Bluetooth service stops after some time
Im using SD5 and after some time (every time different) of transmitting HRS data the SD stops apparently, because there is no more connection with my Android phone and the device becomes invisible as well.
It only happens when I use Timer2 to generate PWM however.
So here is my timer interrupt and init functions:
void TIMER2_IRQHandler()
	if(beepOn && makeBeep>0 && NRF_TIMER2->EVENTS_COMPARE[1]!=0)
		if(beepCycles%2==0)
			nrf_gpio_pin_toggle(BEEPER_PIN);
		beepCycles++;
		if(beepCycles==120)
			beepCycles=0;
			makeBeep--;
			nrf_gpio_pin_clear(BEEPER_PIN);
	if(NRF_TIMER2->EVENTS_COMPARE[1]!=0)NRF_TIMER2->EVENTS_COMPARE[1]=0;
static void pwm_timer_init(void)
    NRF_TIMER2->MODE        = TIMER_MODE_MODE_Timer;
    NRF_TIMER2->BITMODE     = TIMER_BITMODE_BITMODE_16Bit << TIMER_BITMODE_BITMODE_Pos;
    NRF_TIMER2->PRESCALER   = 0;
    // Clears the timer, sets it to 0.
    NRF_TIMER2->TASKS_CLEAR = 1;
    NRF_TIMER2->CC[0] = 355;
NRF_TIMER2->SHORTS = (TIMER_SHORTS_COMPARE1_CLEAR_Enabled << TIMER_SHORTS_COMPARE1_CLEAR_Pos) & TIMER_SHORTS_COMPARE1_CLEAR_Msk;
    NRF_TIMER2->CC[1] = 8000;
NRF_TIMER2->CC[2] = 0;
    // Interrupt setup.
    NRF_TIMER2->INTENSET = (TIMER_INTENSET_COMPARE1_Enabled << TIMER_INTENSET_COMPARE1_Pos);
		NRF_TIMER2->EVENTS_COMPARE[0]=NRF_TIMER2->EVENTS_COMPARE[1]=NRF_TIMER2->EVENTS_COMPARE[2]=0;
    // Enable interrupt on Timer 2.
 sd_nvic_SetPriority(TIMER2_IRQn, PWM_IRQ_PRIORITY | 0x01);
   sd_nvic_EnableIRQ(TIMER2_IRQn);
    // Start the timer.
    NRF_TIMER2->TASKS_START = 1;
The app_error_handler is never called, but if I stop a debug session, I get the following:
SD error on stop
Any ideas what could be wrong?
Thanks, Sergey
