software TWI 1.3mA OFF MODE
Using twi_sw_master have discovered that the nrf51422 E00 draws 1.3mA in off mode.
When the twi device is removed from the bus, the nrf51422 draws under 5uA in off mode.
I have created twi_hw_master.c correctly using SHORTS github.com/.../twi_hw_master.c
I turn hardware twi off using
NRF_TWI1->POWER  = 1;
NRF_TWI1->ENABLE = TWI_ENABLE_ENABLE_Enabled << TWI_ENABLE_ENABLE_Pos;
// do your I2C stuff here
NRF_TWI1->ENABLE = TWI_ENABLE_ENABLE_Disabled << TWI_ENABLE_ENABLE_Pos;
NRF_TWI1->POWER  = 0;
This works fine with the mpu6500, but does not with the hmc5983. I suspect the hmc5983 is some how keeping the nrf51422 twi active.
The solution could be to upmap the twi pins disconnecting the nrf51422 from the twi bus, so that the twi bus does not keep the nrf51422 active.
HOW should I unmap the twi pins? So that the nrf51422 is not effected by the twi bus?
Remapping twi pins or anything that may cause twi communication problems, causes the softdevice to HANG or not function correctly. This includes Advertising timeout not functioning, or hanging the nrf51422 on ble bonding.
Simple disabling pullups does not allow working around twi communication issues.
