NRF52 db discovery event has all characteristic uuids 0
when performing db discovering using a peripheral nrf52832 (running sample dfu project) from sdk 13 from a nrf32832 central on sdk 14 I notice that the db discovery event handler has each characteristic UUID of 0.
it is not possible to update either SDK at this moment for reasons i cannot get into.
my central side code for initializing the db discovery...:
ble_uuid128_t base_uuid        = { .uuid128 = DFU_SERVICE_UUID_128bit };
ble_uuid_t    dfu_service_uuid = { .uuid    = DFU_SERVICE_UUID_16bit };
uint32_t err_code = sd_ble_uuid_vs_add(&base_uuid, &dfu_service_uuid.type);
NRF_LOG_INFO("uuid vs add returned: %d/%04X", err_code, err_code);
/* register to get db discovery events for the dfu service */
ble_db_discovery_evt_register(&dfu_service_uuid);
ble_db_discovery_start(db_disc_handle, dfu_target->conn_handle);
and in my event handler:
uint32_t dfu_db_disc_evt_handler( ble_ript_acc_client_t *dfu_target,
                                  const ble_db_discovery_evt_t * const p_evt)
    if (p_evt->evt_type != BLE_DB_DISCOVERY_COMPLETE)
        return 0;
    // we only care about the dfu service UUIDs
    if (p_evt->params.discovered_db.srv_uuid.uuid == DFU_SERVICE_UUID_16bit)
        for (int i = 0; i < p_evt->params.discovered_db.char_count; i++)
            const ble_gatt_db_char_t *const disc_char = &p_evt->params.discovered_db.charateristics[i];
            NRF_LOG_INFO("%d: uuid: %04X cccd:%04X. value:%04X\n",
                    i,
                    disc_char->characteristic.uuid.uuid,
                    disc_char->cccd_handle,
                    disc_char->characteristic.handle_value);
when i run this, my output on RTT Client looks like this:
<info> app: uuid vs add returned: 0/0000
<info> app: 0: uuid: 0000 cccd:0000. value:0010
<info> app: 1: uuid: 0000 cccd:0013. value:0012
My 2 questions are:
1. Why are the characteristic UUIDs always 0?
2. why do i get 7 events for the same service?
    Noticed that you call ble_db_discovery_start() after ble_db_discovery_evt_register(). Please try to only call ble_db_discovery_start() from the BLE_GAP_EVT_CONNECTED to ensure that the service is discovered once.
    I couldn't tell from the code snippets you provided, but did you set dfu_service_uuid.type to BLE_UUID_TYPE_BLE? I was unable to replicate this with the code below.
    void dfu_c_init()
        uint32_t      err_code;
        ble_uuid_t    dfu_uuid;
        uint8_t       uuid_type = BLE_UUID_TYPE_VENDOR_BEGIN;
        /*Base UUIDs for DFU service characteristics*/
        ble_uuid128_t dfu_base_uuid =
                0x50, 0xEA, 0xDA, 0x30, 0x88, 0x83, 0xB8, 0x9F,
                0x60, 0x4F, 0x15, 0xF3,  0x00, 0x00, 0xC9, 0x8E
        dfu_uuid.type = BLE_UUID_TYPE_BLE;
        dfu_uuid.uuid = 0xFE59;
        err_code = sd_ble_uuid_vs_add(&dfu_base_uuid, &uuid_type);
        err_code = ble_db_discovery_evt_register(&dfu_uuid);
  • I know that I'm calling ble_db_discovery_start only once... otherwise my output would display "<info> app: uuid vs add returned: 0/0000" more than once, which it does not.
    regarding the uuid type, sd_ble_uuid_vs_add()'s 2nd parameter is and output, storing the uuid type into the unit8_t that is passed by adress on your code's line 20. so your assignment in line 17 is without impact per the documentation.  -- in my implementation, on line 4 i do the exact same thing as your reference so i'm not sure why you're asking about it... can you elaborate a bit more on your question?
    can you confirm the SDK version of the peripheral you were connecting with?
  • You're right, the 2nd parameter is an output. I just assumed it was input argument. Sorry for the confusion.
    I did not manage to reproduce the issues. I used the pre-compiled bootloader hex in sdk 13 and modified the uart central example to discover the DFU service. So I'm not sure what the problem is.  Suggest that you do a comparison of your implementation with attached main.c and see if you can spot any relevant differences (verify that we are using same UUIDs etc).
    <info> app: Connected to target
    <info> app: 0: uuid: 0002 cccd:0000. value:0010
    <info> app: 1: uuid: 0001 cccd:0013. value:0012
     * Copyright (c) 2016 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdio.h>
    #include <stdint.h>
    #include <stdbool.h>
    #include "nordic_common.h"
    #include "app_error.h"
    #include "app_uart.h"
    #include "ble_db_discovery.h"
    #include "app_timer.h"
    #include "app_util.h"
    #include "bsp_btn_ble.h"
    #include "ble.h"
    #include "ble_gap.h"
    #include "ble_hci.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_pwr_mgmt.h"
    #include "ble_advdata.h"
    #include "ble_nus_c.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG    1                                       /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
    #define APP_BLE_OBSERVER_PRIO   3                                       /**< Application's BLE observer priority. You shoulnd't need to modify this value. */
    #define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
    #define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
    #define SCAN_INTERVAL           0x00A0                                  /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW             0x0050                                  /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_TIMEOUT            0x0000                                  /**< Timout when scanning. 0x0000 disables timeout. */
    #define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS)         /**< Determines minimum connection interval in millisecond. */
    #define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS)         /**< Determines maximum connection interval in millisecond. */
    #define SLAVE_LATENCY           0                                       /**< Determines slave latency in counts of connection events. */
    #define SUPERVISION_TIMEOUT     MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Determines supervision time-out in units of 10 millisecond. */
    #define UUID16_SIZE             2                                       /**< Size of 16 bit UUID */
    #define UUID32_SIZE             4                                       /**< Size of 32 bit UUID */
    #define UUID128_SIZE            16                                      /**< Size of 128 bit UUID */
    #define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service back to the sender. */
    BLE_NUS_C_DEF(m_ble_nus_c);                                             /**< BLE NUS service client instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< DB discovery module instance. */
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    /**@brief Connection parameters requested for connection. */
    static ble_gap_conn_params_t const m_connection_param =
        (uint16_t)MIN_CONNECTION_INTERVAL,  // Minimum connection
        (uint16_t)MAX_CONNECTION_INTERVAL,  // Maximum connection
        (uint16_t)SLAVE_LATENCY,            // Slave latency
        (uint16_t)SUPERVISION_TIMEOUT       // Supervision time-out
    /** @brief Parameters used when scanning. */
    static ble_gap_scan_params_t const m_scan_params =
        .active   = 1,
        .interval = SCAN_INTERVAL,
        .window   = SCAN_WINDOW,
        .timeout  = SCAN_TIMEOUT,
        #if (NRF_SD_BLE_API_VERSION <= 2)
            .selective   = 0,
            .p_whitelist = NULL,
        #if (NRF_SD_BLE_API_VERSION >= 3)
            .use_whitelist = 0,
    /**@brief NUS uuid. */
    static ble_uuid_t const m_nus_uuid =
        .uuid = BLE_UUID_NUS_SERVICE,
        .type = NUS_SERVICE_UUID_TYPE
    /**@brief Function for asserts in the SoftDevice.
     * @param[in] line_num     Line number of the failing ASSERT call.
     * @param[in] p_file_name  File name of the failing ASSERT call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function to start scanning. */
    static void scan_start(void)
        ret_code_t ret;
        ret = sd_ble_gap_scan_start(&m_scan_params);
        APP_ERROR_CHECK(ret);
        ret = bsp_indication_set(BSP_INDICATE_SCANNING);
    /**@brief Function for handling database discovery events.
     * @details This function is callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function should forward the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        //ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
            return;
        if (p_evt->params.discovered_db.srv_uuid.uuid == 0xFE59)
                        i,
    /**@brief Function for handling characters received by the Nordic UART Service.
     * @details This function takes a list of characters of length data_len and prints the characters out on UART.
     *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
    static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
        ret_code_t ret_val;
        NRF_LOG_DEBUG("Receiving data.");
        NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
        for (uint32_t i = 0; i < data_len; i++)
            do
                ret_val = app_uart_put(p_data[i]);
                if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                    APP_ERROR_CHECK(ret_val);
            } while (ret_val == NRF_ERROR_BUSY);
        if (p_data[data_len-1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
        if (ECHOBACK_BLE_UART_DATA)
            // Send data back to peripheral.
            do
                ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
        static uint16_t index = 0;
        uint32_t ret_val;
        switch (p_event->evt_type)
            /**@snippet [Handling data from UART] */
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                    do
                        ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
                        if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_BUSY) )
                    index = 0;
                NRF_LOG_ERROR("Communication error occurred while handling UART.");
            case APP_UART_FIFO_ERROR:
                NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
    /**@brief Callback handling NUS Client events.
     * @details This function is called to notify the application of NUS client events.
     * @param[in]   p_ble_nus_c   NUS Client Handle. This identifies the NUS client
     * @param[in]   p_ble_nus_evt Pointer to the NUS Client event.
    /**@snippet [Handling events from the ble_nus_c module] */
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
        ret_code_t err_code;
        switch (p_ble_nus_evt->evt_type)
            case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
                NRF_LOG_INFO("Discovery complete.");
                err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
                err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
                NRF_LOG_INFO("Connected to device with Nordic UART Service.");
            case BLE_NUS_C_EVT_NUS_TX_EVT:
                ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            case BLE_NUS_C_EVT_DISCONNECTED:
                NRF_LOG_INFO("Disconnected.");
                scan_start();
     * @brief Function for shutdown events.
     * @param[in]   event       Shutdown type.
    static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
                // Prepare wakeup buttons.
        return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    /**@brief Reads an advertising report and checks if a UUID is present in the service list.
     * @details The function is able to search for 16-bit, 32-bit and 128-bit service UUIDs.
     *          To see the format of a advertisement packet, see
     *          https://www.bluetooth.org/Technical/AssignedNumbers/generic_access_profile.htm
     * @param[in]   p_target_uuid The UUID to search for.
     * @param[in]   p_adv_report  Pointer to the advertisement report.
     * @retval      true if the UUID is present in the advertisement report. Otherwise false
    static bool is_uuid_present(ble_uuid_t               const * p_target_uuid,
                                ble_gap_evt_adv_report_t const * p_adv_report)
        ble_uuid_t   extracted_uuid;
        uint16_t     index  = 0;
        uint8_t    * p_data = (uint8_t *)p_adv_report->data;
        while (index < p_adv_report->dlen)
            uint8_t field_length = p_data[index];
            uint8_t field_type   = p_data[index + 1];
            if (   (field_type == BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_MORE_AVAILABLE)
                || (field_type == BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_COMPLETE))
                for (uint32_t i = 0; i < (field_length / UUID16_SIZE); i++)
                    err_code = sd_ble_uuid_decode(UUID16_SIZE,
                                                  &p_data[i * UUID16_SIZE + index + 2],
                                                  &extracted_uuid);
                    if (err_code == NRF_SUCCESS)
                        if (extracted_uuid.uuid == p_target_uuid->uuid)
                            return true;
            else if (   (field_type == BLE_GAP_AD_TYPE_32BIT_SERVICE_UUID_MORE_AVAILABLE)
                     || (field_type == BLE_GAP_AD_TYPE_32BIT_SERVICE_UUID_COMPLETE))
                for (uint32_t i = 0; i < (field_length / UUID32_SIZE); i++)
                    err_code = sd_ble_uuid_decode(UUID32_SIZE,
                                                  &p_data[i * UUID32_SIZE + index + 2],
                                                  &extracted_uuid);
                        if (   (extracted_uuid.uuid == p_target_uuid->uuid)
                            && (extracted_uuid.type == p_target_uuid->type))
                            return true;
            else if (   (field_type == BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_MORE_AVAILABLE)
                     || (field_type == BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_COMPLETE))
                err_code = sd_ble_uuid_decode(UUID128_SIZE, &p_data[index + 2], &extracted_uuid);
                        return true;
            index += field_length + 1;
        return false;
    /**@brief Variable length data encapsulation in terms of length and pointer to data */
    typedef struct
        uint8_t  * p_data;      /**< Pointer to data. */
        uint16_t   data_len;    /**< Length of data. */
    } data_t;
     * @brief Parses advertisement data, providing length and location of the field in case
     *        matching data is found.
     * @param[in]  Type of data to be looked for in advertisement data.
     * @param[in]  Advertisement report length and pointer to report.
     * @param[out] If data type requested is found in the data report, type data length and
     *             pointer to data will be populated here.
     * @retval NRF_SUCCESS if the data type is found in the report.
     * @retval NRF_ERROR_NOT_FOUND if the data type could not be found.
    static uint32_t adv_report_parse(uint8_t type, data_t * p_advdata, data_t * p_typedata)
        uint32_t  index = 0;
        uint8_t * p_data;
        p_data = p_advdata->p_data;
        while (index < p_advdata->data_len)
            if (field_type == type)
                p_typedata->p_data   = &p_data[index + 2];
                p_typedata->data_len = field_length - 1;
                return NRF_SUCCESS;
        return NRF_ERROR_NOT_FOUND;
    static bool find_adv_name(ble_gap_evt_adv_report_t const * p_adv_report, char const * name_to_find)
        data_t     adv_data;
        data_t     dev_name;
        // Initialize advertisement report for parsing
        adv_data.p_data   = (uint8_t *)p_adv_report->data;
        adv_data.data_len = p_adv_report->dlen;
        //search for advertising names
        err_code = adv_report_parse(BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME, &adv_data, &dev_name);
            if (memcmp(name_to_find, dev_name.p_data, dev_name.data_len) == 0)
                return true;
        return false;
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            case BLE_GAP_EVT_ADV_REPORT:
                ble_gap_evt_adv_report_t const * p_adv_report = &p_gap_evt->params.adv_report;
                if (find_adv_name(p_adv_report, "DfuTarg"))
                    err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
                                                  &m_scan_params,
                                                  &m_connection_param,
                                                  APP_BLE_CONN_CFG_TAG);
                        // scan is automatically stopped by the connect
                        NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                                 p_adv_report->peer_addr.addr[0],
                                 p_adv_report->peer_addr.addr[1],
                                 p_adv_report->peer_addr.addr[2],
                                 p_adv_report->peer_addr.addr[3],
                                 p_adv_report->peer_addr.addr[4],
                                 p_adv_report->peer_addr.addr[5]
            }break; // BLE_GAP_EVT_ADV_REPORT
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected to target");
                err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
                // start discovery of services. The NUS Client waits for a discovery result
                err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
            case BLE_GAP_EVT_TIMEOUT:
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
                    NRF_LOG_INFO("Scan timed out.");
                    scan_start();
                else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_INFO("Connection Request timed out.");
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accepting parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                        &p_gap_evt->params.conn_param_update_request.conn_params);
    #ifndef S140
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
            NRF_LOG_INFO("ATT MTU exchange completed.");
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, 23);// NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in] event  Event generated by button press.
        switch (event)
            case BSP_EVENT_SLEEP:
                nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
    /**@brief Function for initializing the UART. */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    /**@brief Function for initializing the NUS Client. */
    static void nus_c_init(void)
        ble_nus_c_init_t init;
        init.evt_handler = ble_nus_c_evt_handler;
        err_code = ble_nus_c_init(&m_ble_nus_c, &init);
    /**@brief Function for initializing buttons and leds. */
    static void buttons_leds_init(void)
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LED, bsp_event_handler);
    /**@brief Function for initializing the timer. */
    static void timer_init(void)
    /**@brief Function for initializing the nrf log module. */
    static void log_init(void)
    /**@brief Function for initializing the Power manager. */
    static void power_init(void)
        ret_code_t err_code = nrf_pwr_mgmt_init();
    /** @brief Function for initializing the Database Discovery Module. */
    static void db_discovery_init(void)
        ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
    void dfu_c_init()
        uint32_t      err_code;
        log_init();
        timer_init();
        power_init();
        uart_init();
        buttons_leds_init();
        db_discovery_init();
        ble_stack_init();
        gatt_init();
        //nus_c_init();
        dfu_c_init();
        // Start scanning for peripherals and initiate connection
        // with devices that advertise NUS UUID.
        printf("BLE UART central example started.\r\n");
        NRF_LOG_INFO("BLE UART central example started.");
        scan_start();
        for (;;)
                nrf_pwr_mgmt_run();
                //ble_db_discovery_start(&m_db_disc, 0);
