Hi, I'm using nRF52840PDK and SDK 14.2.0. I started from the SAADC example and tried to use NRF_LOG_INFO to print some strings through the UART. I have this:
char test[5] = "test";
char data[8] = "data";
NRF_LOG_INFO("%c*%X*%X*%s*%s", test[0], test[0], test, test, data);
And the output in the UART is:
<info> app: t*74*2003FF14*DU*Y1Z
The first 3 values are ok because the first character is 't', which hex code is 0x74 and is stored at 0x2003FF14 in memory, but when I try to print the whole string, those weird characters appears. This also happened when I tried to form a string using sprintf and using it in NRF_LOG_INFO.
