SES debug of nRF51822 hangs with "Unknown function at 0x000006B0" in ble_app_uart sample
Running SES with SDK v12.2 and debugging an nRF51822 running the ble_app_uart sample application. After running for some period of time (typically 2 - 3 minutes) the debugger stops on a line of assembly (appears to be the same point each time). No error in the console, but the function selector at the top shows "Unknown function at " and some hex address. (Currently 0x000006B0).
Seems to be the same as this: https://devzone.nordicsemi.com/f/nordic-q-a/36352/unknown-function-at-some-address
I've adjusted the flash_placement.xml file and the thumb_crt0.s file to (theoretically) include the expected flash storage. Apparently that was the issue for the previous poster who was also working with the uart example. I haven't found a flash_placement.xml file that's specific to the nRF51822 - the examples I've been working from were for nRF52 devices. Perhaps there's a difference? Here's what I've got:
<!DOCTYPE Linker_Placement_File>
<Root name="Flash Section Placement">
  <MemorySegment name="$(FLASH_NAME:FLASH)">
    <ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START:)" />
    <ProgramSection alignment="4" load="Yes" name=".init" />
    <ProgramSection alignment="4" load="Yes" name=".init_rodata" />
    <ProgramSection alignment="4" load="Yes" name=".text" />
    <ProgramSection alignment="4" load="Yes" name=".dtors" />
    <ProgramSection alignment="4" load="Yes" name=".ctors" />
    <ProgramSection alignment="4" load="Yes" name=".rodata" />
    <ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
    <ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
    <ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
    <ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
    <ProgramSection alignment="4" keep="Yes" load="Yes" runin=".fs_data_run" name=".fs_data" />
  </MemorySegment>
  <MemorySegment name="$(RAM_NAME:RAM);SRAM">
    <ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START:$(SRAM_START:))" />
    <ProgramSection alignment="4" load="No" name=".fast_run" />
    <ProgramSection alignment="4" load="No" name=".data_run" />
    <ProgramSection alignment="4" load="No" name=".bss" />
    <ProgramSection alignment="4" load="No" name=".tbss" />
    <ProgramSection alignment="4" load="No" name=".tdata_run" />
    <ProgramSection alignment="4" load="No" name=".non_init" />
    <ProgramSection alignment="4" keep="Yes" load="No" name=".fs_data_run" address_symbol="__start_fs_data"  end_symbol="__stop_fs_data" />
    <ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
    <ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack" />
    <ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
  </MemorySegment>
  <MemorySegment name="$(FLASH2_NAME:FLASH2)">
    <ProgramSection alignment="4" load="Yes" name=".text2" />
    <ProgramSection alignment="4" load="Yes" name=".rodata2" />
    <ProgramSection alignment="4" load="Yes" runin=".data2_run" name=".data2" />
  </MemorySegment>
  <MemorySegment name="$(RAM2_NAME:RAM2)">
    <ProgramSection alignment="4" load="No" name=".data2_run" />
    <ProgramSection alignment="4" load="No" name=".bss2" />
  </MemorySegment>
</Root>
And here's my thumb_crt0.s file:
// *                    SEGGER Microcontroller GmbH                     *
// *                        The Embedded Experts                        *
// *            (c) 2014 - 2018 SEGGER Microcontroller GmbH             *
// *            (c) 2001 - 2018 Rowley Associates Limited               *
// *           www.segger.com     Support: [email protected]           *
// * All rights reserved.                                               *
// * Redistribution and use in source and binary forms, with or         *
// * without modification, are permitted provided that the following    *
// * conditions are met:                                                *
// * - Redistributions of source code must retain the above copyright   *
// *   notice, this list of conditions and the following disclaimer.    *
// * - Neither the name of SEGGER Microcontroller GmbH                  *
// *   nor the names of its contributors may be used to endorse or      *
// *   promote products derived from this software without specific     *
// *   prior written permission.                                        *
// * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND             *
// * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,        *
// * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF           *
// * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE           *
// * DISCLAIMED.                                                        *
// * IN NO EVENT SHALL SEGGER Microcontroller GmbH BE LIABLE FOR        *
// * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR           *
// * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT  *
// * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;    *
// * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF      *
// * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT          *
// * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE  *
// * USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH   *
// * DAMAGE.                                                            *
//                           Preprocessor Definitions
// APP_ENTRY_POINT
//   Defines the application entry point function, if undefined this setting
//   defaults to "main".
// INITIALIZE_STACK
//   If defined, the contents of the stack will be initialized to a the
//   value 0xCC.
// INITIALIZE_SECONDARY_SECTIONS
//   If defined, the .data2, .text2, .rodata2 and .bss2 sections will be initialized.
// INITIALIZE_TCM_SECTIONS
//   If defined, the .data_tcm, .text_tcm, .rodata_tcm and .bss_tcm sections
//   will be initialized.
// INITIALIZE_USER_SECTIONS
//   If defined, the function InitializeUserMemorySections will be called prior
//   to entering main in order to allow the user to initialize any user defined
//   memory sections.
// FULL_LIBRARY
//  If defined then
//    - argc, argv are setup by the debug_getargs.
//    - the exit symbol is defined and executes on return from main.
//    - the exit symbol calls destructors, atexit functions and then debug_exit.
//  If not defined then
//    - argc and argv are zero.
//    - the exit symbol is defined, executes on return from main and loops
#ifndef APP_ENTRY_POINT
#define APP_ENTRY_POINT main
#ifndef ARGSSPACE
#define ARGSSPACE 128
  .syntax unified
  .global _start
  .extern APP_ENTRY_POINT
  .global exit
  .weak exit
#ifdef INITIALIZE_USER_SECTIONS
  .extern InitializeUserMemorySections
  .section .init, "ax"
  .code 16
  .balign 2
  .thumb_func
_start:
  /* Set up main stack if size > 0 */
  ldr r1, =__stack_end__
  ldr r0, =__stack_start__
  subs r2, r1, r0
  beq 1f
#ifdef __ARM_EABI__
  movs r2, #0x7
  bics r1, r2
  mov sp, r1
#ifdef INITIALIZE_STACK
  movs r2, #0xCC
  bl memory_set
  /* Set up process stack if size > 0 */
  ldr r1, =__stack_process_end__
  ldr r0, =__stack_process_start__
  subs r2, r1, r0
  beq 1f
#ifdef __ARM_EABI__
  movs r2, #0x7
  bics r1, r2
  msr psp, r1
  movs r2, #2
  msr control, r2
  movs r2, #0xCC
  bl memory_set
  /* Copy initialized memory sections into RAM (if necessary). */
  ldr r0, =__data_load_start__
  ldr r1, =__data_start__
  ldr r2, =__data_end__
  bl memory_copy
  ldr r0, =__text_load_start__
  ldr r1, =__text_start__
  ldr r2, =__text_end__
  bl memory_copy
  ldr r0, =__fast_load_start__
  ldr r1, =__fast_start__
  ldr r2, =__fast_end__
  bl memory_copy
  ldr r0, =__ctors_load_start__
  ldr r1, =__ctors_start__
  ldr r2, =__ctors_end__
  bl memory_copy
  ldr r0, =__dtors_load_start__
  ldr r1, =__dtors_start__
  ldr r2, =__dtors_end__
  bl memory_copy
  ldr r0, =__rodata_load_start__
  ldr r1, =__rodata_start__
  ldr r2, =__rodata_end__
  bl memory_copy
  ldr r0, =__tdata_load_start__
  ldr r1, =__tdata_start__
  ldr r2, =__tdata_end__
  bl memory_copy
  ldr r0, =__fs_data_load_start__
  ldr r1, =__fs_data_start__
  ldr r2, =__fs_data_end__
#ifdef INITIALIZE_SECONDARY_SECTIONS
  ldr r0, =__data2_load_start__
  ldr r1, =__data2_start__
  ldr r2, =__data2_end__
  bl memory_copy
  ldr r0, =__text2_load_start__
  ldr r1, =__text2_start__
  ldr r2, =__text2_end__
  bl memory_copy
  ldr r0, =__rodata2_load_start__
  ldr r1, =__rodata2_start__
  ldr r2, =__rodata2_end__
  bl memory_copy
#endif /* #ifdef INITIALIZE_SECONDARY_SECTIONS */
#ifdef INITIALIZE_TCM_SECTIONS
  ldr r0, =__data_tcm_load_start__
  ldr r1, =__data_tcm_start__
  ldr r2, =__data_tcm_end__
  bl memory_copy
  ldr r0, =__text_tcm_load_start__
  ldr r1, =__text_tcm_start__
  ldr r2, =__text_tcm_end__
  bl memory_copy
  ldr r0, =__rodata_tcm_load_start__
  ldr r1, =__rodata_tcm_start__
  ldr r2, =__rodata_tcm_end__
  bl memory_copy
#endif /* #ifdef INITIALIZE_TCM_SECTIONS */
  /* Zero the bss. */
  ldr r0, =__bss_start__
  ldr r1, =__bss_end__
  movs r2, #0
  bl memory_set
  ldr r0, =__tbss_start__
  ldr r1, =__tbss_end__
  movs r2, #0
  bl memory_set
  ldr r0, =__bss2_start__
  ldr r1, =__bss2_end__
  mov r2, #0
  bl memory_set
  ldr r0, =__bss_tcm_start__
  ldr r1, =__bss_tcm_end__
  mov r2, #0
  bl memory_set
  /* Initialize the heap */
  ldr r0, = __heap_start__
  ldr r1, = __heap_end__
  subs r1, r1, r0
  cmp r1, #8
  blt 1f
  movs r2, #0
  str r2, [r0]
  adds r0, r0, #4
  str r1, [r0]
1:
  ldr r2, =InitializeUserMemorySections
  blx r2
  /* Call constructors */
  ldr r0, =__ctors_start__
  ldr r1, =__ctors_end__
ctor_loop:
  cmp r0, r1
  beq ctor_end
  ldr r2, [r0]
  adds r0, #4
  push {r0-r1}
  blx r2
  pop {r0-r1}
  b ctor_loop
ctor_end:
  /* Setup initial call frame */
  movs r0, #0
  mov lr, r0
  mov r12, sp
  .type start, function
start:
  /* Jump to application entry point */
#ifdef FULL_LIBRARY
  movs r0, #ARGSSPACE
  ldr r1, =args
  ldr r2, =debug_getargs
  blx r2
  ldr r1, =args
#else
  movs r0, #0
  movs r1, #0
  ldr r2, =APP_ENTRY_POINT
  blx r2
  .thumb_func
exit:
#ifdef FULL_LIBRARY
  mov r5, r0 // save the exit parameter/return result
  /* Call destructors */
  ldr r0, =__dtors_start__
  ldr r1, =__dtors_end__
dtor_loop:
  cmp r0, r1
  beq dtor_end
  ldr r2, [r0]
  add r0, #4
  push {r0-r1}
  blx r2
  pop {r0-r1}
  b dtor_loop
dtor_end:
  /* Call atexit functions */
  ldr r2, =_execute_at_exit_fns
  blx r2
  /* Call debug_exit with return result/exit parameter */
  mov r0, r5
  ldr r2, =debug_exit
  blx r2
  /* Returned from application entry point, loop forever. */
exit_loop:
  b exit_loop
  .thumb_func
memory_copy:
  cmp r0, r1
  beq 2f
  subs r2, r2, r1
  beq 2f
1:
  ldrb r3, [r0]
  adds r0, r0, #1
  strb r3, [r1]
  adds r1, r1, #1
  subs r2, r2, #1
  bne 1b
2:
  bx lr
  .thumb_func
memory_set:
  cmp r0, r1
  beq 1f
  strb r2, [r0]
  adds r0, r0, #1
  b memory_set
1:
  bx lr
  // default C/C++ library helpers
.macro HELPER helper_name
  .section .text.\helper_name, "ax", %progbits
  .balign 2
  .global \helper_name
  .weak \helper_name
\helper_name:
  .thumb_func
.endm
.macro JUMPTO name
#if defined(__thumb__) && !defined(__thumb2__)
  mov r12, r0
  ldr r0, =\name
  push {r0}
  mov r0, r12
  pop {pc}
#else
  b \name
.endm
HELPER __aeabi_read_tp
  ldr r0, =__tbss_start__-8
  bx lr
HELPER abort
  b .
HELPER __assert
  b .
HELPER __aeabi_assert
  b .
HELPER __sync_synchronize
  bx lr
HELPER __getchar
  JUMPTO debug_getchar
HELPER __putchar
  JUMPTO debug_putchar
HELPER __open
  JUMPTO debug_fopen
HELPER __close
  JUMPTO debug_fclose
HELPER __write
  mov r3, r0
  mov r0, r1
  movs r1, #1
  JUMPTO debug_fwrite
HELPER __read
  mov r3, r0
  mov r0, r1
  movs r1, #1
  JUMPTO debug_fread
HELPER __seek
  push {r4, lr}
  mov r4, r0
  bl debug_fseek
  cmp r0, #0
  bne 1f
  mov r0, r4
  bl debug_ftell
  pop {r4, pc}
1:
  ldr r0, =-1
  pop {r4, pc}
  // char __user_locale_name_buffer[];
  .section .bss.__user_locale_name_buffer, "aw", %nobits
  .global __user_locale_name_buffer
  .weak __user_locale_name_buffer
  __user_locale_name_buffer:
  .word 0x0
#ifdef FULL_LIBRARY
  .bss
args:
  .space ARGSSPACE
  /* Setup attibutes of stack and heap sections so they don't take up room in the elf file */
  .section .stack, "wa", %nobits
  .section .stack_process, "wa", %nobits
  .section .heap, "wa", %nobits
Anyone have any ideas?
