Is there any possibility of modifying UUID, Major, Minor programatically in iOS using nRF51822 beacon
All attributes of an advertisement can be modified on the fly, you do not even need to stop advertising. Just modify the values you wish and re-init advertising.
Thank you AmbystomaLabs
Here's an example of doing that. It is based on SDK11.
Below is the advertising init and then a few lines where one of the parameters was changed. Just remember the advertising data is little endian so the byte order is reversed.
* @details Encodes the required advertising data and passes it to the stack.
* Also builds a structure to be passed to the stack when starting advertising.
static void advertising_init(uint32_t adv_interval )
uint32_t err_code;
ble_advdata_t advdata;
uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
ble_advdata_manuf_data_t manuf_specific_data;
manuf_specific_data.company_identifier = company_id;
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
// If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
// UICR instead of using the default values. The major and minor values obtained from the UICR
// are encoded into advertising data in big endian order (MSB First).
// To set the UICR used by this example to a desired value, write to the address 0x10001080
// using the nrfjprog tool. The command to be used is as follows.
// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
// For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
// the following command should be used.
// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
m_beacon_info[index++] = MSB_16(major_value);
m_beacon_info[index++] = LSB_16(major_value);
m_beacon_info[index++] = MSB_16(minor_value);
m_beacon_info[index++] = LSB_16(minor_value);
m_beacon_info [18]= (NRF_FICR->DEVICEID[1])>>8;
m_beacon_info [19]= (NRF_FICR->DEVICEID[1])&0xff;
m_beacon_info [20]= (NRF_FICR->DEVICEID[0])&0xff;
manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
// Build and set advertising data.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_NO_NAME;
advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
err_code = ble_advdata_set(&advdata, NULL);
// Initialize advertising parameters (used when starting advertising).
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.type = BLE_GAP_ADV_TYPE_ADV_NONCONN_IND;
m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
m_adv_params.fp = BLE_GAP_ADV_FP_ANY;
//m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
m_adv_params.interval = adv_interval;
m_adv_params.timeout = APP_CFG_NON_CONN_ADV_TIMEOUT;
m_beacon_info [20]= 0xC1; //Here we are changing the top byte of minor ID
advertising_init();
