To merge ble_app_uart peripheral into ble_app_uart central to make it as both central and peripheral!!!!!
I am trying to merge ble_app_uart peripheral example to ble_app_uart central to make it as to work both central and peripheral at a time.
I am using nrf52 boards and SDK15.
I combined them both, the code is error free but it is not printing anything on teraterm and it is neither scanning nor advertising.
 * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "nrf.h"//add
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_advdata.h"
#include "ble_advertising.h"//add
#include "ble_conn_params.h"//add
#include "nrf_ble_qwr.h"//add
#include "ble_nus.h"//add
#include "app_util_platform.h"//add
#include "ble_nus_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#define PERIPHERAL_ADVERTISING_LED      BSP_BOARD_LED_2
#define PERIPHERAL_CONNECTED_LED        BSP_BOARD_LED_3
#define CENTRAL_SCANNING_LED            BSP_BOARD_LED_0
#define CENTRAL_CONNECTED_LED           BSP_BOARD_LED_1
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG    1                                       /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO   3                                       /**< Application's BLE observer priority. You shoulnd't need to modify this value. */
#define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
#define SCAN_INTERVAL           0x00A0                                  /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW             0x0050                                  /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION           0x0000                                  /**< Timout when scanning. 0x0000 disables timeout. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS)         /**< Determines minimum connection interval in millisecond. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS)         /**< Determines maximum connection interval in millisecond. */
#define SLAVE_LATENCY           0                                       /**< Determines slave latency in counts of connection events. */
#define SUPERVISION_TIMEOUT     MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Determines supervision time-out in units of 10 millisecond. */
#define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service back to the sender. */
//..............FOR UART PERIPHERAL................
#define DEVICE_NAME                     "Nordic_UART"
#define APP_ADV_INTERVAL                300                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
        /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3
#define DEAD_BEEF                       0xDEADBEEF
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
static ble_nus_t m_nus;                                             /**< Heart rate service instance. */                                          /**< Running speed and cadence service instance. */
static ble_nus_c_t m_nus_c;                                         /**< Heart rate service client instance. */
/**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
/**< Number of attempts before giving up the connection parameter negotiation. */
/**< The advertising duration (180 seconds) in units of 10 milliseconds. */
BLE_NUS_C_DEF(m_ble_nus_c);                                             /**< BLE NUS service client instance. */
//NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< DB discovery module instance. */
//static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief Connection parameters requested for connection. */
static ble_gap_conn_params_t const m_connection_param =
    (uint16_t)MIN_CONNECTION_INTERVAL,  // Minimum connection
    (uint16_t)MAX_CONNECTION_INTERVAL,  // Maximum connection
    (uint16_t)SLAVE_LATENCY,            // Slave latency
    (uint16_t)SUPERVISION_TIMEOUT       // Supervision time-out
static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
/**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
static ble_data_t m_scan_buffer =
    m_scan_buffer_data,
/** @brief Parameters used when scanning. */
static ble_gap_scan_params_t const m_scan_params =
    .active   = 1,
    .interval = SCAN_INTERVAL,
    .window   = SCAN_WINDOW,
    .timeout          = SCAN_DURATION,
    .scan_phys        = BLE_GAP_PHY_1MBPS,
    .filter_policy    = BLE_GAP_SCAN_FP_ACCEPT_ALL,
/**@brief NUS uuid. */
static ble_uuid_t const m_nus_uuid =
    .uuid = BLE_UUID_NUS_SERVICE,
    .type = NUS_SERVICE_UUID_TYPE
/**@brief Function for asserts in the SoftDevice.
 * @param[in] line_num     Line number of the failing ASSERT call.
 * @param[in] p_file_name  File name of the failing ASSERT call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function to start scanning. */
static void scan_start(void)
    ret_code_t ret;
    ret = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
    APP_ERROR_CHECK(ret);
    ret = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for handling database discovery events.
 * @details This function is callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function should forward the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
/**@brief Function for handling characters received by the Nordic UART Service.
 * @details This function takes a list of characters of length data_len and prints the characters out on UART.
 *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
        do
            ret_val = app_uart_put(p_data[i]);
            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                APP_ERROR_CHECK(ret_val);
        } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
        while (app_uart_put('\n') == NRF_ERROR_BUSY);
    if (ECHOBACK_BLE_UART_DATA)
        // Send data back to peripheral.
        do
            ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    static uint16_t index = 0;
    uint32_t ret_val;
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                do
                    ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
                    if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_BUSY) )
                index = 0;
            NRF_LOG_ERROR("Communication error occurred while handling UART.");
        case APP_UART_FIFO_ERROR:
            NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling NUS Client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS Client Handle. This identifies the NUS client
 * @param[in]   p_ble_nus_evt Pointer to the NUS Client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    ret_code_t err_code;
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        case BLE_NUS_C_EVT_NUS_TX_EVT:
            ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
        case BLE_NUS_C_EVT_DISCONNECTED:
            NRF_LOG_INFO("Disconnected.");
            scan_start();
 * @brief Function for shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
            // Prepare wakeup buttons.
    return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
/**@brief Function for handling the advertising report BLE event.
 * @param[in] p_adv_report  Advertising report from the SoftDevice.
static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
    if (ble_advdata_uuid_find(p_adv_report->data.p_data, p_adv_report->data.len, &m_nus_uuid))
        err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
                                      &m_scan_params,
                                      &m_connection_param,
                                      APP_BLE_CONN_CFG_TAG);
        if (err_code == NRF_SUCCESS)
            // scan is automatically stopped by the connect
            NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                     p_adv_report->peer_addr.addr[0],
                     p_adv_report->peer_addr.addr[1],
                     p_adv_report->peer_addr.addr[2],
                     p_adv_report->peer_addr.addr[3],
                     p_adv_report->peer_addr.addr[4],
                     p_adv_report->peer_addr.addr[5]
        err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
static void ble_central_evt_handler(ble_evt_t const * p_ble_evt, void * p_context)
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_ADV_REPORT:
            on_adv_report(&p_gap_evt->params.adv_report);
            break; // BLE_GAP_EVT_ADV_REPORT
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected to target");
            err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
            // start discovery of services. The NUS Client waits for a discovery result
            err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
                NRF_LOG_INFO("Scan timed out.");
                scan_start();
            else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_INFO("Connection Request timed out.");
            // Pairing not supported
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
static void ble_peripheral_evt_handler(ble_evt_t const * p_ble_evt, void * p_context)
    uint32_t err_code;
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
        } break;
            // No implementation needed.
/**@brief Function for checking if a bluetooth stack event is an advertising timeout.
 * @param[in] p_ble_evt Bluetooth stack event.
static bool ble_evt_is_advertising_timeout(ble_evt_t const * p_ble_evt)
    return (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_SET_TERMINATED);
    uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    uint16_t role        = ble_conn_state_role(conn_handle);
    // Based on the role this device plays in the connection, dispatch to the right handler.
    if (role == BLE_GAP_ROLE_PERIPH || ble_evt_is_advertising_timeout(p_ble_evt))
        ble_nus_on_ble_evt(p_ble_evt, &m_nus);
        ble_peripheral_evt_handler(p_ble_evt,&m_nus);
    else if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT))
        ble_nus_c_on_ble_evt(p_ble_evt, &m_nus_c);
        ble_central_evt_handler(p_ble_evt,&m_nus_c);
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("ATT MTU exchange completed.");
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in] event  Event generated by button press.
    switch (event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
/**@brief Function for initializing the UART. */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
/**@brief Function for initializing the NUS Client. */
static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler = ble_nus_c_evt_handler;
    err_code = ble_nus_c_init(&m_ble_nus_c, &init);
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/** @brief Function for initializing the Database Discovery Module. */
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
 * @details Handle any pending log operation(s), then sleep until the next event occurs.
        nrf_pwr_mgmt_run();
 *          the device. It also sets the permissions and appearance.
static void gap_params_init(void)//added
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
static void nus_data_handler(ble_nus_evt_t * p_evt)//added
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
    APP_ERROR_HANDLER(nrf_error);
static void services_init(void)//added
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
static void on_conn_params_evt(ble_conn_params_evt_t * p_evt)//added
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
static void conn_params_init(void)//added
static void sleep_mode_enter(void)//added
static void on_adv_evt(ble_adv_evt_t ble_adv_evt)//added
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
static void advertising_init(void)//added
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    // Initialize.
    log_init();
    timer_init();
    uart_init();
    buttons_leds_init();
    db_discovery_init();
    power_management_init();
    ble_stack_init();
    gatt_init();
    nus_c_init();
    gap_params_init();//added
    services_init();//added
    advertising_init();//added
    conn_params_init();//added
    // Start execution.
    printf("BLE UART central_and_peripheral example started.\r\n");
    NRF_LOG_INFO("BLE UART central_and_peripheral example starter.");
    scan_start();
	  advertising_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
The above one is my code, could anyone help me solving this?
Thanks in advance.
