How to know nRF52832 UART tx memory?
Hi, I'm using external board with nRF52832. (SDK 15.0.0)
In my external board, there are no RTS,CTS pin. So I don't use hardware flow control (HWFC).
The problem is, I have to flush tx memory when memory is full but I don't know how to check it.
I rarely use tx memory that flushing every sec or minute seems to waste of power.
How can I know that tx memory is full?
  • Could you provide some code of the program, in order to get a better understanding of your situation?
  • static void nus_data_handler(ble_nus_evt_t * p_evt)
    						if(p_evt->params.rx_data.p_data[0]== '0')
    								nrf_gpio_pin_write(13,0);//turn off motor
    						else if(p_evt->params.rx_data.p_data[0]== '1')
    								if(nrf_gpio_pin_read(8))
    									nrf_gpio_pin_write(13,1); //Turn on motor
    									pin8=true;
    								else if(nrf_gpio_pin_read(15))
    									pin15=true;
    This above code is modified code from UART example.
    I control motor through uart tx data ( 0: turn off , 1: turn on ) and now I want to add some more code.
    When I add more code that use tx data, it cause error. ( Suddenly disconnect BLE )
    So I think I have to flush tx fifo memory.
    Am I missunderstanding??
    Thanks for repling.
