOG_FLUSH(); return nrf_drv_spi_xfer(p_instance, &xfer_desc, 0); } static void finish_transfer(spi_control_block_t * p_cb) { // If Slave Select signal is used, this is the time to deactivate it. if (p_cb->ss_pin != NRF_DRV_SPI_PIN_NOT_USED) { nrf_gpio_pin_set(p_cb->ss_pin); } // By clearing this flag before calling the handler we allow subsequent // transfers to be started directly from the handler function. p_cb->transfer_in_progress = false; p_cb->evt.type = NRF_DRV_SPI_EVENT_DONE; NRF_LOG_INFO("finish_transfer rx_len:%d.\r\n", p_cb->evt.data.done.rx_length); NRF_LOG_DEBUG("Rx data:\r\n"); NRF_LOG_HEXDUMP_DEBUG((uint8_t *)p_cb->evt.data.done.p_rx_buffer, p_cb->evt.data.done.rx_length * sizeof(p_cb->evt.data.done.p_rx_buffer)); p_cb->handler(&p_cb->evt); } // This function is called from IRQ handler or, in blocking mode, directly // from the 'nrf_drv_spi_transfer' function. // It returns true as long as the transfer should be continued, otherwise (when // there is nothing more to send/receive) it returns false. static bool transfer_byte(NRF_SPI_Type * p_spi, spi_control_block_t * p_cb) { // Read the data byte received in this transfer and store it in RX buffer, // if needed. volatile uint8_t rx_data = nrf_spi_rxd_get(p_spi); if (p_cb->bytes_transferred < p_cb->evt.data.done.rx_length) { if(READ_DATA_BYTE == p_cb->evt.data.done.p_tx_buffer[0]) { if(p_cb->bytes_transferred >= 4) { p_cb->evt.data.done.p_rx_buffer[p_cb->bytes_transferred-4] = rx_data; } } else { p_cb->evt.data.done.p_rx_buffer[p_cb->bytes_transferred] = rx_data; } } ++p_cb->bytes_transferred; // Check if there are more bytes to send or receive and write proper data // byte (next one from TX buffer or over-run character) to the TXD register // when needed. // NOTE - we've already used 'p_cb->bytes_transferred + 1' bytes from our // buffers, because we take advantage of double buffering of TXD // register (so in effect one byte is still being transmitted now); // see how the transfer is started in the 'nrf_drv_spi_transfer' // function. // uint16_t bytes_used = p_cb->bytes_transferred + 1; // if (bytes_used < p_cb->evt.data.done.tx_length) if (p_cb->bytes_transferred < p_cb->evt.data.done.tx_length) { // NRF_LOG_DEBUG("transfer_byte Tx0 data:%x\r\n", p_cb->evt.data.done.p_tx_buffer[bytes_used]); // nrf_spi_txd_set(p_spi, p_cb->evt.data.done.p_tx_buffer[bytes_used]); // NRF_LOG_DEBUG("transfer_byte Tx0 data:%x\r\n", p_cb->evt.data.done.p_tx_buffer[p_cb->bytes_transferred]); nrf_spi_txd_set(p_spi, p_cb->evt.data.done.p_tx_buffer[p_cb->bytes_transferred]); return true; } //else if (bytes_used < p_cb->evt.data.done.rx_length) else if (p_cb->bytes_transferred < p_cb->evt.data.done.rx_length) { // NRF_LOG_DEBUG("transfer_byte Tx1 data:%x\r\n", p_cb->orc); nrf_spi_txd_set(p_spi, p_cb->orc); return true; } return (p_cb->bytes_transferred < p_cb->evt.data.done.tx_length || p_cb->bytes_transferred < p_cb->evt.data.done.rx_length); } static void spi_xfer(NRF_SPI_Type * p_spi, spi_control_block_t * p_cb, nrf_drv_spi_xfer_desc_t const * p_xfer_desc) { p_cb->bytes_transferred = 0; nrf_spi_int_disable(p_spi, NRF_SPI_INT_READY_MASK); nrf_spi_event_clear(p_spi, NRF_SPI_EVENT_READY); nrf_spi_txd_set(p_spi, p_xfer_desc->tx_length > 0 ? p_xfer_desc->p_tx_buffer[0] : p_cb->orc); // TXD register is double buffered, so next byte to be transmitted can // be written immediately, if needed, i.e. if TX or RX transfer is to // be more that 1 byte long. Again - if there is something more in TX // buffer send it, otherwise use over-run character. #if 0 if (p_xfer_desc->tx_length > 1) { nrf_spi_txd_set(p_spi, p_xfer_desc->p_tx_buffer[1]); } else if (p_xfer_desc->rx_length > 1) { nrf_spi_txd_set(p_spi, p_cb->orc); } #endif // For blocking mode (user handler not provided) wait here for READY // events (indicating that the byte from TXD register was transmitted // and a new incoming byte was moved to the RXD register) and continue // transaction until all requested bytes are transferred. // In non-blocking mode - IRQ service routine will do this stuff. if (p_cb->handler) { nrf_spi_int_enable(p_spi, NRF_SPI_INT_READY_MASK); } else { do { while (!nrf_spi_event_check(p_spi, NRF_SPI_EVENT_READY)) {} nrf_spi_event_clear(p_spi, NRF_SPI_EVENT_READY); NRF_LOG_DEBUG("SPI: Event: NRF_SPI_EVENT_READY.\r\n"); } while (transfer_byte(p_spi, p_cb)); if (p_cb->ss_pin != NRF_DRV_SPI_PIN_NOT_USED) { nrf_gpio_pin_set(p_cb->ss_pin); } } } ret_code_t nrf_drv_spi_xfer(nrf_drv_spi_t const * const p_instance, nrf_drv_spi_xfer_desc_t const * p_xfer_desc, uint32_t flags) { spi_control_block_t * p_cb = &m_cb[p_instance->drv_inst_idx]; ASSERT(p_cb->state != NRF_DRV_STATE_UNINITIALIZED); ASSERT(p_xfer_desc->p_tx_buffer != NULL || p_xfer_desc->tx_length == 0); // ASSERT(p_xfer_desc->p_rx_buffer != NULL || p_xfer_desc->rx_length == 0); ret_code_t err_code = NRF_SUCCESS; if (p_cb->transfer_in_progress) { err_code = NRF_ERROR_BUSY; NRF_LOG_WARNING("nrf_drv_spi_xfer Function: %s, error code: %s.\r\n", (uint32_t)__func__, (uint32_t)ERR_TO_STR(err_code)); return err_code; } else { if (p_cb->handler && !(flags & (NRF_DRV_SPI_FLAG_REPEATED_XFER | NRF_DRV_SPI_FLAG_NO_XFER_EVT_HANDLER))) { p_cb->transfer_in_progress = true; } } p_cb->evt.data.done = *p_xfer_desc; p_cb->tx_done = false; p_cb->rx_done = false; nrf_gpio_pin_clear(p_cb->ss_pin); if (flags) { p_cb->transfer_in_progress = false; err_code = NRF_ERROR_NOT_SUPPORTED; } else { spi_xfer(p_instance->p_registers, p_cb, p_xfer_desc); } NRF_LOG_INFO("nrf_drv_spi_xfer_1 Function: %s, error code: %s.\r\n", (uint32_t)__func__, (uint32_t)ERR_TO_STR(err_code)); return err_code; } /** * @brief Read status register of flash. * @param none. * @return value of status register. * */ uint8_t ExternalFlash_ReadStatus(nrf_drv_spi_t const * const p_instance) { uint8_t sendBuf[2] = {READ_STATUS_REG, 0}; // 05 read register uint8_t irecvBuf[2], recv_len = 2;; spi_xfer_done = false; APP_ERROR_CHECK(nrf_drv_spi_transfer(p_instance, sendBuf, sizeof(sendBuf), irecvBuf, recv_len)); while (!spi_xfer_done) { __WFE(); } return irecvBuf[1]; } /** * @brief Check flash is in progress or not. * @param none. * @return SET: Flash is always in progress. RESET: Flash is in standby mode. * */ FlagStatus ExternalFlash_CheckWriteStatus(nrf_drv_spi_t const * const p_instance) { uint32_t time_out = 0xfffff; uint8_t status = 0; do { /* Time out control */ time_out--; if(time_out == 0) { return SET; } status = ExternalFlash_ReadStatus(p_instance); } while(status & STATUS_BUSY);/* Check flash is communicating or not */ return RESET; } /** * @brief Send write enable command before every page program(PP), * sector earse(SE), block earse(BE), chip earse(CE) and write status register(WRSR) command. * @param No parameter. * @return void * */ void ExternalFlash_WriteCmd(nrf_drv_spi_t const * const p_instance, FunctionalState NewState) { uint8_t cmd, send_len = 1; uint8_t recvBuf[1], recv_len = 1; /* Check earse status */ ExternalFlash_CheckWriteStatus(p_instance); /* Send write command */ if(NewState == ENABLE) { /* Send write enable command */ cmd = 0x06; } else { /* Send write disable command */ cmd = 0x04; } spi_xfer_done = false; APP_ERROR_CHECK(nrf_drv_spi_transfer(p_instance, &cmd, send_len, recvBuf, recv_len)); while (!spi_xfer_done) { __WFE(); } /* Check earse status */ ExternalFlash_CheckWriteStatus(p_instance); } /** * @brief Earse flash. * @param address: address which begin to earse. * @param mode: select earse mode. * @return none. * */ void ExternalFlash_Earse(nrf_drv_spi_t const * const p_instance,uint32_t address, Flash_erase_module_t mode) { uint8_t sendBuf[4],recvBuf[4]; uint8_t send_len = 4; uint16_t recv_len = 4; /* Enable write */ ExternalFlash_WriteCmd(p_instance,ENABLE); /* Write data */ sendBuf[0] = mode; sendBuf[1] = (address>>16) & 0xff; sendBuf[2] = (address>>8) & 0xff; sendBuf[3] = address & 0xff; spi_xfer_done = false; APP_ERROR_CHECK(nrf_drv_spi_transfer(p_instance, sendBuf, send_len, recvBuf, recv_len)); while (!spi_xfer_done) { __WFE(); } APP_ERROR_CHECK(nrf_drv_spi_transfer(p_instance, sendBuf, send_len, recvBuf, recv_len)); } /** * @brief Write flash. * @param address: address which begin to write. * @param psendBuf: address of data buffer which want to write. * @param len: length of data buffer which want to write. * @return none. * */ void ExternalFlash_Write(nrf_drv_spi_t const * const p_instance,uint32_t address, uint8_t *psendBuf, uint16_t len) { uint8_t sendBuf[255], recvBuf[1];// = {PAGE_PROGRAM, 0, 0, 0},recvBuf[10]; /* Enable write */ ExternalFlash_WriteCmd(p_instance,ENABLE); /* Send write command */ sendBuf[0] = 0x02; sendBuf[1] = (address>>16) & 0xff; sendBuf[2] = (address>>8) & 0xff; sendBuf[3] = address & 0xff; /* Send write data */ memcpy(&sendBuf[4], psendBuf, len); len = len + 4; spi_xfer_done = false; nrf_drv_spi_transfer(p_instance, sendBuf, len, recvBuf,0);//recvBuf, 30); while (!spi_xfer_done) { __WFE(); } } /** * @brief Read flash. * @param address: address which begin to read. * @param pStoreBuf: address of data buffer which want to read. * @param len: length of data buffer which want to read. * @return none. * */ void ExternalFlash_Read(nrf_drv_spi_t const * const p_instance,uint32_t address, uint8_t *pStoreBuf, uint16_t len) { uint8_t sendBuf[4] ={READ_DATA_BYTE,0,0,0}; /* Read flash status register */ ExternalFlash_CheckWriteStatus(p_instance); /* Send read command and address */ sendBuf[0] = READ_DATA_BYTE; sendBuf[1] = (address>>16) & 0xff; sendBuf[2] = (address>>8) & 0xff; sendBuf[3] = address & 0xff; spi_xfer_done = false; APP_ERROR_CHECK(nrf_drv_spi_transfer(p_instance, sendBuf, 4, pStoreBuf, len)); while (!spi_xfer_done) { __WFE(); } } static void irq_handler_spi(NRF_SPI_Type * p_spi, spi_control_block_t * p_cb) { ASSERT(p_cb->handler); nrf_spi_event_clear(p_spi, NRF_SPI_EVENT_READY); if (!transfer_byte(p_spi, p_cb)) { finish_transfer(p_cb); } } #if NRF_MODULE_ENABLED(SPI0) IRQ_HANDLER(0) { spi_control_block_t * p_cb = &m_cb[SPI0_INSTANCE_INDEX]; #if SPI0_USE_EASY_DMA irq_handler_spim(NRF_SPIM0, p_cb); #else irq_handler_spi(NRF_SPI0, p_cb); #endif } #endif // NRF_MODULE_ENABLED(SPI0) #if NRF_MODULE_ENABLED(SPI1) IRQ_HANDLER(1) { spi_control_block_t * p_cb = &m_cb[SPI1_INSTANCE_INDEX]; #if SPI1_USE_EASY_DMA irq_handler_spim(NRF_SPIM1, p_cb); #else irq_handler_spi(NRF_SPI1, p_cb); #endif } #endif // NRF_MODULE_ENABLED(SPI1) #if NRF_MODULE_ENABLED(SPI2) IRQ_HANDLER(2) { spi_control_block_t * p_cb = &m_cb[SPI2_INSTANCE_INDEX]; #if SPI2_USE_EASY_DMA irq_handler_spim(NRF_SPIM2, p_cb); #else irq_handler_spi(NRF_SPI2, p_cb); #endif } #endif // NRF_MODULE_ENABLED(SPI2)
