Conflict in compiling when merging the two examples: gpiote (or pwm_library) and ble_uarte
I have been trying to merge the  pwm_library (or gpiote) with ble_uarte examples to have controle on the pwm signal through UART events
I think i merged correctly the projects enabling the right options in sdk_config, i added the needed .c and includes directory (gpiote into ble_uarte or pwm_library into ble_uarte)
1/ first question: it seems like the order of include directory matters in the list of directories? is that normal? (i.e ../../../../../../components/drivers_nrf/nrf_soc_nosd has to be much further in the list than it is in the gpiote or pwm_library)
2/ Second question: i have better results when on the top of adding the existing .c files (missiing in to the ble_uarte) I also import the file. does it make a difference to have the file local instead of letting it into the sdk?
I get a conflict with the BSP_DEFINES_ONLY  preprocessor definition (used in both gpiote or pwm_library)
'BSP_BUTTON_ACTION_LONG_PUSH' undeclared (first use in this function)   in the bsp.c file ?? this error doesnt appear without BSP_DEFINES_ONLY into the pre-processor
3/ what should i do to make this merging of code compiling?
Thanks for your help
