I'm aware of the limitations on using "printf" in a non-debug environment, but apparently there must be something similar with sprintf. I'm using it to load a value into a brief string for transmission over BLE. This works perfectly while debugging - the value is sent using ble_nus_string_send() and is received by the Central as expected. However, when I disconnect the debugger and run in production mode, the notification works but the characteristic value comes through as a null string.
This does not appear to be causing any sort of error or fault - the connection is maintained, the other functions of the board work as expected.
Using SDK v12.3 on an nRF51822 custom board. Building with SES.
Anyone know how to fix this?
