timer deviation nrf52840 sdk15.0 s140
Hello, i have a central card nrf52840 and several peripheral cards nrf52840.
I have a program that allows me to launch the timer on the central and peripherals at the same time. The peripherals send their timers to the central station and the central station compares its timer with the one received.
I have a connection interval of 62.5 ms and a connection time of 7.8ms.
When I have a central connection and 1 peripheral: I have a drift only 3 second on 16h00.
But when I have a central 2 peripheral connection: I have a drift of 1 second after a few minutes.  and i don't why  if if anyone can help me.
Here is the central code:
const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(1);
uint32_t compteurTimer;
uint32_t compteur;
uint32_t compteur2;
uint32_t compteur3;
uint32_t compteur4;
void timer_led_event_handler(nrf_timer_event_t event_type, void* p_context){
switch (event_type)
case NRF_TIMER_EVENT_COMPARE0:
compteur2++;
compteur3++;
compteur++;
compteur4++;
if(compteur==1000){
//NRF_LOG_INFO("dif_Cent_Perip = %d",dif_Cent_Perip);
compteur = 0;
if(compteur3==6250){
compteurTimer=compteur2;
compteur3=0;
if(compteur4==100000){
tmp=2;
compteur4=0;
//Do nothing.
void test(){
NRF_LOG_INFO("test");
uint32_t time_us = 10; //Time(in microsecond) between consecutive compare events.
uint32_t time_ticks;
uint32_t err_code = NRF_SUCCESS;
//Configure all leds on board.
//Configure TIMER_LED for generating simple light effect - leds on board will invert his state one after the other.
err_code = nrf_drv_timer_init(&TIMER_LED, &timer_cfg, timer_led_event_handler);
NRF_LOG_INFO("err_code %d",err_code);
time_ticks = nrf_drv_timer_us_to_ticks(&TIMER_LED, time_us);
nrf_drv_timer_extended_compare(
&TIMER_LED, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
nrf_drv_timer_enable(&TIMER_LED);
Here is the peripheral code:
uint32_t compteur;
uint32_t compteur2;
uint32_t compteur3;
uint32_t tab[20] ={0};
int d = 0;
int f;
int x ;
switch (event_type)
d++;
compteur++;
//Do nothing.
void test(){
uint32_t time_us =10; //Time(in miliseconds) between consecutive compare events.
thank's
  • the central code:
    int x =0 ;
    uint32_t datatab[11]={0}; // table to save data
    uint32_t CompteurCentral[11]={0};
    uint32_t tab_dif_Cent_Perip[11]={0};
    uint32_t dif2 ;
    uint32_t i = 0;
    uint32_t dif_Cent_Perip;
    uint32_t delta_dif ;
    uint32_t cpt=0;
    static int tmp = 0;////timer&&compteur//////////////////////////////
    uint32_t compteur;
    uint32_t compteur2;
    uint32_t compteur3;
    uint32_t compteur4;
        switch (event_type)
    				compteur2++;
    				compteur3++;
    				compteur++;
    				compteur4++;
    				if(compteur==1000){
    					compteur = 0;
    					compteur3=0;
    				tmp=2;
    					compteur4=0;
                //Do nothing.
    }static void cid_c_evt_handler(ble_cid_c_t * p_cid_c, ble_cid_c_evt_t * p_cid_c_evt)
        ret_code_t err_code;
    		static float moyenne[NRF_SDH_BLE_CENTRAL_LINK_COUNT] = {0};
    		static float timer[NRF_SDH_BLE_CENTRAL_LINK_COUNT] = {0};
    		static int compteur[NRF_SDH_BLE_CENTRAL_LINK_COUNT] ={0};
    		static uint64_t time_actu[NRF_SDH_BLE_CENTRAL_LINK_COUNT]={0};
    		static uint64_t time_diff[NRF_SDH_BLE_CENTRAL_LINK_COUNT]={0};
    		static uint8_t num_data[NRF_SDH_BLE_CENTRAL_LINK_COUNT];
    		static float  time_con[NRF_SDH_BLE_CENTRAL_LINK_COUNT]= {0};
    		//etat gpiote
    		nrf_drv_gpiote_init();
    		nrf_gpio_cfg_input(7,NRF_GPIO_PIN_PULLDOWN);
    		uint16_t state = nrf_gpio_pin_read(7);
    		state = 1;
        switch (p_cid_c_evt->evt_type)
            case BLE_CID_C_EVT_DISCOVERY_COMPLETE:
                NRF_LOG_INFO("Cidelec service discovered.");
                err_code = ble_cid_c_handles_assign(p_cid_c,
                                                    p_cid_c_evt->conn_handle,
                                                    &p_cid_c_evt->params.peer_db);
                // Initiate bonding.
                err_code = pm_conn_secure(p_cid_c_evt->conn_handle, false);
    						//param_conn.m_conn_handle=p_cid_c->conn_handle;
    						m_cid_c[p_cid_c->conn_handle].conn_handle=p_cid_c->conn_handle;
            } break;
            case BLE_CID_C_EVT_NOTIFICATION_SIMPLE_DATA_RECEIVE:
    					bsp_board_led_invert(BSP_BOARD_LED_2);
    //					for(uint8_t i=0;i<p_cid_c_evt->params.cid_data.data_length;i++){
    //						if(p_cid_c_evt->params.cid_data.data[i]!=i){
    //							NRF_LOG_INFO("erreur:mauvaise donnée recu");
    //							i=250;
    					if(param_conn[p_cid_c_evt->conn_handle].test_debit.etat_test){
    						param_conn[p_cid_c_evt->conn_handle].test_debit.data_receive+=p_cid_c_evt->params.cid_data.data_length;
    					}else if(data_1_16[p_cid_c_evt->conn_handle].etat_test){
    						//décalage pour récuper la valeur en 32 bit (8 bit -> 32 bit)
    						cpt = p_cid_c_evt->params.cid_data.data[0]+(p_cid_c_evt->params.cid_data.data[1]*256)+(p_cid_c_evt->params.cid_data.data[2]*65356)+(p_cid_c_evt->params.cid_data.data[3]*16777216);
    						x++;
    						//NRF_LOG_INFO("num_data=%d for conn %d",num_data[p_cid_c_evt->conn_handle],p_cid_c_evt->conn_handle);
    				   // NRF_LOG_INFO("-----------------------------------------------------------" );
    						//NRF_LOG_INFO("Connexion %d", p_cid_c_evt->conn_handle);
    						datatab[x] = cpt; // put data on the table
    						CompteurCentral[x] = compteurTimer; // tableau compteur central
    						dif_Cent_Perip = CompteurCentral[x] - datatab[x];  // différence entre central et peripheral
    						tab_dif_Cent_Perip[x] = dif_Cent_Perip ; //tableau différence entre central et peripheral
    					//	NRF_LOG_INFO("data_receive=%d from conn%d time_data=%d",cpt, p_cid_c_evt->conn_handle, time_diff[p_cid_c_evt->conn_handle]);
    					//	NRF_LOG_INFO("CompteurCentral = %d",CompteurCentral[x]);
    						//NRF_LOG_INFO("%d",dif_Cent_Perip);
    						if(tmp==2){
    							NRF_LOG_INFO("ce= %d, p1= %d, ce= %d, p2 = %d",CompteurCentral[x-1],datatab[x-1],CompteurCentral[x],datatab[x] );
    							tmp = 0;
    						if(datatab[x-1]>datatab[x]){
    							dif2 = datatab[x-1]-datatab[x];	//compare of two values Con0 Con1
    						else{
    							dif2 = datatab[x]-datatab[x-1]; //compare of two values
    						if(tab_dif_Cent_Perip[x-1]>tab_dif_Cent_Perip[x]){
    							delta_dif = tab_dif_Cent_Perip[x-1] - tab_dif_Cent_Perip[x];
    							//NRF_LOG_INFO("delta_dif = %d",delta_dif);
    						else{
    							delta_dif = tab_dif_Cent_Perip[x] - tab_dif_Cent_Perip[x-1];
    						//NRF_LOG_INFO("dif_Cent_Perip = %d ", dif_Cent_Perip);
    						//NRF_LOG_INFO("delta_dif =  %d" ,delta_dif);
    						//NRF_LOG_INFO("datatab X =  %d" ,datatab[x]);
    						//NRF_LOG_INFO("datatab X-1 =  %d" ,datatab[x-1]);
    						if(x==10){
    							uint32_t f = datatab[x];
    							uint32_t f2 = tab_dif_Cent_Perip[x];
    							uint32_t f3 = CompteurCentral[x];
    							for(i = 0; i<=x;i++){
    									datatab[i]=0;
    								tab_dif_Cent_Perip[i]=0;
    								CompteurCentral[i]=0;
    							datatab[0]=f;
    							tab_dif_Cent_Perip[0] =f2;
    							CompteurCentral[0]=f3;
    							x=0;
    					//	 NRF_LOG_INFO("décalage valeur tab[0]= %d",datatab[0] );
    						data_1_16[p_cid_c_evt->conn_handle].data_receive+=p_cid_c_evt->params.cid_data.data_length;
    						state =1;
    						//NRF_LOG_INFO("EtatData = %d",state);
    						//NRF_LOG_INFO("data_receive=%d from conn%d time_data=%d",data_1_16[p_cid_c_evt->conn_handle].data_receive, p_cid_c_evt->conn_handle, time_diff[p_cid_c_evt->conn_handle]);
    					}else{
    						//NRF_LOG_INFO("data_receive:%d octets from conn %d",p_cid_c_evt->params.cid_data.data_length,p_cid_c_evt->conn_handle);
    					//	NRF_LOG_INFO("EtatData = %d",state);
            } break;
    The peripheral code :
    uint32_t compteur;
    uint32_t compteur2;
    uint32_t compteur3;
    int d = 0;
    int f;
    int x ;
        switch (event_type)
            d++;
    		compteur++;
                //Do nothing.
    void test(){
    tatic void data_send_timeout_handler(void * p_context)
    	bsp_board_led_on(BSP_BOARD_LED_3);
    	ret_code_t err_code=20;
    	uint32_t data_send=DATA_TO_SEND_IN_INTERVAL;
    	static const uint8_t data_length=243;
    	static uint8_t data_cid[data_length];
    	static bool all_data_send=1;
    	static uint32_t num_data=0;
    	static int i =0;
    	uint32_t tmp;
    	tmp = compteur ;
    	if(data_send<DATA_TO_SEND_IN_INTERVAL){
    		all_data_send=0;
    	if(param_conn.periph_to_central && all_data_send && test_1_16){
    		if(i == 0){
    			test();
    			i=1;
    	//	NRF_LOG_INFO("num_data=%d",num_data);
    		data_cid[0]=(tmp >> 0)& 0xFF;
    		data_cid[1]=(tmp >> 8)& 0xFF;
    		data_cid[2]=(tmp >> 16)& 0xFF;
    		data_cid[3]=(tmp >> 24)& 0xFF;
    		data_send=0;
    		/*for(int x = 0; x<=3;x++){
    		NRF_LOG_INFO("data_cid %d = %d",x,data_cid[x]);
    		//send start
    		while(err_code!=NRF_SUCCESS){
    			err_code=ble_cid_measurement_send(&m_cid,&data_cid[0],1,DATA_1_16_START_FLAG);
    			if ((err_code != NRF_SUCCESS) &&
    							(err_code != NRF_ERROR_INVALID_STATE) &&
    							(err_code != NRF_ERROR_BUSY) &&
    							(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
    					APP_ERROR_HANDLER(err_code);
    				if(m_cid.conn_handle==BLE_CONN_HANDLE_INVALID || !param_conn.periph_to_central){
    					return;
    		err_code=20;
    		//NRF_LOG_INFO("send start");
    		//send data
    		while(data_send<DATA_TO_SEND_IN_INTERVAL){
    				bsp_board_led_on(BSP_BOARD_LED_2);
    				if(data_send+data_length<DATA_TO_SEND_IN_INTERVAL){
    					err_code = ble_cid_measurement_send(&m_cid, data_cid, data_length,SIMPLE_DATA_SEND_FLAG);
    				}else{
    					err_code = ble_cid_measurement_send(&m_cid, data_cid, DATA_TO_SEND_IN_INTERVAL-data_send,SIMPLE_DATA_SEND_FLAG);
    				bsp_board_led_off(BSP_BOARD_LED_2);
    					return;
    			err_code=20;
    			data_send+=data_length;
    		all_data_send=1;
    		s
  • Not sure if I quite understand the resolution of your timer ticks here, but I recommend to have them to minimum 1ms. If you have very small ticks (e.g. in the tens of us), then the interrupts will be blocked during BLE events, this will work as long as the communication is 1:1 (since both are blocked equally much), but will not work in a 1:2 (since then the central will be blocked twize as much.Can that be the case?
    Possible easier would be to use an app_timer (RTC) with 1ms interval that increment an 1ms counter value. You can always have finer resolution by using timer when needed.
  • ok thank's you but how i how to do  app_timer (RTC) with a 1 ms interval that increments a counter reading by 1 ms?
  • I have changed my timer, my counter increments every ms but now I have a problem with my send I can no longer store the counter reading in the table.
    static void lfclk_request(void)
        ret_code_t err_code = nrf_drv_clock_init();
    		NRF_LOG_INFO("LFCLK: off");
        if(nrf_drv_clock_lfclk_is_running()){
    		NRF_LOG_INFO("LFCLK: ON");
    static void timer_sd_handler(void * p_context){
    	compteur++;
    //	NRF_LOG_INFO("%d",compteur);
    void test(){
    	// Initialize timer module.
    	err_code = app_timer_init();
    	// Create timers
    	err_code = app_timer_create(&sd_timer_id,APP_TIMER_MODE_REPEATED,timer_sd_handler);
    	NRF_LOG_INFO("");
    	NRF_LOG_INFO("Timer_sd_start");
    	err_code = app_timer_start(sd_timer_id, SD_SAVE_DATA_INTERVAL, NULL);
    static void data_send_timeout_handler(void * p_context)
    	static int i =0;
    	uint32_t tmp;
    	tmp = compteur ;
    		all_data_send=0;
    //		NRF_LOG_INFO("1/16second");
    //		if(data_cid[30]!=29){
    //			for(uint8_t i=0;i<data_length;i++){
    //				data_cid[i]=i;
    		if(i == 0){
    			test();
    			i=1;
    	//!!!!!!!!!!!!!!!!!!!here i have a problem !!!!!!!!!!!!!!!!!//////////////////
    		//NRF_LOG_INFO("num_data=%d",num_data);
    		data_send=0;
    		//send start
    					return;
    		err_code=20;
    		//send data
    				}else{
    					return;
    			err_code=20;
    		all_data_send=1;
  • Now  i can send mi counter but it's the same, there are a big diference into conter central and conteur peripheral
