I have a situation with the devices my company builds. From what I understand, they've been designed with a small flaw, which causes them to sometimes get stuck and require a hard reboot when (among other things) a certain service is running and a DFU update starts. Even worse, the production cards cannot be hard rebooted!
In order to avoid this situation, I have been tasked with creating an app that uses the technical solution of sending a command to stop the service (and the other things) before an update is attempted. However, in the case that an update is going on and the app dies (crash, user killed it, system reclaimed resources and killed it...), I'm stuck.
Is there any way I could check if the device is currently already in DFU mode, and get the current progress, without actually building a controller, which requires starting a firmware update, which might brick a non-dfu'ed device?
From what Aleksander said in a previous question I asked (https://devzone.nordicsemi.com/f/nordic-q-a/35930/reset-in-nordic-connect-versus-dfu-library-ios), I'm afraid my only option is to write down the DFUxxxxxxx identifier to disk, and when the app restarts check if I find it around, but I do hope there is a better solution I'm not aware of.
