NRF_FAULT_ID_APP_MEMACC failed when migrate code Mesh 2.0 and BLE V15
When i tried the light switch example from the Mesh 2.0 source code, i got the error code NRF_FAULT_ID_SD_ASSERT. when it is doing the provision process.
The last meassae i got is as follow
<t:     372169>, provisioner_helper.c,  157, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
<t:     372175>, provisioner_helper.c,   96, UUID filter matched
<t:     541121>, provisioner_helper.c,  166, Start Provision with : 0059ABCDEFABCDEFACCDEFABCDEFABCD
<t:     541127>, provisioner_helper.c,  115, key data  index 0
<t:     541132>, provisioner_helper.c,  116, key address 0x100
<t:     541136>, provisioner_helper.c,  117, key type 1
<t:     541142>, nrf_mesh_prov.c,  219, nrf_mesh_prov_provision exit with status 0
<t:     542805>, provisioner_helper.c,  309, Provisioning link established
<t:     892634>, provisioner_helper.c,  304, Static authentication data provided
<t:     969894>, provisioner_helper.c,  210, Provisioning completed received
But seems then the assertion failed is from the function of dsm_address_publish_add
How could I debug from that?
I have got the id =0x4001 pc = 0x2b875 info=0x2000fd88
Ajay
  • <!DOCTYPE CrossStudio_Project_File>
    <solution Name="ble_app_uart_pca10040_s132" target="8" version="2">
      <project Name="ble_app_uart_pca10040_s132">
        <configuration
          Name="Common"
          arm_architecture="v7EM"
          arm_core_type="Cortex-M4"
          arm_endian="Little"
          arm_fp_abi="Hard"
          arm_fpu_type="FPv4-SP-D16"
          arm_linker_heap_size="8192"
          arm_linker_process_stack_size="0"
          arm_linker_stack_size="8192"
          arm_linker_treat_warnings_as_errors="No"
          arm_simulator_memory_simulation_parameter="RWX 00000000,00100000,FFFFFFFF;RWX 20000000,00010000,CDCDCDCD"
          arm_target_device_name="nRF52832_xxAA"
          arm_target_interface_type="SWD"
          c_preprocessor_definitions="BOARD_PCA10040;CONFIG_GPIO_AS_PINRESET;FLOAT_ABI_HARD;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52;NRF52832_XXAA;NRF52_PAN_74;NRF_SD_BLE_API_VERSION=6;S132;SOFTDEVICE_PRESENT;SWI_DISABLE0;NRF52_SERIES;CONFIG_APP_IN_CORE"
          c_user_include_directories="../../../config;../../../../../../components;../../../../../../components/ble/ble_advertising;../../../../../../components/ble/ble_dtm;../../../../../../components/ble/ble_link_ctx_manager;../../../../../../components/ble/ble_racp;../../../../../../components/ble/ble_services/ble_ancs_c;../../../../../../components/ble/ble_services/ble_ans_c;../../../../../../components/ble/ble_services/ble_bas;../../../../../../components/ble/ble_services/ble_bas_c;../../../../../../components/ble/ble_services/ble_cscs;../../../../../../components/ble/ble_services/ble_cts_c;../../../../../../components/ble/ble_services/ble_dfu;../../../../../../components/ble/ble_services/ble_dis;../../../../../../components/ble/ble_services/ble_gls;../../../../../../components/ble/ble_services/ble_hids;../../../../../../components/ble/ble_services/ble_hrs;../../../../../../components/ble/ble_services/ble_hrs_c;../../../../../../components/ble/ble_services/ble_hts;../../../../../../components/ble/ble_services/ble_ias;../../../../../../components/ble/ble_services/ble_ias_c;../../../../../../components/ble/ble_services/ble_lbs;../../../../../../components/ble/ble_services/ble_lbs_c;../../../../../../components/ble/ble_services/ble_lls;../../../../../../components/ble/ble_services/ble_nus;../../../../../../components/ble/ble_services/ble_nus_c;../../../../../../components/ble/ble_services/ble_rscs;../../../../../../components/ble/ble_services/ble_rscs_c;../../../../../../components/ble/ble_services/ble_tps;../../../../../../components/ble/common;../../../../../../components/ble/nrf_ble_gatt;../../../../../../components/ble/nrf_ble_qwr;../../../../../../components/ble/peer_manager;../../../../../../components/boards;../../../../../../components/drivers_nrf/usbd;../../../../../../components/libraries/atomic;../../../../../../components/libraries/atomic_fifo;../../../../../../components/libraries/atomic_flags;../../../../../../components/libraries/balloc;../../../../../../components/libraries/bootloader/ble_dfu;../../../../../../components/libraries/bsp;../../../../../../components/libraries/button;../../../../../../components/libraries/cli;../../../../../../components/libraries/crc16;../../../../../../components/libraries/crc32;../../../../../../components/libraries/crypto;../../../../../../components/libraries/csense;../../../../../../components/libraries/csense_drv;../../../../../../components/libraries/delay;../../../../../../components/libraries/ecc;../../../../../../components/libraries/experimental_log;../../../../../../components/libraries/experimental_log/src;../../../../../../components/libraries/experimental_memobj;../../../../../../components/libraries/experimental_mpu;../../../../../../components/libraries/experimental_ringbuf;../../../../../../components/libraries/experimental_section_vars;../../../../../../components/libraries/experimental_stack_guard;../../../../../../components/libraries/experimental_task_manager;../../../../../../components/libraries/fds;../../../../../../components/libraries/fifo;../../../../../../components/libraries/fstorage;../../../../../../components/libraries/gfx;../../../../../../components/libraries/gpiote;../../../../../../components/libraries/hardfault;../../../../../../components/libraries/hci;../../../../../../components/libraries/led_softblink;../../../../../../components/libraries/low_power_pwm;../../../../../../components/libraries/mem_manager;../../../../../../components/libraries/mutex;../../../../../../components/libraries/pwm;../../../../../../components/libraries/pwr_mgmt;../../../../../../components/libraries/queue;../../../../../../components/libraries/scheduler;../../../../../../components/libraries/sdcard;../../../../../../components/libraries/slip;../../../../../../components/libraries/sortlist;../../../../../../components/libraries/spi_mngr;../../../../../../components/libraries/strerror;../../../../../../components/libraries/timer;../../../../../../components/libraries/twi_mngr;../../../../../../components/libraries/twi_sensor;../../../../../../components/libraries/uart;../../../../../../components/libraries/usbd;../../../../../../components/libraries/usbd/class/audio;../../../../../../components/libraries/usbd/class/cdc;../../../../../../components/libraries/usbd/class/cdc/acm;../../../../../../components/libraries/usbd/class/hid;../../../../../../components/libraries/usbd/class/hid/generic;../../../../../../components/libraries/usbd/class/hid/kbd;../../../../../../components/libraries/usbd/class/hid/mouse;../../../../../../components/libraries/usbd/class/msc;../../../../../../components/libraries/usbd/config;../../../../../../components/libraries/util;../../../../../../components/nfc/ndef/conn_hand_parser;../../../../../../components/nfc/ndef/conn_hand_parser/ac_rec_parser;../../../../../../components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser;../../../../../../components/nfc/ndef/conn_hand_parser/le_oob_rec_parser;../../../../../../components/nfc/ndef/connection_handover/ac_rec;../../../../../../components/nfc/ndef/connection_handover/ble_oob_advdata;../../../../../../components/nfc/ndef/connection_handover/ble_pair_lib;../../../../../../components/nfc/ndef/connection_handover/ble_pair_msg;../../../../../../components/nfc/ndef/connection_handover/common;../../../../../../components/nfc/ndef/connection_handover/ep_oob_rec;../../../../../../components/nfc/ndef/connection_handover/hs_rec;../../../../../../components/nfc/ndef/connection_handover/le_oob_rec;../../../../../../components/nfc/ndef/generic/message;../../../../../../components/nfc/ndef/generic/record;../../../../../../components/nfc/ndef/launchapp;../../../../../../components/nfc/ndef/parser/message;../../../../../../components/nfc/ndef/parser/record;../../../../../../components/nfc/ndef/text;../../../../../../components/nfc/ndef/uri;../../../../../../components/nfc/t2t_lib;../../../../../../components/nfc/t2t_lib/hal_t2t;../../../../../../components/nfc/t2t_parser;../../../../../../components/nfc/t4t_lib;../../../../../../components/nfc/t4t_lib/hal_t4t;../../../../../../components/nfc/t4t_parser/apdu;../../../../../../components/nfc/t4t_parser/cc_file;../../../../../../components/nfc/t4t_parser/hl_detection_procedure;../../../../../../components/nfc/t4t_parser/tlv;../../../../../../components/softdevice/common;../../../../../../components/softdevice/s132/headers;../../../../../../components/softdevice/s132/headers/nrf52;../../../../../../components/toolchain/cmsis/include;../../../../../../external/fprintf;../../../../../../external/segger_rtt;../../../../../../integration/nrfx;../../../../../../integration/nrfx/legacy;../../../../../../modules/nrfx;../../../../../../modules/nrfx/drivers/include;../../../../../../modules/nrfx/hal;../../../../../../modules/nrfx/mdk;../config;$(meshSDKv2)/mesh/core/api;$(meshSDKv2)/mesh/core/include;$(meshSDKv2)/mesh/bearer/api;$(meshSDKv2)/mesh/bearer/include;$(meshSDKv2)/mesh/prov/api;$(meshSDKv2)/mesh/prov/include;$(meshSDKv2)/mesh/access/api;$(meshSDKv2)/mesh/access/include;$(meshSDKv2)/mesh/dfu/api;$(meshSDKv2)/mesh/dfu/include;$(meshSDKv2)/mesh/stack/api;$(meshSDKv2)/models/config/include;$(meshSDKv2)/models/health/include;$(meshSDKv2)/models/simple_on_off/include;$(meshSDKv2)/external/micro-ecc;$(meshSDKv2)/examples/common/include"
          debug_additional_load_file="../../../../../../components/softdevice/s132/hex/s132_nrf52_6.0.0_softdevice.hex"
          debug_register_definition_file="../../../../../../modules/nrfx/mdk/nrf52.svd"
          debug_start_from_entry_point_symbol="No"
          debug_target_connection="J-Link"
          gcc_debugging_level="Level 3"
          gcc_entry_point="Reset_Handler"
          linker_output_format="hex"
          linker_printf_fmt_level="long"
          linker_printf_width_precision_supported="Yes"
          linker_section_placement_file="flash_placement.xml"
          linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x80000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x10000;FLASH_START=0x26000;FLASH_SIZE=0x5a000;RAM_START=0x20002a98;RAM_SIZE=0xd568"
          linker_section_placements_segments="FLASH RX 0x0 0x80000;RAM RWX 0x20000000 0x10000"
          macros="CMSIS_CONFIG_TOOL=../../../../../../external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar"
          project_directory=""
          project_type="Executable" />
        <folder Name="Segger Startup Files">
          <file file_name="$(StudioDir)/source/thumb_crt0.s" />
        </folder>
        <folder Name="nRF_Log">
          <file file_name="../../../../../../components/libraries/experimental_log/src/nrf_log_backend_rtt.c" />
          <file file_name="../../../../../../components/libraries/experimental_log/src/nrf_log_backend_serial.c" />
          <file file_name="../../../../../../components/libraries/experimental_log/src/nrf_log_default_backends.c" />
          <file file_name="../../../../../../components/libraries/experimental_log/src/nrf_log_frontend.c" />
          <file file_name="../../../../../../components/libraries/experimental_log/src/nrf_log_str_formatter.c" />
        </folder>
        <folder Name="nRF_Libraries">
          <file file_name="../../../../../../components/libraries/button/app_button.c" />
          <file file_name="../../../../../../components/libraries/util/app_error.c" />
          <file file_name="../../../../../../components/libraries/util/app_error_handler_gcc.c" />
          <file file_name="../../../../../../components/libraries/util/app_error_weak.c" />
          <file file_name="../../../../../../components/libraries/fifo/app_fifo.c" />
          <file file_name="../../../../../../components/libraries/scheduler/app_scheduler.c" />
          <file file_name="../../../../../../components/libraries/timer/app_timer.c" />
          <file file_name="../../../../../../components/libraries/uart/app_uart_fifo.c" />
          <file file_name="../../../../../../components/libraries/util/app_util_platform.c" />
          <file file_name="../../../../../../components/libraries/hardfault/hardfault_implementation.c" />
          <file file_name="../../../../../../components/libraries/util/nrf_assert.c" />
          <file file_name="../../../../../../components/libraries/atomic_fifo/nrf_atfifo.c" />
          <file file_name="../../../../../../components/libraries/atomic_flags/nrf_atflags.c" />
          <file file_name="../../../../../../components/libraries/atomic/nrf_atomic.c" />
          <file file_name="../../../../../../components/libraries/balloc/nrf_balloc.c" />
          <file file_name="../../../../../../external/fprintf/nrf_fprintf.c" />
          <file file_name="../../../../../../external/fprintf/nrf_fprintf_format.c" />
          <file file_name="../../../../../../components/libraries/fstorage/nrf_fstorage.c" />
          <file file_name="../../../../../../components/libraries/fstorage/nrf_fstorage_sd.c" />
          <file file_name="../../../../../../components/libraries/experimental_memobj/nrf_memobj.c" />
          <file file_name="../../../../../../components/libraries/pwr_mgmt/nrf_pwr_mgmt.c" />
          <file file_name="../../../../../../components/libraries/experimental_section_vars/nrf_section_iter.c" />
          <file file_name="../../../../../../components/libraries/strerror/nrf_strerror.c" />
          <file file_name="../../../../../../components/libraries/uart/retarget.c" />
        </folder>
        <folder Name="None">
          <file file_name="../../../../../../modules/nrfx/mdk/ses_nRF_Startup.s" />
          <file file_name="../../../../../../modules/nrfx/mdk/ses_nrf52_Vectors.s" />
          <file file_name="../../../../../../modules/nrfx/mdk/system_nrf52.c" />
        </folder>
        <folder Name="Board Definition">
          <file file_name="../../../../../../components/boards/boards.c" />
        </folder>
        <folder Name="nRF_Drivers">
          <file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_clock.c" />
          <file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_uart.c" />
          <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_clock.c" />
          <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_gpiote.c" />
          <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_power_clock.c" />
          <file file_name="../../../../../../modules/nrfx/drivers/src/prs/nrfx_prs.c" />
          <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uart.c" />
          <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uarte.c" />
        </folder>
        <folder Name="Board Support">
          <file file_name="../../../../../../components/libraries/bsp/bsp.c" />
          <file file_name="../../../../../../components/libraries/bsp/bsp_btn_ble.c" />
        </folder>
        <folder Name="Application">
          <file file_name="../../../main.c" />
          <file file_name="../config/sdk_config.h" />
          <file file_name="../../../node_setup.c" />
          <file file_name="../../../provisioner_helper.c" />
          <file file_name="../../../simple_hal.c" />
          <file file_name="../../../rtt_input.c" />
        </folder>
        <folder Name="nRF_Segger_RTT">
          <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT.c" />
          <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_Syscalls_SES.c" />
          <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_printf.c" />
        </folder>
        <folder Name="nRF_BLE">
          <file file_name="../../../../../../components/ble/common/ble_advdata.c" />
          <file file_name="../../../../../../components/ble/ble_advertising/ble_advertising.c" />
          <file file_name="../../../../../../components/ble/common/ble_conn_params.c" />
          <file file_name="../../../../../../components/ble/common/ble_conn_state.c" />
          <file file_name="../../../../../../components/ble/ble_link_ctx_manager/ble_link_ctx_manager.c" />
          <file file_name="../../../../../../components/ble/common/ble_srv_common.c" />
          <file file_name="../../../../../../components/ble/nrf_ble_gatt/nrf_ble_gatt.c" />
          <file file_name="../../../../../../components/ble/nrf_ble_qwr/nrf_ble_qwr.c" />
        </folder>
        <folder Name="nRF_BLE_Services">
          <file file_name="../../../../../../components/ble/ble_services/ble_nus/ble_nus.c" />
        </folder>
        <folder Name="nRF_SoftDevice">
          <file file_name="../../../../../../components/softdevice/common/nrf_sdh.c" />
          <file file_name="../../../../../../components/softdevice/common/nrf_sdh_ble.c" />
          <file file_name="../../../../../../components/softdevice/common/nrf_sdh_soc.c" />
        </folder>
        <folder Name="mesh">
          <folder Name="core">
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/aes.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/aes_cmac.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/beacon.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/bearer_event.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/cache.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/ccm_soft.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/core_tx.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/core_tx_adv.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/core_tx_instaburst.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/enc.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/event.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/fifo.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/flash_manager.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/flash_manager_defrag.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/flash_manager_internal.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/fsm.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/hal.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/heartbeat.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/internal_event.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/list.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/log.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/mesh_flash.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/msg_cache.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/msqueue.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/net_beacon.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/net_packet.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/net_state.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/network.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/nrf_flash.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/nrf_mesh.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/nrf_mesh_configure.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/nrf_mesh_keygen.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/nrf_mesh_opt.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/nrf_mesh_utils.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/packet_buffer.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/packet_mgr.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/queue.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/rand.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/replay_cache.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/ticker.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/timer.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/timer_scheduler.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/timeslot.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/toolchain.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/transport.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/core/src/uri.c" />
          </folder>
          <folder Name="bearer">
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/ad_listener.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/ad_type_filter.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/adv_ext_packet.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/adv_ext_tx.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/adv_packet_filter.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/advertiser.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/bearer_handler.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/broadcast.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/filter_engine.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/gap_address_filter.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/instaburst.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/instaburst_rx.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/instaburst_tx.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/radio_config.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/rssi_filter.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/bearer/src/scanner.c" />
          </folder>
          <folder Name="prov">
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/prov/src/nrf_mesh_prov.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/prov/src/prov_beacon.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/prov/src/prov_bearer_adv.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/prov/src/prov_provisionee.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/prov/src/prov_provisioner.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/prov/src/prov_utils.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/prov/src/provisioning.c" />
          </folder>
          <folder Name="access">
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/access/src/access.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/access/src/access_publish.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/access/src/access_reliable.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/access/src/device_state_manager.c" />
          </folder>
          <folder Name="dfu">
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/dfu/src/nrf_mesh_dfu.c" />
          </folder>
          <folder Name="stack">
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/mesh/stack/src/mesh_stack.c" />
          </folder>
          <folder Name="mesh_model_config">
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/models/config/src/composition_data.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/models/config/src/config_server.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/models/config/src/packed_index_list.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/models/config/src/config_client.c" />
          </folder>
          <folder Name="mesh_model_health">
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/models/health/src/health_server.c" />
          </folder>
          <folder Name="mesh_model_simple_OnOff">
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/models/simple_on_off/src/simple_on_off_client.c" />
          </folder>
          <folder Name="external">
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/external/micro-ecc/uECC.c" />
          </folder>
          <folder Name="common">
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/examples/common/src/assertion_handler_weak.c" />
            <file file_name="../../../../../../../nrf5_SDK_for_Mesh_v2.0.1_src/examples/common/src/mesh_provisionee.c" />
          </folder>
        </folder>
        <configuration Name="Release" c_user_include_directories="." />
      </project>
      <configuration
        Name="Release"
        c_preprocessor_definitions="NDEBUG"
        gcc_optimization_level="Optimize For Size" />
      <configuration
        Name="Debug"
        c_preprocessor_definitions="DEBUG; DEBUG_NRF"
        gcc_optimization_level="None" />
      <configuration Name="Common" c_preprocessor_definitions="" />
    </solution>
  • I think it may related to the memory setting of the softdevice for the project. So, i also upload the Project Solution configuration here for reference.
  • You have mentioned two error codes, NRF_FAULT_ID_APP_MEMACC and NRF_FAULT_ID_SD_ASSERT. Which error did you get?
  • My Fault, it should be NRF_FAULT_ID_APP_MEMACC .
    But already locate the problem is not from the SoftDevice. Is about I did not config the server model well before use.
    Thanks and Regards,
    Ajay
