I have an application that is using FDS to save settings to flash. The application works great as a standalone application, but when I try to use a custom bootloader (same as the secure bootloader for buttonless dfu), I get a FDS_ERR_NO_PAGES when calling fds_init(). This is one of the first calls in the main as listed below. The only difference is the use of the bootloader. I have erased all before loading the bootloader, and Segger is setup to load the additional hex files. Note that I have buttonless DFU working on a separate application that does not use the DFU, and it works as expected. The flash_placement.xml is also attached.
Snippet from main for initialization
int main(void) { ret_code_t err_code; // Initialize. log_init(); timers_init(); leds_init(); power_management_init(); // Start execution. NRF_LOG_DEBUG("Beacon example started."); err_code = nrf_mem_init(); APP_ERROR_CHECK(err_code); err_code = nrf_crypto_init(); APP_ERROR_CHECK(err_code); fds_app_init(); ble_stack_init(); gap_params_init();
fds_app_init() definition:
void fds_app_init(void) {
NRF_LOG_INFO("Initializing fds...");
ret_code_t rc;
/* Register first to receive an event when initialization is complete. */
(void) fds_register(fds_evt_handler);
rc = fds_init(); // <---- The line that fails -----
APP_ERROR_CHECK(rc);
/* Wait for fds to initialize. */
wait_for_fds_ready();
Segger additional load files.
debug_additional_load_file="lib/nRF5-sdk/components/softdevice/s132/hex/s132_nrf52_6.0.0_softdevice.hex"
debug_additional_load_file1="$(ProjectDir)/secure_bootloader/pca10040_ble/ses/Output/Release/Exe/secure_bootloader_ble_s132_pca10040.hex"
debug_additional_load_file2="$(ProjectDir)/$(OutDir)/settings.hex"
Linker section macros and placement
linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x80000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x10000;FLASH_START=0x26000;FLASH_SIZE=0x5a000;RAM_START=0x20002220;RAM_SIZE=0xDDE0;UICR_PH_START=0x10001000;UICR_PH_SIZE=0x0100;UICR_START=0x10001080"
linker_section_placements_segments="FLASH RX 0x0 0x80000;RAM RWX 0x20000000 0x10000;uicr_bootloader_start_address RX 0x10001014 0x4;UICR RX 0x10001000 0x0100"
<!DOCTYPE Linker_Placement_File>
<Root name="Flash Section Placement">
<MemorySegment name="FLASH" start="$(FLASH_PH_START)" size="$(FLASH_PH_SIZE)">
<ProgramSection load="no" name=".reserved_flash" start="$(FLASH_PH_START)" size="$(FLASH_START)-$(FLASH_PH_START)" />
<ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START)" />
<ProgramSection alignment="4" load="Yes" name=".init" />
<ProgramSection alignment="4" load="Yes" name=".init_rodata" />
<ProgramSection alignment="4" load="Yes" name=".text" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_soc_observers" inputsections="*(SORT(.sdh_soc_observers*))" address_symbol="__start_sdh_soc_observers" end_symbol="__stop_sdh_soc_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".pwr_mgmt_data" inputsections="*(SORT(.pwr_mgmt_data*))" address_symbol="__start_pwr_mgmt_data" end_symbol="__stop_pwr_mgmt_data" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_ble_observers" inputsections="*(SORT(.sdh_ble_observers*))" address_symbol="__start_sdh_ble_observers" end_symbol="__stop_sdh_ble_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_const_data" inputsections="*(SORT(.log_const_data*))" address_symbol="__start_log_const_data" end_symbol="__stop_log_const_data" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_balloc" inputsections="*(.nrf_balloc*)" address_symbol="__start_nrf_balloc" end_symbol="__stop_nrf_balloc" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_state_observers" inputsections="*(SORT(.sdh_state_observers*))" address_symbol="__start_sdh_state_observers" end_symbol="__stop_sdh_state_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_stack_observers" inputsections="*(SORT(.sdh_stack_observers*))" address_symbol="__start_sdh_stack_observers" end_symbol="__stop_sdh_stack_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_req_observers" inputsections="*(SORT(.sdh_req_observers*))" address_symbol="__start_sdh_req_observers" end_symbol="__stop_sdh_req_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_queue" inputsections="*(.nrf_queue*)" address_symbol="__start_nrf_queue" end_symbol="__stop_nrf_queue" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_command" inputsections="*(.cli_command*)" address_symbol="__start_cli_command" end_symbol="__stop_cli_command" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".crypto_data" inputsections="*(SORT(.crypto_data*))" address_symbol="__start_crypto_data" end_symbol="__stop_crypto_data" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections" address_symbol="__start_nrf_sections" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_dynamic_data" inputsections="*(SORT(.log_dynamic_data*))" runin=".log_dynamic_data_run"/>
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".fs_data" inputsections="*(.fs_data*)" runin=".fs_data_run"/>
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_sorted_cmd_ptrs" inputsections="*(.cli_sorted_cmd_ptrs*)" runin=".cli_sorted_cmd_ptrs_run"/>
<ProgramSection alignment="4" load="Yes" name=".dtors" />
<ProgramSection alignment="4" load="Yes" name=".ctors" />
<ProgramSection alignment="4" load="Yes" name=".rodata" />
<ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
<ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
<ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
<ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
</MemorySegment>
<MemorySegment name="RAM" start="$(RAM_PH_START)" size="$(RAM_PH_SIZE)">
<ProgramSection load="no" name=".reserved_ram" start="$(RAM_PH_START)" size="$(RAM_START)-$(RAM_PH_START)" />
<ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START)" address_symbol="__app_ram_start__"/>
<ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run" address_symbol="__start_nrf_sections_run" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".log_dynamic_data_run" address_symbol="__start_log_dynamic_data" end_symbol="__stop_log_dynamic_data" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".cli_sorted_cmd_ptrs_run" address_symbol="__start_cli_sorted_cmd_ptrs" end_symbol="__stop_cli_sorted_cmd_ptrs" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run_end" address_symbol="__end_nrf_sections_run" />
<ProgramSection alignment="4" load="No" name=".fast_run" />
<ProgramSection alignment="4" load="No" name=".data_run" />
<ProgramSection alignment="4" load="No" name=".tdata_run" />
<ProgramSection alignment="4" load="No" name=".bss" />
<ProgramSection alignment="4" load="No" name=".tbss" />
<ProgramSection alignment="4" load="No" name=".non_init" />
<ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
<ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack" address_symbol="__StackLimit" end_symbol="__StackTop"/>
<ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
</MemorySegment>
<MemorySegment name="uicr_bootloader_start_address" start="0x10001014" size="0x4">
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".uicr_bootloader_start_address" address_symbol="__start_uicr_bootloader_start_address" end_symbol="__stop_uicr_bootloader_start_address" start = "0x10001014" size="0x4" />
</MemorySegment>
<MemorySegment name="UICR" start="$(UICR_PH_START)" size="$(UICR_PH_SIZE)">
<ProgramSection load="no" name=".reserved_uicr" start="$(UICR_PH_START)" size="$(UICR_START)-$(UICR_PH_START)"/>
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress00" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress01" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress02" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress03" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress04" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress05" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress06" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress07" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress08" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress09" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress10" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress11" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress12" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress13" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress14" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress15" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress16" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress17" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress18" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress19" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress20" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress21" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress22" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress23" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress24" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress25" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress26" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress27" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress28" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress29" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress30" />
<ProgramSection alignment="4" load="Yes" keep="Yes" name=".uicrCustomerAddress31" />
</MemorySegment>
</Root>
