My problem described below, please share solution or any suggestion how to fix this.
=== Background / Problem ===
- I've setup and run MESH serial network, for machine sensor. It works good, at least 2 weeks before STOP running.
- Re-program application doesn't help.
- Only erase entire Flash, re-program SoftDevice and Application to bring it run again.
=== Device ===
- nRF52832 module
=== Code configuration ===
- Keil compiler, Processor symbol:
CONFIG_NFCT_PINS_AS_GPIOS DONOT_CONFIG_GPIO_AS_PINRESET FLOAT_ABI_HARD NRF52 NRF52832_XXAA NRF52_PAN_74 NRF_SD_BLE_API_VERSION=6 S132 SOFTDEVICE_PRESENT SWI_DISABLE0 CONFIG_APP_IN_CORE NRF_MESH_LOG_ENABLE=1 PERSISTENT_STORAGE=1 NRF52_SERIES NRF52832 SD_BLE_API_VERSION=6 uECC_OPTIMIZATION_LEVEL=2 uECC_SUPPORTS_secp160r1=0 uECC_SUPPORTS_secp192r1=0 uECC_SUPPORTS_secp224r1=0 uECC_SUPPORTS_secp256r1=1 uECC_SUPPORTS_secp256k1=0 uECC_SUPPORT_COMPRESSED_POINT=0
- The Code modified from Mesh Serial example,"nrf5_SDK_for_Mesh_v2.1.1_src\examples\serial". No bootloader.
- Add Coexistence (follow "how_to_nordicSDK.md") with ble_app_uart (nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart).
- Enable persistent storage, chage symbol define from "PERSISTENT_STORAGE=0" to "PERSISTENT_STORAGE=1"
- Apply fix described in "https://devzone.nordicsemi.com/f/nordic-q-a/34542/bluetooth-5-ble-mesh-assert-0x0002dc36"
- Add Quick setup inside the code instead of external serial command (No external controller).
void mesh_quick_setup_(uint16_t address) { uint32_t status; // dsm_subnet_add status = dsm_subnet_add(0, MESH_DEFAULT_SUBNET_KEY, &MESH_subnet_handle); __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "dsm_subnet_add: %u\n", status); // dsm_appkey_add status = dsm_appkey_add(0, MESH_subnet_handle, MESH_DEFAULT_APP_KEY, &MESH_appkey_handle); __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "dsm_appkey_add: %u\n", status); // dsm_local_unicast_addresses_set dsm_local_unicast_address_t local = { .address_start = address, //DEFAULT_LOCAL_UNICAST_ADRESS_START, .count = ACCESS_ELEMENT_COUNT }; status = dsm_local_unicast_addresses_set(&local); __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "dsm_local_unicast_addresses_set: %u\n", status); // publication uint16_t pub_count = get_setting_publication_count(); for (uint16_t i=0; i< pub_count; i++) { status = mesh_addr_publication_add(get_setting_publication(i)); __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "mesh_addr_publication_add: %X, sta:%d\n", get_setting_publication(i), status); } }
- Add handler event to receive Mesh data
m_evt_handler.evt_cb = serial_handler_mesh_evt_handle; nrf_mesh_evt_handler_add(&m_evt_handler);
=== Debugging ===
Below information from my running debugger,
- Found the CPU process locked at "flash_manager_wait" function, no return util Watchdog reset (10 sec).
/** Waits for the flash manager to complete all its operations. */ static inline void flash_manager_wait(void) { #if !defined(HOST) while (!flash_manager_is_stable()) { /* Temporary hack to make sure that bearer events are handled while waiting for * the flash manager to finish. * TODO: Find a solution for this that does not include busy-waiting. */ if (bearer_event_handler()) { __WFE(); } } #endif }
- I observer the MCU write 8 bytes data append to flash on every time it reset.
Here is the Flash memory data reading from "nrfjprog --readcode d:/code.hex"
:020000040007F3 :10900000080410100100FFFFFFFFFFFFFFFFFFFF3D :10901000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60 :10902000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50 ... ... :10A00000080410100100FFFF040001000800080010 :10A010000A0020000800000006000000000000BB4D :10A02000CCBBCCBBCCBBCCBBCCBBCCBBCCBBCC00B3 :10A030000600000000000000AABBAABBAABBAABB86 :10A04000AABBAABBAABBAABB020002000001010076 :10A05000020000102100000006000030000000BBDC :10A06000CCBBCCBBCCBBCCBBCCBBCCBBCCBBCC0073 :10A070000600004000000000AABBAABBAABBAABB06 :10A08000AABBAABBAABBAABBFFFFFF7FFFFFFFFFC4 :10A09000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0 :10A0A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0 :10A0B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0 ... ... :10B00000080410100100FFFF030002000000000010 :10B01000000000000200000000200000020000000C :10B02000004000000200000000600000020000007C :10B03000008000000200000000A0000002000000EC :10B0400000C000000200000000E00000020000005C :10B0500000000100020000000020010002000000CA :10B06000004001000200000000600100020000003A :10B07000008001000200000000A0010002000000AA :10B0800000C001000200000000E00100020000001A :10B090000000020002000000002002000200000088 :10B0A00000400200020000000060020002000000F8 ... ... ... :10BF800000A03D000200000000C03D0002000000D3 :10BF900000E03D000200000000003E000200000042 :10BFA00000203E000200000000403E0002000000B1 :10BFB00000603E000200000000803E000200000021 :10BFC00000A03E000200000000C03E000200000091 :10BFD00000E03E000200000000003F000200000000 :10BFE00000203F000200000000403F00020000006F :10BFF00000603F000200010000803F00FFFFFF7F64 :10C00000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40 :10C01000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30
Observer the problem appear when write address reach 0x7BFFF.
Thank you,
