I'm trying to test the BLE Mesh example. I want to prove that whether the feature of Relay is able to work or not. So, I use the functionality of heartbeat publishing to test it. At first, the first provisioning is finished, the provisionee begins publishing the Heartbeat state to the provisioner. I can also use the command "config_client_relay_get" and "config_client_relay_set" to get and set the parameter. Upon the second provisioning finished, the previous provisionees can't receive any commands. I also found why it can't send the command to the specific address.
In the config_client.c
static config_client_t m_client;
static uint32_t send_reliable(config_opcode_t opcode, uint16_t length, config_opcode_t reply_opcode)
access_reliable_t reliable;
reliable.model_handle = m_client.model_handle;
I got some questions as below.
1.How to enable the provisionee to re-start publishing the Heartbeat state to provisioner?
2.How to send the command listed in the "opcode_handlers" array to any provisioned device?
