nrf52810 PWM issue
Hi All:
When I simulated PWM by GPIO, the output current noise was shown like the picture below (red circle area):
Cause it will lead to a loading issue in the backend, so I'm wondering the root cause and if there is any possible solution for this.
Any suggestion will be great. Thanks!!
Update working details:
SDK: 14.2
52810: QFAAB0 - 1740AC
Update code of generating PWM :
We use GPIOTE to simulate the PWM.
    #define  IO_KEY_PAIRING     15
    #define  IO_ZERO_X               31
     APP_ERROR_CHECK(nrf_drv_gpiote_init());
    nrf_drv_gpiote_in_config_t gpiote_config =
        .sense = NRF_GPIOTE_POLARITY_TOGGLE,
        .pull = NRF_GPIO_PIN_PULLUP,
        .is_watcher = false,
        .hi_accuracy = false
    APP_ERROR_CHECK(nrf_drv_gpiote_in_init(IO_KEY_PAIRING, &gpiote_config, gpiote_event_handler));
    nrf_drv_gpiote_in_event_enable(IO_KEY_PAIRING, true);
    gpiote_config.pull = NRF_GPIO_PIN_NOPULL;
    APP_ERROR_CHECK(nrf_drv_gpiote_in_init(IO_ZERO_X, &gpiote_config, gpiote_event_handler));
    nrf_drv_gpiote_in_event_enable(IO_ZERO_X, true);
In  gpiote_event_handler(), we generate PWM pulse according to IO_ZERO_X.
Update code of generating PWM  --- gpiote_event_handler()- :
static void gpiote_event_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    NRF_LOG_INFO("gpiote_event_handler");
    if (pin == IO_KEY_PAIRING)
        uint32_t read_value = nrf_gpio_pin_read(IO_KEY_PAIRING);
        if (!read_value)
            nrf_delay_ms(1);
            if (read_value == nrf_gpio_pin_read(IO_KEY_PAIRING))
                m_pairing_key_latch_for_on_off = 0x01;
                m_pairing_key_latch = 0x01;
    if (pin == IO_ZERO_X)
        controls_zero_x_trigger();//generate PWM
