No data output from uart
Hi, Everyone
My development environment is PCA10028, SoftDevice 130, SDK12.3.0
I am testing the input and output of the uart using nRF5_SDK_12.3.0_d7731ad\examples\peripheral\uart
I use RTT for debugging and uart for communication with sensor.
Terminal programs use Realterm.
1. If I use sdk_config_1.h, it will be input and output to the terminal.
However, if I use sdk_config_2.h, it will not be input and output to the terminal 2. Both sdk_config_1.h and sdk_config_2.h do not output data to the RTT Viewer.
I do not know why this is happening.
 * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup uart_example_main main.c
 * @ingroup uart_example
 * @brief UART Example Application main file.
 * This file contains the source code for a sample application using UART.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "bsp.h"
#if 1
#define NRF_LOG_MODULE_NAME "APP"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
//#define ENABLE_LOOPBACK_TEST  /**< if defined, then this example will be a loopback test, which means that TX should be connected to RX to get data loopback. */
#define MAX_TEST_DATA_BYTES     (15U)                /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
void uart_error_handle(app_uart_evt_t * p_event)
    if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
    else if (p_event->evt_type == APP_UART_FIFO_ERROR)
#ifdef ENABLE_LOOPBACK_TEST
/** @brief Function for setting the @ref ERROR_PIN high, and then enter an infinite loop.
static void show_error(void)
    bsp_board_leds_on();
    while (true)
        // Do nothing.
/** @brief Function for testing UART loop back.
 *  @details Transmitts one character at a time to check if the data received from the loopback is same as the transmitted data.
 *  @note  @ref TX_PIN_NUMBER must be connected to @ref RX_PIN_NUMBER)
static void uart_loopback_test()
    uint8_t * tx_data = (uint8_t *)("\r\nLOOPBACK_TEST\r\n");
    uint8_t   rx_data;
    // Start sending one byte and see if you get the same
    for (uint32_t i = 0; i < MAX_TEST_DATA_BYTES; i++)
        uint32_t err_code;
        while (app_uart_put(tx_data[i]) != NRF_SUCCESS);
        nrf_delay_ms(10);
        err_code = app_uart_get(&rx_data);
        if ((rx_data != tx_data[i]) || (err_code != NRF_SUCCESS))
            show_error();
    return;
    uint32_t err_code;
    bsp_board_leds_init();
    const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          APP_UART_FLOW_CONTROL_ENABLED,
          false,
          UART_BAUDRATE_BAUDRATE_Baud115200
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_error_handle,
                         APP_IRQ_PRIORITY_LOWEST,
                         err_code);
#ifndef ENABLE_LOOPBACK_TEST
    printf("\r\nStart: \r\n");
    while (true)
        uint8_t cr;
		app_uart_put(0x30);
        while (app_uart_get(&cr) != NRF_SUCCESS);
//		NRF_LOG_INFO("\r\nReceived: \r\n");
//		printf("\r\nReceived: \r\n");
        while (app_uart_put(cr) != NRF_SUCCESS);
        if (cr == 'q' || cr == 'Q')
            printf(" \r\nExit!\r\n");
            while (true)
                // Do nothing.
#else
    // This part of the example is just for testing the loopback .
    while (true)
        uart_loopback_test();
sdk_config_1.hsdk_config_2.h
  • Hi Alex,
    I would recommend that you take a look at the logger module documentation.
    Here is how you can set the sdk_config.h to enable RTT.
    #ifndef SDK_CONFIG_H
    #define SDK_CONFIG_H
    // <<< Use Configuration Wizard in Context Menu >>>\n
    #ifdef USE_APP_CONFIG
    #include "app_config.h"
    // <h> nRF_Drivers
    // <e> PERIPHERAL_RESOURCE_SHARING_ENABLED - nrf_drv_common - Peripheral drivers common module
    #ifndef PERIPHERAL_RESOURCE_SHARING_ENABLED
    #define PERIPHERAL_RESOURCE_SHARING_ENABLED 0
    #if  PERIPHERAL_RESOURCE_SHARING_ENABLED
    // <e> COMMON_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef COMMON_CONFIG_LOG_ENABLED
    #define COMMON_CONFIG_LOG_ENABLED 0
    #if  COMMON_CONFIG_LOG_ENABLED
    // <o> COMMON_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef COMMON_CONFIG_LOG_LEVEL
    #define COMMON_CONFIG_LOG_LEVEL 3
    // <o> COMMON_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef COMMON_CONFIG_INFO_COLOR
    #define COMMON_CONFIG_INFO_COLOR 0
    // <o> COMMON_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef COMMON_CONFIG_DEBUG_COLOR
    #define COMMON_CONFIG_DEBUG_COLOR 0
    #endif //COMMON_CONFIG_LOG_ENABLED
    // </e>
    #endif //PERIPHERAL_RESOURCE_SHARING_ENABLED
    // </e>
    // <e> UART_ENABLED - nrf_drv_uart - UART/UARTE peripheral driver
    #ifndef UART_ENABLED
    #define UART_ENABLED 1
    #if  UART_ENABLED
    // <o> UART_DEFAULT_CONFIG_HWFC  - Hardware Flow Control
    // <0=> Disabled
    // <1=> Enabled
    #ifndef UART_DEFAULT_CONFIG_HWFC
    #define UART_DEFAULT_CONFIG_HWFC 0
    // <o> UART_DEFAULT_CONFIG_PARITY  - Parity
    // <0=> Excluded
    // <14=> Included
    #ifndef UART_DEFAULT_CONFIG_PARITY
    #define UART_DEFAULT_CONFIG_PARITY 0
    // <o> UART_DEFAULT_CONFIG_BAUDRATE  - Default Baudrate
    // <323584=> 1200 baud
    // <643072=> 2400 baud
    // <1290240=> 4800 baud
    // <2576384=> 9600 baud
    // <3862528=> 14400 baud
    // <5152768=> 19200 baud
    // <7716864=> 28800 baud
    // <10289152=> 38400 baud
    // <15400960=> 57600 baud
    // <20615168=> 76800 baud
    // <30924800=> 115200 baud
    // <61865984=> 230400 baud
    // <67108864=> 250000 baud
    // <121634816=> 460800 baud
    // <251658240=> 921600 baud
    // <268435456=> 57600 baud
    #ifndef UART_DEFAULT_CONFIG_BAUDRATE
    #define UART_DEFAULT_CONFIG_BAUDRATE 30924800
    // <o> UART_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    #ifndef UART_DEFAULT_CONFIG_IRQ_PRIORITY
    #define UART_DEFAULT_CONFIG_IRQ_PRIORITY 3
    // <q> UART_EASY_DMA_SUPPORT  - Driver supporting EasyDMA
    #ifndef UART_EASY_DMA_SUPPORT
    #define UART_EASY_DMA_SUPPORT 1
    // <q> UART_LEGACY_SUPPORT  - Driver supporting Legacy mode
    #ifndef UART_LEGACY_SUPPORT
    #define UART_LEGACY_SUPPORT 1
    // <e> UART0_ENABLED - Enable UART0 instance
    #ifndef UART0_ENABLED
    #define UART0_ENABLED 1
    #if  UART0_ENABLED
    // <q> UART0_CONFIG_USE_EASY_DMA  - Default setting for using EasyDMA
    #ifndef UART0_CONFIG_USE_EASY_DMA
    #define UART0_CONFIG_USE_EASY_DMA 1
    #endif //UART0_ENABLED
    // </e>
    // <e> UART_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef UART_CONFIG_LOG_ENABLED
    #define UART_CONFIG_LOG_ENABLED 0
    #if  UART_CONFIG_LOG_ENABLED
    // <o> UART_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef UART_CONFIG_LOG_LEVEL
    #define UART_CONFIG_LOG_LEVEL 3
    // <o> UART_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef UART_CONFIG_INFO_COLOR
    #define UART_CONFIG_INFO_COLOR 0
    // <o> UART_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef UART_CONFIG_DEBUG_COLOR
    #define UART_CONFIG_DEBUG_COLOR 0
    #endif //UART_CONFIG_LOG_ENABLED
    // </e>
    #endif //UART_ENABLED
    // </e>
    // </h>
    // <h> nRF_Libraries
    // <q> APP_FIFO_ENABLED  - app_fifo - Software FIFO implementation
    #ifndef APP_FIFO_ENABLED
    #define APP_FIFO_ENABLED 1
    // <e> APP_UART_ENABLED - app_uart - UART driver
    #ifndef APP_UART_ENABLED
    #define APP_UART_ENABLED 1
    #if  APP_UART_ENABLED
    // <o> APP_UART_DRIVER_INSTANCE  - UART instance used
    // <0=> 0
    #ifndef APP_UART_DRIVER_INSTANCE
    #define APP_UART_DRIVER_INSTANCE 0
    #endif //APP_UART_ENABLED
    // </e>
    // <q> RETARGET_ENABLED  - retarget - Retargeting stdio functions
    #ifndef RETARGET_ENABLED
    #define RETARGET_ENABLED 1
    // </h>
    // <h> nRF_Log
    // <e> NRF_LOG_ENABLED - nrf_log - Logging
    #ifndef NRF_LOG_ENABLED
    #define NRF_LOG_ENABLED 1
    #if  NRF_LOG_ENABLED
    // <e> NRF_LOG_USES_COLORS - If enabled then ANSI escape code for colors is prefixed to every string
    #ifndef NRF_LOG_USES_COLORS
    #define NRF_LOG_USES_COLORS 0
    #if  NRF_LOG_USES_COLORS
    // <o> NRF_LOG_COLOR_DEFAULT  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_LOG_COLOR_DEFAULT
    #define NRF_LOG_COLOR_DEFAULT 0
    // <o> NRF_LOG_ERROR_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_LOG_ERROR_COLOR
    #define NRF_LOG_ERROR_COLOR 0
    // <o> NRF_LOG_WARNING_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_LOG_WARNING_COLOR
    #define NRF_LOG_WARNING_COLOR 0
    #endif //NRF_LOG_USES_COLORS
    // </e>
    // <o> NRF_LOG_DEFAULT_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_LOG_DEFAULT_LEVEL
    #define NRF_LOG_DEFAULT_LEVEL 4
    // <e> NRF_LOG_DEFERRED - Enable deffered logger.
    // <i> Log data is buffered and can be processed in idle.
    #ifndef NRF_LOG_DEFERRED
    #define NRF_LOG_DEFERRED 0
    #if  NRF_LOG_DEFERRED
    // <o> NRF_LOG_DEFERRED_BUFSIZE - Size of the buffer for logs in words.
    // <i> Must be power of 2
    #ifndef NRF_LOG_DEFERRED_BUFSIZE
    #define NRF_LOG_DEFERRED_BUFSIZE 256
    #endif //NRF_LOG_DEFERRED
    // </e>
    // <q> NRF_LOG_USES_TIMESTAMP  - Enable timestamping
    // <i> Function for getting the timestamp is provided by the user
    #ifndef NRF_LOG_USES_TIMESTAMP
    #define NRF_LOG_USES_TIMESTAMP 0
    #endif //NRF_LOG_ENABLED
    // </e>
    // <h> nrf_log_backend - Logging sink
    // <o> NRF_LOG_BACKEND_MAX_STRING_LENGTH - Buffer for storing single output string
    // <i> Logger backend RAM usage is determined by this value.
    #ifndef NRF_LOG_BACKEND_MAX_STRING_LENGTH
    #define NRF_LOG_BACKEND_MAX_STRING_LENGTH 256
    // <o> NRF_LOG_TIMESTAMP_DIGITS - Number of digits for timestamp
    // <i> If higher resolution timestamp source is used it might be needed to increase that
    #ifndef NRF_LOG_TIMESTAMP_DIGITS
    #define NRF_LOG_TIMESTAMP_DIGITS 8
    // <e> NRF_LOG_BACKEND_SERIAL_USES_UART - If enabled data is printed over UART
    #ifndef NRF_LOG_BACKEND_SERIAL_USES_UART
    #define NRF_LOG_BACKEND_SERIAL_USES_UART 0
    #if  NRF_LOG_BACKEND_SERIAL_USES_UART
    // <o> NRF_LOG_BACKEND_SERIAL_UART_BAUDRATE  - Default Baudrate
    #ifndef NRF_LOG_BACKEND_SERIAL_UART_BAUDRATE
    #define NRF_LOG_BACKEND_SERIAL_UART_BAUDRATE 30924800
    // <o> NRF_LOG_BACKEND_SERIAL_UART_TX_PIN - UART TX pin
    #ifndef NRF_LOG_BACKEND_SERIAL_UART_TX_PIN
    #define NRF_LOG_BACKEND_SERIAL_UART_TX_PIN 9
    // <o> NRF_LOG_BACKEND_SERIAL_UART_RX_PIN - UART RX pin
    #ifndef NRF_LOG_BACKEND_SERIAL_UART_RX_PIN
    #define NRF_LOG_BACKEND_SERIAL_UART_RX_PIN 11
    // <o> NRF_LOG_BACKEND_SERIAL_UART_RTS_PIN - UART RTS pin
    #ifndef NRF_LOG_BACKEND_SERIAL_UART_RTS_PIN
    #define NRF_LOG_BACKEND_SERIAL_UART_RTS_PIN 8
    // <o> NRF_LOG_BACKEND_SERIAL_UART_CTS_PIN - UART CTS pin
    #ifndef NRF_LOG_BACKEND_SERIAL_UART_CTS_PIN
    #define NRF_LOG_BACKEND_SERIAL_UART_CTS_PIN 10
    // <o> NRF_LOG_BACKEND_SERIAL_UART_FLOW_CONTROL  - Hardware Flow Control
    // <0=> Disabled
    // <1=> Enabled
    #ifndef NRF_LOG_BACKEND_SERIAL_UART_FLOW_CONTROL
    #define NRF_LOG_BACKEND_SERIAL_UART_FLOW_CONTROL 0
    // <o> NRF_LOG_BACKEND_UART_INSTANCE  - UART instance used
    // <0=> 0
    #ifndef NRF_LOG_BACKEND_UART_INSTANCE
    #define NRF_LOG_BACKEND_UART_INSTANCE 0
    #endif //NRF_LOG_BACKEND_SERIAL_USES_UART
    // </e>
    // <e> NRF_LOG_BACKEND_SERIAL_USES_RTT - If enabled data is printed using RTT
    #ifndef NRF_LOG_BACKEND_SERIAL_USES_RTT
    #define NRF_LOG_BACKEND_SERIAL_USES_RTT 1
    #if  NRF_LOG_BACKEND_SERIAL_USES_RTT
    // <o> NRF_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE - RTT output buffer size.
    // <i> Should be equal or bigger than \ref NRF_LOG_BACKEND_MAX_STRING_LENGTH.
    // <i> This value is used in Segger RTT configuration to set the buffer size
    // <i> if it is bigger than default RTT buffer size.
    #ifndef NRF_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE
    #define NRF_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE 512
    #endif //NRF_LOG_BACKEND_SERIAL_USES_RTT
    // </e>
    // </h>
    // </h>
    // <h> nRF_Segger_RTT
    // <h> segger_rtt - SEGGER RTT
    // <o> SEGGER_RTT_CONFIG_BUFFER_SIZE_UP - Size of upstream buffer.
    #ifndef SEGGER_RTT_CONFIG_BUFFER_SIZE_UP
    #define SEGGER_RTT_CONFIG_BUFFER_SIZE_UP 64
    // <o> SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS - Size of upstream buffer.
    #ifndef SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS
    #define SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS 2
    // <o> SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN - Size of upstream buffer.
    #ifndef SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN
    #define SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN 16
    // <o> SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS - Size of upstream buffer.
    #ifndef SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS
    #define SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS 2
    // </h>
    // </h>
    // <<< end of configuration section >>>
    #endif //SDK_CONFIG_H
    Remembember to add:
    static void log_init(void)
    		NRF_LOG_INFO("RTT Logging initialized");
    to main.c.
    This thread could also be interesting.
  • Hi, Martin
    I added log_init () to main.c as advised by you
    The result of the program execution
    1. log_init ()
        APP_UART_FIFO_INIT ()
       => error_code 0x08 occurs in nrf_drv_uart_init ()
    2. APP_UART_FIFO_INIT ()
        log_init ()
      => No error occurred
    3. #define NRF_LOG_BACKEND_SERIAL_USES_UART 1
        If the setting is as above  I can not get uart input as input to app_uart_get ()
  • Hi Alex,
    I am sorry for the delay, have you had any progress with this issue?
    If so could you give an update?
