When to TX and when to RX
I am evaluating a front end module by skyworks 66111 output power is ~14dBm. The FEM requires that logic dictate when to transmit and when to receive. When CRX, pin 17, is low and CTX, pin 19 is high, the device is transmitting. In the opposite configuration the device is receiving. The only other configuration allowable is when both are zero or the device is sleeping. I would like to get a test set up as easily as possible to see accurate bidirectional communication, but could start with unidirectional if necessary. I could use some guidance with creating firmware for the two pins connected from the nRF52832 toggling the state of the FEM in accordance with the nRF52832 radio needing to receive or transmit and the state of the soft stack.
Thank you for your consideration of my problem.
Cy Drollinger
Electronic Realization
